Going to buy a Gen 2. What should I know?
Discussion in 'Gen 2 Prius Main Forum' started by Isaac Zachary, Jul 15, 2018.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,155
    1,776
    Mars Hotel
    As I understand it, my relatives were all wool gatherers: To go woolgathering means “to indulge in aimless thought, day dreaming, or fruitless pursuit.”
    kris
    #21 cyberpriusII, Jul 15, 2018
    51,944
    sheepskin seat covers?:eek:
    Isaac Zachary likes this.
    51,944
    that is a definite possibility. i must have inherited some of those 'qualities'.:whistle:
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,548
    1,293
    Yes siree bobtail Peter horsefly! And also in the engine compartment to keep the engine warm.
  5. cyberpriusII
    1,155
    1,776
    Mars Hotel
    So, once again, I feel guilty taking this to a fred's post level.
    Hope someone with some real knowledge replies. At least we have kept it up top. As for me, I am exiting to listen to Richard Manuel.
  6. rogerthat
    rogerthat Active Member
    387
    124
    Georgia
    My feeling is if you're climbing that much in a day and using AC in summer and heat in winter, forget about a Prius. Whenever I climb substantial hills (nothing like in your neck of the woods), you end up relying on the under-powered ICE and it is miserable. In any case, a car with 700k miles deserves a push towards a million. Good luck.
    DLC82SV and Isaac Zachary like this.
  7. Isaac Zachary
    2,548
    1,293
    You don't know how tempting it is for me to just keep the old smelly Golf diesel. The car is immortal. But then again it doesn't have any sort of A/C system at all.
    But on the other hand I think a second gen Prius would blow the doors off my ol' Golf. No wait, they do all the time. The Golf has 52hp at sea level. Up here it has less than 40hp. And that's with a 5 speed manual, not a CVT. Just last month I got pulled over by a cop wondering if my car was defective or something for going 35mph up a 7-8% grade and offered to follow me home if that would make me feel better.
    jerrymildred likes this.
  8. Isaac Zachary
    2,548
    1,293
    I just checked out Car Complaints and noticed the 2009 Prius gets "The Seal of Awesomeness", so that's encouraging.
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Car fax and Toyota records should flush out and flooded or damaged cars, I say go for it, yes on a factory installed traction battery, probably a 12v also.
    Studded Nokians make all the no go issues melt, if there’s to much snow to go, don’t go, the studs will stop you on ice.
    The gen2 with body stiffeners and an upper front strut bar is a cornering beast, gen3 is a hog, nothing will help, great ride, but no finesse.gen4 is also a cornering beast, without stiffeners, adding them would only help.
    So, my gen2 needed front wheel bearing and a steering wrack and struts at 60,000.
    After the parts were added it was back to being a wondercornerer.
    Rust wise, you might want to get one from the southwest, that’s never seen salty roads.
  10. rogerthat
    387
    124
    Georgia
    Isaac, do yourself a favor and see if you can take a Gen2 car for a test drive and drive it on a constant extended uphill route with AC on. You may not be so high on the Gen2 after that.
  11. Isaac Zachary
    2,548
    1,293
    Thanks @Lucifer !
    Anywho, I guess if it's a 2009 it should have good information on Carfax seeing how it probably would still have been on full coverage. Once a car gets too old though, like some of mine I've had, you don't do full coverage and you don't take it to a mechanic or anything else. If it breaks you fix it. I don't know how that kind of info could get onto Carfax.
    Just a question, what kind of fuel mileage car I really expect?
    I tried my 150mile route in a 2013 Nissan Leaf. The nice thing is that charging was free! (See how frugal I am?)
    But the range was too iffy and I went back to my 50-60mpg VW diesel. I love doing my drive and in 4 days of driving this far only pay $50 in fuel.
    The Prius is rated for 45mpg on the highway. Not too bad, but then I have lots of climbing to do. But then again, I do in my diesel, and it was only rated at some forty some mpg too. I also try to hypermile a bit. I don't like driving faster than the speed limit, and that varies between 40 and 60mph along my highway route. Plus sometimes I even drive slower just to save a bit more fuel.
    Do you think a Gen 2 Prius will be similar in fuel mileage as my diesel? Just making sure, the Prius also uses regular octane too right? (Which is cheaper than diesel too.)
