Going to buy a 2005 with a dead hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jan 5, 2018.
  1. Bunce
    Bunce Active Member
    322
    185
    Oregon
    The Mrs informs me the red triangle has disappeared a few days ago. I presume the car has charged it back up to within allowable spec.
  2. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I've decided to make it a little more forest road capable. Step 1- a 1.5" lift and new rear shocks and springs. (Fronts were already replaced).
    Paul Schenck, VFerdman and TMR-JWAP like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Looking good!! I like the way it sits with the extra height.
  4. Prodigyplace
    12,570
    11,782
    Central Virginia
    Are you going to start a long thread to counter those California flatlanders that insist on lowering their Prius? LOL
  5. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I doubt I have the will power. I've been thinking about doing this ever since @strawbrad posted his height modification using suspension components from another Toyota vehicle. We have some killer speed bumps in my plant that are designed to make tractor trailers think twice. I have to take my car inside the gates every now and then. My car does not like those speed bumps at all. I'm not sure how my exhaust is still connected to my car. An extra inch or so would make a world of difference.
    Prodigyplace likes this.
  6. Bunce
    Bunce Active Member
    322
    185
    Oregon
    A couple more updates and a trip report. After the winter tires and 1.5" lift, I installed a hitch with a Thule 665C cargo box. This enabled us to complete a 2600 mile road trip around the Sierra Nevada and sleep in the back. 2300 miles of the trip were in the mountains and the Prius did great.
    We woke up in some spectacular places. 20210321_074437.jpg 20210323_074931.jpg 20210323_155548.jpg
    VFerdman, fotomoto and Raytheeagle like this.
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
  8. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Here's the easy way to lift it. 2004-2009 PRIUS
  9. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I've jinxed myself. We went for a trip into the mountains and got a P0A93 on the way up so turned around as a precaution since I wanted to head up remote dirt roads. I think it is the inverter water pump. And I think I replaced that shortly after buying the car at 205,000 miles if I remember correctly. Currently it's at 252,000.
    There's no turbulence in the coolant reservoir. I just checked. So I think that definitely confirms a new inverter coolant pump is needed.
    How long do these usually last?
  10. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    I drove several hundred miles with that one. Eventually replaced it. It was easy repair.
  11. golfmk681
    264
    105
    los angeles, ca
    Impressive locations you’ve taken the Prius in.
  12. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Genuine OEM ones generally last 100,000 miles or more. Aftermarket and counterfeits not so much.
  13. Prodigyplace
    12,570
    11,782
    Central Virginia
    Don't let those flatlander Californians catch you. They spend big bucks to lower a Prius.
  14. golfmk681
    264
    105
    los angeles, ca
    I’m a flatlandwe but who lowers the Prius LOL. I have seen 3rd gen lowered here though. You know for efficiency sake
  15. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Looks like we hike the same trails
    iPhone ?
  16. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Another update - it recently ticked over 299,998 miles. It's stuck at 299,999 now. That's over 100,000 miles of driving. I'm glad we took the gamble on buying it.
    srellim234 and bisco like this.
  17. Paul Schenck
    523
    306
    Fresno, California
    I kept track with a log book and the trip meter for a while then contacted Texas Hybrids and exchanged mine for one with the correct miles on it.
    iPhone ?
