Good CFL, bad CFL...user recommendations
Discussion in 'Environmental Discussion' started by Celtic Blue, Dec 30, 2008.
  1. msirach
    msirach Member
    321
    Southern Illinois
    I bought the same LED's at Sam's Club. They are a dim 40w equivalent so I put them in several small accent lamps that are on a lot. I do have three candelabra shaped in a fixture in the foyer that has several hundred beaded crystal prisms.
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I picked up a pack of 100W equivalent n:vision CFL's at Home Depot today. They are "Commercial Electrics". Same shape, same instant on, same model number. The other wattage n:visions I have also seem to use the same model numbering system. So it looks like they just changed names some years back.
  3. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I'm curious to hear about what sort of failure rate you experience with them. They seem a bit hit or miss. The hits are great lights. The misses are shite. Still, they're so cheap a lot of the time that it doesn't really matter. I got a 6 pack of them for $3.99 about 4 years ago at home depot and I just installed the last two (I think) the other night when I lost two bulbs at the same time (a rather odd coincidence it would seem). At those prices I can't be arsed about occasional dud.
  4. Celtic Blue
    2,224
    139
    Midwest
    tripp,
    I had one package of 100W that all failed within two weeks about 4 years ago. The rest of the 100's are still going strong--except for some attrition due to being physcially struck or damaged in the fixture.
    I believe I also had a package of 60W Commercial Electrics purchased about the same time that only lasted a few thousand hours (on all night in the bathroom for toddlers), they could have been GE's, but I think they were the Commercial Electrics.
    The failure consistency of a given package has been good. When one has gone out, the others in the package soon fail. (But I've only had two packages ever fail, a 100 and a 60, and can't recall if the second one was Commercial Electric or not.) I've taken to writing a date of purchase on the base of each bulb so that I can keep track of them, but only started this a few months ago. Like you say, they are either great or crap, with little in between.
  5. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    While it's not about CFLs, I spent part of last night playing with
    a 3 watt LED. Got it from Mouser; it comes pre-mounted on one of
    those six-sided little "star boards" whose back side is aluminum
    to be mounted on a heat sink. The thing could easily handle a
    watt without heatsinking, and then when I started to push up to
    an amp through it a minimal chunk of aluminum clamped to the
    backside was more than enough to keep it cool. Now, think what
    shoving an amp through a typical old-school LED would have done...
    The really amazing part is the "lip test" ... since skin near
    the mouth is quite sensitive to heat and cold, placing one's
    lip in the path of a strong light [e.g. a laser] can yield a
    convenient ballpark indication of how much radiant power is there.
    I could feel more heat coming at me in the *output* from the
    device than the device itself was producing otherwise, i.e. it
    was pretty clear that was turning a high proportion of the power
    input into light and when I actually touched my lip to the
    surface of the device, it felt *colder*. Try that with a
    light bulb.
    Hopefully LEDs will soon reach the lm/W efficiency of short-arc
    discharge lamps or maybe even sodium vapor. That will be so
    cool on a whole bunch of levels.
    _H*
  6. tripp
    4,717
    79
    Denver, CO
    interesting, 'obbit. It would be great to go through another lighting efficiency jump in the next decade or so. I wonder how much money a typical medium sized city would save by having ALL traffic lights be provided by LED. Throw in street lamps and it's a pretty substantial amount of power that doesn't have to be generated. Negawatts indeed!
  7. Fibb222
    Fibb222 New Member
    1,499
    99
    All the traffic lights in my neck of the woods went to LED a few years ago. Much brighter and no doubt very cost effective.
  8. tripp
    4,717
    79
    Denver, CO
    Here in Denver it's a mix. I still see quite a few old style bulbs, but quite a few new ones too. Sadly, I see old styles in some pretty new intersections. Why didn't they installed LEDs in these from the get go. Perhaps they're hard to comeby. Don't know why the city would elect to waste money like that.
  9. hobbit
    4,089
    470
    Bahstahn
    Taking a cue from the fine folks here and a need to kill some
    time before dinner, I stopped in the Orange Box to look around
    and found that yes, they *do* have a 68 watt [real] unit:
    This thing is a *monster*. It is the hulking Escalade of compact
    fluorescents, claiming to produce the equivalent of 300W and
    4200 lumens. The box it came in, easily 11 inches long, is also
    printed "2700K" but that seems awfully low for a color temperature.
    From tcpi.com, a domestic company, but of course actually manufactured
    in the usual place. When I got it back to the car I tried it in the
    inverter, and it was very dim due to being cold but then the brightness
    gradually crept inward from the ends. The tubing is about twice as
    thick as any of the others I've got, even the 42-watt jobs.
    I found it in with the sodium lamps and metal-halide capsules,
    in the outdoor security-lights section. They're apparently aimed
    at the "flood the parking lot" market. Sets of these, mounted in
    the clip-sockets with the *big* bowls attached, might actually
    do the trick for various outdoor events.
