Gonna Try a 12V Heater for Winter MPG's
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 12, 2012.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    I recently saw that Harbor Freight is selling these 12v heaters for $10 (Its listed for $14.99 but the flyer has a coupon for $9.99). (12V Heater w/ Fan)
    I'm gonna give it a try to see if I can save some mpg's in the upcoming winter months. This (along with ccdisce's wonderful ECT spoofer) should give me summer-like fuel economy in the normally fair KY winters. I will be mounting it in front of the center console (not hard mounted just placed there) and will move it on the dash if I needed to defrost.
    I will let you know if it does what I expect. It is cheaply made but, what do you expect for $10? I wouldn't recommend it for colder climates like MN or WI etc but, in the milder areas (AL, NC, SC etc), it should warm you up pretty good (I'm hoping anyway). We'll see.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I'm not sure what the 12 volt outlet fuse is rated for. Hope the heater doesn't draw more than the fuse's rating.
  3. tv4fish
    tv4fish Member
    202
    46
    Heater ad says it uses/needs a 15 amp fuse
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    I tried it out the other day and it ran fine w/ no issues for about 15 minutes.
  5. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    The power outlets on the prius use 15 amp fuses.
  6. bisco
    52,891
    excellent! thanks usnavy, keep us informed. some of us pip drivers are looking for just a bit of warmth to add to the heated seats so we can ev all winter without ice.:D
    usnavystgc likes this.
  7. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    I think this is something Toyota could have improved upon. The inverter and transmission produce upwards of 2kw of heat that is thrown away by the inverter cooling system. If a small heat exchanger was plumbed into this system and the air flow put into the cabin air intake much of this heat could be usefully recovered. The coolant after leaving the heat exchanger would then go through the normal rad.
  8. richard schumacher
    7,686
    1,068
    United States
    It will provide heat immediately, which is nice, but it will reduce fuel economy by some trifle. You'll be using the engine to create electricity to charge the traction battery to charge the 12V battery to run the electric heater, instead of using engine heat directly.
  9. Britprius
    5,194
    1,924
    Also the PTC heaters do exactly this.
    Assuming this fan heater uses a couple of amps to drive the fan and it does load the electrical system to 15 amps the heat output will be around 100 watts. Not very much I'm afraid.
  10. John H
    John H Senior Member
    2,208
    558
    But if it is running for an hour or so before unplugging the PiP from the charger, it could take most of the edge off of a cold cabin in advance.
  11. Britprius
    5,194
    1,924
    If the car is in a position where it can be charged why not use a mains heater rated at say 1kw plugged in. Other wise you are converting mains current to 12 volts to charge the battery then using the 12 volts to run a heater discharging the battery.
    Also if the charger stopped working for any reason "lost power supply, charger fault etc" and the heater is running off the battery that battery is going to be discharged very quickly.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm a fan of heated seats for winter fuel economy. I find I turn the heater on for about a minute or three depending on ambient temperature, and that is enough to tide me over until the ICE is hot enough to supply waste heat.
    OP's 12v heater sounds like a good hack, but potentially dangerous in an accident.
  13. John H
    2,208
    558
    I'm thinking simplicity. One heater, one mains connection (via the EVSE, public or private). You are right about the potential to drain the battery if the AC get's interupted. I would be sweet if there was a 12V connection that would cutout if the circuit dropped below 12.5V.
    12V Low Battery Cutoff Kit | Buy Online | Volt Electronics
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, not enough, I have a 120 volt, 400 watt oil filled heater, left it on max temp all night, the next morning the outside temperature was 47 degrees f inside: 51 degrees f
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    Everyone has some good input here. It does not put out that much heat. That's why I said it is fine for milder climates like KY but def not enough for the north. I know I won't be roasting in the cabin and I'm pretty sure I'll be cold. My problem is a 6 mile one way commute that takes about 12 minutes to complete. By the time I get to work, the cabin is just getting comfortably warm. Without this heater, (and ccdisce's ECT hack), the ICE runs the entire time.
    Today the outside temp was 55 f when I left home (not a good test day). I turned on the heater right away and directed the flow to my legs. I could feel the warm air w/in 20-30 sec's. By the time I got to work, the cabin was starting to get warm (just like if I used the stock heater). The difference is, I was in S4 in 45-50 sec's w/ ICE off at the first stoplight vice ICE running the entire way to work. It is def not as good as the stock heater but, I'm hoping it will provide some comfort on the milder winter days.
    As far as it being a safety hazard, I'm not sure how???? It is small, doesn't weigh a lot, stays in front of the center console without moving around. I would say its about as dangerous as an aftermarket GPS that's mounted in one of those non sliding dash (bean bag style mounts). It may be even less dangerous because I keep it low.
    I'm not trying to advocate this to anyone, I'm simply sharing my idea and will later post my results.
    My running average FE is 50.1 mpg over the last 10 tanks. This is my "summer" mileage. I'm hoping to achieve similiar winter results but, as I said earlier, "We'll see".
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, I'm sure it will reduce FE but I'm hoping not as much as the stock system.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Can you take advantage of an engine block heater ?
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm sure I can. I just haven't done it yet.
  19. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, we've had a few "colder" days and here's my observations/results.
    The heater is providing a dissapointing amount of heat on days colder than 40f. Using it has had the desired effect of improving winter mpg but my mpg is not equal to summer mpg as I hoped. With this heater, it is only good on the mildest of days (above 40f).
    Conclusion: It was a good try but didn't meet expectations. In my view, a waste of $10. Not recommended.
    bisco and Britprius like this.
  20. Britprius
    5,194
    1,924
    Thanks for an honest conclusion to your test. Sorry for the waste of money as I no it is not always easy to admit defeat.
