Going to buy a 2005 with a dead hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jan 5, 2018.
  1. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    Wait! This engine has VVT?! I had no idea!
  2. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Well the bloody misfire on cylinder 1 is back. I know why, it's because I drove off as soon as I started the car. If I stay still until the rattley engine subsides it's usually fine. If I drive off, it triggers a code, so I don't think this is normal.
    51,886
    bad head gasket?
  4. Bunce
    Bunce Active Member
    322
    185
    Oregon
    No oil in water or vice-versa. But why would that cause a rattley sound for about 1 minute at warmup?
  5. bisco
    51,886
    danlatu says it is because the engine is burning off the coolant leaked into the cylinders.
  6. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    That won't cause the rattlely sound. I already told you back in page 8-post #159 why it makes the rattle/clickity-click and it is not a defect. It is supposed to do that.
    If you drive off gently in stage 1 so you are only using the HV battery/electric motor, does it still misfire?
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Nope only if the engine is used.
  8. bisco
    51,886
    can you post a recording of the sound?
  9. dolj
    dolj Senior Member
    8,437
    4,288
    So are the misfires so frequent that the MIL comes on?
  10. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Is MIL the same as the CEL? If so, yes.
  11. dolj
    dolj Senior Member
    8,437
    4,288
    Yes, that's it MIL is what Toyota calls – malfunction indicator light.
    One last question, if you start the car from cold, and let it complete stage 1 while sitting still, that is, until the engine shuts off, then drive off on the petrol engine, does it still mis-fire on 1 & 3?
  12. Bunce
    Bunce Active Member
    322
    185
    Oregon
    No, if I wait, it's good.
    Weird huh? But if I stop, turn it off, just for a few minutes, I'll still to wait for it to do that warm up cycle or I'll get MIL.
  13. dolj
    dolj Senior Member
    8,437
    4,288
    Yes, that is strange. If the car is warm, it virtually skips stage 1. Are you saying yours doesn't and always runs for 50 secs?
  14. Bunce
    Bunce Active Member
    322
    185
    Oregon
    No. Without knowing much there's 2 scenarios.
    Turn car on and drive off, this almost guarantees an MIL will pop up on that journey shortly after starting.
    Turn car on, sit and wait for engine to do it's thing then turn stop, I then drive off, usually no MILs for entire journey.
    The disadvantage I have is I don't drive it regularly, like a commuter would. I live about 1.5 miles from college and walk most of the time. Taking the Prius is pointless since it won't warm up in time. So, I try and do a test loop on the same route when I'm looking for something.
  15. JC91006
    16,767
    8,565
    When the new injector comes for cylinder 3, move number 1 to number 2. See if the misfire moves. If it passes, then move the coil over
    These refurbished injectors could be an issue
    Bunce likes this.
  16. padroo
    padroo Senior Member
    2,763
    2,252
    Does anyone know how long it takes the engine to go into closed loop?
    I have heard of cars having vacuum leaks when the engine is cold and when they warm up the leak gets sealed due to expansion from heat.
  17. VFerdman
    1,186
    1,215
    I would try a new injector, not refurb. It's more runaround than it's worth with another un-known.
  18. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I haven't got the new(refurbed) injector in yet, too cold and rainy.
    But I have been thinking, I'm thinking the rough running engine on warmup might have something to do with the ecu software. Was there ever any software updates or anything of the sort?
    What's the latest ecu that would work in my 2005, if I can find one cheap, I might try it and see what happens. The roughness just seems to happen on a particular cycle of the warmup.
  19. padroo
    2,763
    2,252
    The ECU on cars goes from what is called "open loop" until the car reaches a certain temperature is reached and then it goes into what is called "closed loop" when the engine reaches a certain temperature. When in open loop a lot of inputs to the ECU are not used, it just runs it's program and when it goes into closed loop it starts taking inputs from the O2 sensors and other inputs to adjust fuel trims to optimize fuel delivery for pollution and economy. It will stay in closed loop as long as the car is turned on ( Ready), as soon as the engine cools the engine will restart because it will always try to keep from polluting and will always try to keep the fuel to air ratio at 14.7 to one. If you has a scanner that reads out live data or maybe Torque Pro will show the Open Loop and closed Loop readouts. If you are watching it and it smoothes out at the switch I would guess that is what it is.
    This is the short answer, go on YouTube and type in open and closed loop.
  20. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I post with promising news. I installed the refurbed injector in Cyl. 3. Disconnected the battery to reset the witch box, held my breath and started it up. It sounded Horrible with a capitol H. I figured it may be because there was no fuel in cylinder 3 for a second. I turned the engine off, disconnected the -ive again and restarted. It sounds good! I killed it and restarted a few times, still good. I just got back from a 116 mile drive @ over 45 mpg and no error codes.
    The test will be tomorrow morning, starting from cold, that's when it was at its worst. Fingers crossed.
    Raytheeagle and JC91006 like this.
