Going to buy a 2005 with a dead hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jan 5, 2018.
  1. JC91006
    16,769
    8,567
    This car has come a long ways......
  2. Bunce
    Bunce Active Member
    322
    185
    Oregon
    No prius left behind! Well, we'll see in the morning.
    Raytheeagle likes this.
  3. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I did say I'd update so here I am. The weather was a rather balmy 55 degrees when I first started it this morning, so at least 15 degrees warmer than the previous few weeks. It started up and idled just fine, I hesitate to say it's all tickety boo until I start it up when cold again. So, once again, I'll update when that opportunity arises.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Bunce,
    You are rapidly climbing the ladder of success as a Gen 2 Prius DIYer. Making us proud.
    I hope it keeps going well for you !!
    Raytheeagle and Prodigyplace like this.
  5. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I fear it's not all rosy. After my 120 mile or so drive on Saturday I parked the Prius. We live on top of a 600ft climb, so the battery takes a bit of a beating everytime I drive home. Late last night I popped out for some milk, I got in and the battery was at 2 bars, a short 1/2 mile climb over the hill and a mile or so down hill, lightly on the brakes and the battery was at 7 bars. That re-charged suspiciously fast for my liking. Block 6 looks to be consistently the lowest and Block 8 (the semi replaced) consistenly the highest with a delta of about 0.3v between them.
    What's the maximum delta before CEL starts lighting up the dash?
  6. JC91006
    16,769
    8,567
    This is quite normal when you first attempt to repair your battery. It's not balanced so it'll give you problems. If everything else looks good, you can invest in fixing that battery properly now
  7. gamma742
    gamma742 Member
    178
    73
    Luxury
    Grid Charger/Discharger?
  8. Prodigyplace
    12,569
    11,782
    Central Virginia
    Yes. Many here use the @jeff652 's Prolong system from Hybrid Automotive.
  9. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I'll see how the car does over the next month or so. The rattley start up idle seems to be gone, so far. Then it's probably a decision between $700 for the charger/discharger kit or invest that in a battery. I'll monitor the MPG and go from there.
    jeff652 likes this.
  10. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    If I haven't suggest it previously in this thread, check the link in my signature to see what I did when faced with this.
    GOOD LUCK!
    Raytheeagle and Bunce like this.
  11. gamma742
    gamma742 Member
    178
    73
    Luxury
    I'm thinking about one myself.. Maybe I'll find someone in my area to share in the cost and we'll share the unit.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Find the right member and it works out well :).
    We’ve even loaned it out with success (y).
    jeff652, SFO, gamma742 and 1 other person like this.
  13. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Everyone should buy their own, no sharing! :mad:
    hahah just kidding share away it's a great way to spread out the costs :)
  14. Prodigyplace
    12,569
    11,782
    Central Virginia
    Are the sales of used modules working out well so far?
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    You actually gave me the idea a year ago:whistle:.
    But otherwise it sits on the shelf waiting for me, so why not help another member out;).
    You’re warehousing in LA, so I bet you’re close to your personal goal(y).
    jeff652, SFO and Prodigyplace like this.
  16. Bunce
    Bunce Active Member
    322
    185
    Oregon
    On a side note, there's 3 bulbs in the overhead light unit,( I switched them out to LED, I've tried them both ways round). One of which goes on and off with the unlocking and locking of doors. I can't figure out what the outer 2 do? Any idea?
  17. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Those are the map reading lights, they are switched on and off using the push buttons on the left and right.
    Prodigyplace likes this.
  18. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I'm an idiot and feel rather stupid now. :whistle:
  19. Bunce
    Bunce Active Member
    322
    185
    Oregon
    So I bought an auxiliary audio jack that plugs into the CD changer plug in the back, but I can't seem to get it to work. Anyone have any experience with these? http://amzn.to/2Ch2XTQ
  20. Mikesvagen
    Mikesvagen Member
    31
    31
    Kathleen, GA
    I
    Bunce, this thread has been kept me reading off and on all day. I am a new owner myself and learning about my car. The rattle at start up sounds like low oil pressure. That would explain the rattle and why goes away after a short while. Once the oil drains to the pan overnight it may be taking a while to circulate when you start it the next morning.
    Please keep the updates coming!!
