Going to buy a 2005 with a dead hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jan 5, 2018.
  1. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Am I right in thinking there's 2 seperate coolant systems? I'm going to have to replace the water valve since I have an error code for that.
  2. JC91006
    16,769
    8,567
    Yes, 2 separate systems. You should change the valve the same time you drain the coolant. Check the water pump and belt while you're at it
  3. padroo
    padroo Senior Member
    2,763
    2,252
    I prefer a .pdf because of the search feature and then print out the parts I need. Each to his own.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I like your advice to bunce. That's the way it should be. No one should be relegated as some folks are doing right now with bunce, that has decided to buy the car.
    If I were in his shoes, I'd buy that dammed Prius, and fix em. I'm ready to bear such risks.
    If people can't advice him, sharing their experiences, they should jog on! Simple.
    Nice work sir!
    Mikesvagen and Bunce like this.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Please I here people say its possible to get a gen2 Prius for $500-700. Is that really true? I mean, maybe accidental, or something?
  6. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I did pay $500, but there's a reason it was only $500.
    Obviously the hybrid battery is on it's last legs, the clear coat on the roof and spoiler have failed,a few other error codes, there's a decent dent in the right rear quarter panel and a ding in the left front quarter, the hatch handle piece will fall out if you try and open the hatch with it. The interior also looks pretty grubby, but that seems to be a way a lot of the beige interiors look even at higher prices.
    I had arranged to buy one for $1200 a few weeks ago, made an appointment at the sellers convenience and then the bugger sold it out from under me, but that one was in great shape with only the battery issue (as far as I could tell from communication and pictures).
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The order or replacement for my 4 prii
    Front wheel bearings
    Header to muffler donut
    Struts
    Gen 2 needed a steering wrack
    Dealer inspired replacements
    Brakes......sneaky suckers
    500$ not bad, now 2500$ for a new Toyota traction battery, 2-3 years of 50mpg or better, honestly, even if they have a good reading the traction battery is how many years old?
  8. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Supposedly it's had its battery replaced before. What with? I've no idea, but I'd say some form of reconditioned battery.
  9. bisco
    51,994
    have you checked the toyota owners website for service records?
    either way, you'll find out when you open it up.
  10. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I did a VIN lookup on it to find the spec. I didn't see a service record search. That could be handy, do you have a link by any chance?
  11. Prodigyplace
    12,570
    11,782
    Central Virginia
    Toyota Owners Official Web Site
    bisco and paprius4030 like this.
  12. gamma742
    gamma742 Member
    178
    73
    Luxury
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    If you put the vin# in at the Toyota owners website it will give you a service history if a Toyota dealer worked on the car.
  14. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I think I like cars like that. I fix such cars, and would be a great business for me.
    Clearing, and all that would be where the pockets gets hurt.
  15. Bunce
    Bunce Active Member
    322
    185
    Oregon
    So I got that Toyota service history, all looked pretty good and fairly regular until the last entry in Feb of 2016. It looks like they've been tackling mis-fire issues a intermittently since 125,000 miles.
    It got a new short block at about 80,000 due to coolant consumption.
    There's a considerable number of cleaning the intake and throttle body services.
    Feb. 2016
    CHECK ENGINE LIGHT ON,REPORT ~|~CHECK ENGINE LIGHT ON,REPORT ~|~ ~|~189157 100 CHECK CODES HAD CODE P0300 P0301 P0303 AND P0420 MISFIRE CODES ONE CYLINDER ONE AND CYLINDER 3 TRIED SWITCHING COILS AND SPARK PLUGS STILL MISFIRING ON 1 AND 3 CHECK COMP WAS LOW ON CYLINDERS, CHECK WITH BORE SCOPE HAS A LOT OF CARBON BILLED UP
    How does one get rid of that carbon buildup? I read a thread where someone had the same issue and ran I think 5 bottles of Chevron Techron through their tank in 5 consecutive tanks of gas. He was well happy with the results.
    Thoughts?
  16. JC91006
    16,769
    8,567
    I think you should try and fix the battery and sell the car. This one is not a keeper.
    paprius4030 likes this.
  17. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Is this where a good old fashioned Italian tune up comes into play?
  18. JC91006
    16,769
    8,567
    This car is probably worth more if you parted it out, and not sell it whole. But it depends how much time you have available and if you have a storage place for the parted car.
  19. Bunce
    Bunce Active Member
    322
    185
    Oregon
    For me to buy another Prius or a VW TDI we'd be spending about $5000-7000 for a decent one. I'm going to see what we can do with this. I'm a full time student and it'd be nice to just use this for a few years, upgrade the campervan and stash a few grand for a rainy day.
    I've been looking up techniques for getting rid of the carbon and so far found sucking in water or seafoam into a vacuum line, has got some peoples cars running better. Can you use the vacuum line connected to the PCV as that would go into all cylinders?
    I've heard a mention of a soak but not a description of the process, so not sure how that works? Maybe pull plugs and spray something in and let it soak? Then drive like a bat out of hell?
    I also read about doing a half tank of E85 mixed with regular.....research continues.
  20. bisco
    51,994
    you might as well get the battery done and see how she runs before worrying about the next step.
