For Sale GONE: lsqSTAR 8 Inch Head Unit $100
Discussion in 'Private Sales' started by Dylan Doxey, Mar 20, 2016.
  1. TriniTT
    TriniTT New Member
    Birmingham, AL
    2012 Nissan LEAF
    Ok thanks, needed to know so I can research the reverse hookup.
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    This is what the connector on the wiring harness looks like.
    You can see pin 2 is labeled "rev."
    Here's the adapter that comes with the head unit.
    The white plug with three black wires plugs into the wiring harness. The three black wires are the steering wheel controls (labeled SWG, SW2, SW1). You just need to make sure that the backup signal wire (the single black/orange) goes into pin 2.
    The harness connector above is for 2013 and before. I had to hack that connector to make it work with my 2014.
    #22 Dylan Doxey, Oct 7, 2016
  3. Dylan Doxey
    1,389
    3,455
    92
    This is still available folks.
    #JustSayin
  4. iamfillet
    iamfillet Junior Member
    Is this still available? Does this works with the factory JBL unit? I have a 2010 with JBL. Thanks
  5. Dylan Doxey
    1,389
    3,455
    92
    Yes, I still have it.
    I don't know if this unit can be used with JBL. The safe answer is "probably not", but I don't know well enough to say for sure.
  6. riceroni87
    riceroni87 Senior Member
    360
    597
    Oxnard, CA
  7. Dylan Doxey
    1,389
    3,455
    92
    This item is no longer available.
