GoM *and* Battery Percent
Discussion in 'Prime Technical Discussion' started by mr88cet, Oct 8, 2018.
  1. Tideland Prius
    16,681
    Anyone noticed that the battery meter isn't linear either? At "50%" on the battery illustration, the actual percentage is in the 30s as shown in the display if you switch to %.
    mr88cet likes this.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I don’t recall seeing that sort of non-linearity. I’ll have to give it a look again on my way home this evening.
    When you say “50% on the battery illustration,” are you including the reserve for hybrid operation? The %battery doesn’t include that, of course.
    Salamander_King likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Correct. The scale is different than the actual charge in the battery, since Toyota isn't using the top 20% or bottom 20%. So, 100% indicated (which is all you are using) is actually about 80% using software like Hybrid Assistant. When you get down to 0% indicated on the dash, it's in the range of 20% on the aftermarket tool.
    The one that matters is the dash display, since that accurately shows how the car will behave. 0% indicate battery = no EV mode. 100% battery = no more regeneration capture in the battery.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Are you talking about the battery illustration in the HSI? The numerical percentage displayed is for the EV portion only. Mine is pretty close to 50% of EV portion when the numerical percentage is 50%.
    As commented above, you can not include the reserve hybrid portion.
    jb in NE likes this.
  5. Tideland Prius
    16,681
    Yes. (although I was talking about it in the split display next to the speedo but it's the same display). Yes, where you labelled "50%" in your photo, the car says it's 33%. I will have to take a photo cause I see yours correlates correctly.
  6. Tideland Prius
    16,681
    No, I'm only counting the EV portion ( the green part). @Salamander_King has a photo that shows 50% on the battery meter and 50% (value) on the HSI screen. I'll have to take a look at my car again. When I saw 50% on the battery meter (green portion only), I saw 33% (value) on the HSI display.
  7. Salamander_King
    11,024
    8,980
    New England
    Here is a 40% picture. It is possible the battery illustration's green level does not move much from 50% to 30%. I looked but did not have any pic for the 30% level.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    For a wealth of data, watch the detail available on this video...
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Or, get the Hybrid Assistant app and do the comparison on the car in question.
  10. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Another option is to switch to the mi/kWh screen. You can make range estimates based on:
    4 mi/kWh ~ 25 mi EV range
    5 mi/kWh ~ 30 mi EV range
  11. Tideland Prius
    16,681
    Fortuitously, here’s my commute today at 57 and 31%.
    Yeah I must’ve been dreaming about the 33% at half. But yeah it doesn’t move too much. Seems like more than 1/3 on the battery display.
    88C938B0-9B73-46CA-A45C-F9C8DEC64DCE.jpeg 297E3248-3EF1-4EBE-B3AB-A3C9D6C9F7E5.jpeg
    john1701a and Salamander_King like this.
  12. Salamander_King
    11,024
    8,980
    New England
    I never use the split screen battery level (one next to the speedometer), but yeah, it is a slender version of the battery icon on the HSI, and that should makes it easier to see the changes but doesn't. Still, too few ticks on the bar to make accurate reading. ;)
    Tideland Prius likes this.
  13. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    it's possible but I managed only once to bring down the blue part of the battery while driving EV ( really slow ... lol )