    _H*
  10. patsparks
    10,664
    569
    Adelaide South Australia
    All, or almost all Adelaide traffic lights are LED and most have been long enough that most have been renewed at least once. I think there were reliability issues with the early ones. I have noticed the lights have been set up that a minimal number come on at once, for example where the round straight ahead and right turn arrows once came on together now the green turn arrows come on a second before the round straight ahead greens. I'm not sure if that's a control thing or done to make the LEDs live longer?
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sounds like how they are controlled. Unsure how that could be a MTBF advantage
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    As far as CFL's to avoid: anything from Canadian Tire that is marked "Globe." They have a habit of going POP and exploding when you flick them on.
  13. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    We have CFLs throughout the house for the last 10 years, including rear and front porch lights. Great light and reliability.
    We are looking forward to making the move to "white" LEDs. Lower power consumption, better light. CFLs have run their course. Time to move on.
  14. tripp
    4,717
    79
    Denver, CO
    It doesn't sound like LEDs are there yet. They're expensive and the Lumen/Watt is still not quite up to CFLs. Light quality sounds like it's still an issue as well. When they're ready though, it will be another great leap forward (no homage to mao there, it just sorta came out that way) in efficiency.
  15. Celtic Blue
    2,224
    139
    Midwest
    skruse,
    I'm looking forward to LED's, but from what I can see they have a long way to go. CFL's whip them hands down at the moment in many areas: diffusion, cost, and color temperature. The LED's have many niche advantages, particularly small size and the increased efficiency is great, but won't save nearly what a simple incandescent to CFL conversion will save at a fraction of the cost.
    I've been using variable brightness red LED flashlights since 1996 for astronomy (doesn't bleach out the rhodopsin and the 9V battery tends to last a year or so.)
    I've got a few LED applications (wall socket and wall plate nightlights, flashlights, and Christmas lights) and prefer them when they fit the use, but I'm still waiting for good mainstream LED lighting at a reasonable cost. Work out color temperature and diffusion at a reasonable cost and the LED's will be winners.
  16. Celtic Blue
    2,224
    139
    Midwest
    I had a brief experience with a 60W equivalent Satco bulb today. It used thin spirals (rather than the normal thickness seen in most bulbs.) Unfortunately, it had two flaws: it was definitely not instant on, and it was a bit longer than the n:visions I'm using. The latter resulted in it sticking slightly below the bell of the fixture I was considering (A "Bright Effects" bulb had the same problem in another fixture at Lowes...n:vision fits it perfectly.)
    Major milestone: Purchased my last major fixtures for CFL conversion in this house today! :party: An ugly, eight 40W incandescent, globe fixture is about to see last light...when the weather warms up enough for me to venture into the attic to add new eletrical boxes and wiring without losing too much gas heat that direction.
    Ignoring simple CFL conversions of about three dozen bulbs in existing fixtures (and also two LED conversions), I will have replaced the fixtures of 26 candelabra bulb incandescents, 18 globe incandescents, and one closet incandesent bulb, all with fixtures that can take standard CFL's.
  17. patsparks
    10,664
    569
    I know they are controlled, what I mean is it may be that the computer program used to control the lights can't do two things at once so it is programed to turn the green right arrow on a second before the round light. I could drop by the traffic signal section at work and ask them why it is done this way. I might if I remember.
  18. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Shawn,
    I bought a couple of these bulbs yesterday, and my initial impression of them is excellent.
    Instant on, 23w, 1640 lumens, 12,000 hours, and they're tiny -- around 30% smaller than the next smallest equivalent CFL. And I think they've gotten smaller recently. The box they came in proclaims that they're "Now smaller than ever". And according to my measurements, they are -- 4.375" length and 2.0" width! They easily fit in my two lamps that needed CFLs about the size of incandescents.
    They were not easy to find. Lowe's didn't have the 23w micro-mini in stock. The two Ace hardware stores I went to didn't have any of the Sylvania micro-minis. I ended up finding them at Kmart where they cost $16.49 for a two-pack :(, as opposed to the $10.99 charged by Lowe's stores and Ace Online.
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Unless the traffic hardware dates from the early 1970's I very much doubt that is the case
    Might be that way on purpose. Like how in some EU countries I've noticed on a red light, the yellow light will turn on, then the green light as the yellow and red go out. I should warn you I noticed this effect from a cafe or a bar, so perhaps my visual record isn't terribly reliable
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Yeah, right now the current LED technology for general lighting is in the Model T era. This blurb from about a year ago promises a lot of breakthroughs
    GE demonstrates first roll-to-roll OLEDs - R & D
    For general large area task and industrial lighting, induction lamps are now very hard to beat. Their instant on, instant restrike, and very long life all combine to make them very attractive