  12. Isaac Zachary
    2,548
    1,293
    Yes, I would like to try to do that. But say I do, and end up not liking the Prius. What should I do then? I bought my Golf rustier than a car that sunk with the Titanic (hyperbole). I don't really want to fix it up if I don't have too.
    A little more information. I just sold two other cars, a 2013 Nissan Leaf and a 1972 VW Beetle. I got $7,000 and $5,000 respectively. So I have $12,000 to spend on a car. But I'm used to getting +50mpg. Yes, I know that up at these levels 40mpg isn't going to be a huge difference, even at +30,000 miles per year. But I don't want to drive a Mitsubishi Mirage either. If a Prius isn't for me, any suggestions on what to get?
  13. rogerthat
    387
    124
    Georgia
    Better to find out that the Prius is not suitable before purchasing...so try the test drive. Googling Prius mountain passes and AC may offer some insight. You're not going to get the type of gas mileage you're getting with your VW, but something like an AWD Impreza may be a good idea....or just get a Corolla!
  14. Isaac Zachary
    2,548
    1,293
    I'm googling about the Corolla as we speak. How to they compare in longevity? Which years? It's kind of discouraging seeing the Corolla rated to get only 33mpg on the highway. :(
    I want 60mpg if possible, but a car that lasts a million miles if possible, and that isn't a lemon clunker project car or a $30,000 brand new car to start out with. Something I can pay cash for, repair and take care of and not ask myself why I'm spending $500 per month in fuel in.
    As far as AWD goes, it's overrated. I've been driving for some 18 years in the mountains of Colorado and have never seen it of much use. Even last year during our several feet deep "snowmaggedon" winter I only got stuck once ( happened in my 2013 Nissan Leaf). I don't see paying extra for AWD if it only comes in handy once every 5 years or so.
    #34 Isaac Zachary, Jul 16, 2018
  15. rogerthat
    387
    124
    Georgia
    60mpg, up mountain passes, with AC, hmm maybe this
  16. Isaac Zachary
    2,548
    1,293
    :LOL: Good one!
    I actually had to drive my 2013 Nissan Leaf no more than 35 mph with heat and AC off to make it back home on my route. It did get old after a year.
    Anyhow, I could always just turn on the AC going down hills. That's kind of what my Golf does, but with the heater. When it's super cold, it puts out heat on the way up the mountain, but then starts blowing cold air going down. I have three peaks on the way there and on the way back.
  17. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    My 2c – stick with your Golf. I don't think a Prius (or any hybrid) would suit what you want from a vehicle.
    A corolla would be a good option too. Yes, they are very reliable. On average. There lemon corollas too.
  18. Isaac Zachary
    2,548
    1,293
    In what ways would the hybrid not meet my needs?
    Anyhow, I guess I'll just figure out what to do here with the Golf. I love the Golf but also would like a bit more safety. (It doesn't have any shoulder strap seat belts in the rear for an example, nor airbags.) And the paint and interior are pretty bad and the sunroof leaks pretty bad too. I guess I could spend money on fixing those things up on this car. And the black clouds of death do bother me. But whatever. If it's better to climb up 65mph hills at 45mph with big black clouds of death in an old diesel than a newer hybrid, I guess I give up.
    #38 Isaac Zachary, Jul 17, 2018
  19. dolj
    dolj Senior Member
    8,446
    4,291
    The mountain driving will be hard on the battery.
    You didn't mention that before, so obviously a big consideration and would make a lot of sense to retire the VW.
    Again that would not be preferable. But I still think a hybrid may not make sense for intense mountainous driving. However, a newer, safer, and economical car would be better than a diesel that is overdue for some TLC.
  20. Isaac Zachary
    2,548
    1,293
    I thought that was a given. Any pre-mid-nineties diesel is not going to have a particulate filter and is going to blow black smoke under full throttle. And a pre electronics diesel (aka: mechanically injected) isn't going to have any way to compensate for altitude, producing more smoke the higher the altitude.
    Ok, but I would like to get a car that has the qualities my old car has. I don't want to change 55mpg for 30mpg. Looking at 3 to 5 year old Corollas, they are rated to get only 33mpg. Ok, so to be honest 55mpg diesel is equivalent to something like 48mpg gasoline. What do you suggest? Mitsubishi Mirage?
