Good option for hybrid battery replacement or too good to be true?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sewella, Jun 6, 2017.
  1. sewella
    sewella Junior Member
    Los Angeles
    2001 Prius
    I am living overseas and left my 2006 Prius with relatives. They have not been driving it regularly, so the 12-volt battery died. My aunt had it towed to her shop to get the battery replaced, and the mechanic looked at the codes and said the hybrid battery is also bad. I had been thinking to sell the car, so this puts a wrinkle in things, as does the fact that I'm not physically there to deal with this.
    The shop quoted around $2,500 to replace the hybrid battery with a new one, which isn't worth it for me, especially since I'm not planning to keep the car. I have been looking around for other options and came across a seller on eBay offering a remanufactured battery pack with a 1-year warranty for $599 plus installation. (The form won't let me post the link to the ad here, but the title is 04-09 TOYOTA PRIUS HYBRID BATTERY PACK 1 YEAR WARRANTY CALIFORNIA BUYERS ONLY! and seller is mamaleonora in case anyone wants to check it out).
    I contacted the seller to ask how much they would charge with installation, as they are in Sacramento and the car is in Santa Barbara. They said they will do it for $1,000 total. That seems like a good deal, and the seller has good reviews, but I'm wondering if it's too good to be true. Does anyone have any experience with this seller or thoughts on what I should look out for?
    I have friends who were interested in buying the car before I found out about the battery. I told them the situation and that I'm looking into replacing it with a re-manufactured battery. They said they're still interested if I do that, but obviously I don't want to screw them over by getting a replacement battery that will turn out to be a dud.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    Installing the $1,000 battery will leave the car living on borrowed time. But if you are just going to dump it then at least it will be running when you sell it.
    But don't fool yourself into thinking it will last.
    A new battery will likely last as long as the original one. (10 years) Maybe longer.
    Will the eBay one last more than a year? Hard to say. 3 years? I doubt it. 2 years? Hmm.
    I have to admit, when I saw the first part of your post saying you could get a new battery installed for $2,500 that seemed like a good deal.
    An idea if you are selling it to a friend, you could either sell as is, or offer to put $1,000 towards a replacement battery. Then they can decide if they want to fix it properly with a new battery, or take the risk of putting a rebuilt. Maybe one with a longer warranty.
  3. jerrymildred
    jerrymildred Senior Member
    11,518
    14,127
    Tampa, FL
    I think that might be a good idea, Eric! I don't like to sell cars to friends because I'm always concerned that something could break right after they get it and then there's potential for strained relationships. But, if they want to split the cost, it eases your pain and they get a brand new battery for half price, or however you split it. And I agree that $2,500 for a new one is a nice price.
    N.J.PRIUS likes this.
  4. HBS
    HBS Member
    74
    56
    MO
    I install new hv batteries in Missouri MO, Nebraska NE, Iowa IA and Kansas KS with core exchange for $2,729.
    $2729 - New 2004-2009 Generation 2 HV Hybrid OEM Battery Pack - This option includes mobile installation and a 36 month HV battery warranty.
    #4 HBS, Jun 6, 2017
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Ditto above. I'd sooner sell it to my friend for $500 - $1000 than replace the battery. You've already done the research for them. Let them decide on the repair path. For $500, I won't feel too bad if something goes wrong with the car. No one expects a $500 car to be completely reliable.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    BEFORE you spend any money on the hybrid battery, have the mechanic RESET the codes and see if they come back......and see how the car operates for a few miles.
    N.J.PRIUS and jerrymildred like this.
  7. bisco
    49,816
    if you're going to sell it to a friend, work with them on their preferred option. if you're going to dump it, go with the cheapest option you can find, and disclose the information to the buyer.
  8. JC91006
    16,500
    8,412
    Rebuilding a battery is not that hard and I can't believe the prices people charge on these things.
    jerrymildred and sewella like this.
  9. bisco
    49,816
    whatever the market will bear. same for oil and filter change.
  10. Sam Spade
    2,036
    1,023
    2017 Prius c
    For YOU maybe.
    Brain surgery is not that hard either. :whistle:
  11. sewella
    Los Angeles
    2001 Prius
    Even not running at all, I wouldn't want to sell the car for $500, since the resale value for Priuses is pretty high in California, but I see your point.
  12. ericbecky
    4,379
    3,235
    Madison, Wisconsin
    There are lots of ways to "rebuild" a battery is the problem.
    Unfortunately there isn't any standard.
    Basically there is a gold standard that I think all rebuilds should have and it deserves a high price.
    Down from there every company cuts corners to whatever is their (possibly low) standard.
    When someone says they "put a new battery" in the car, I immediately have to go into detective mode...
    What company?
    Is there a warranty?
    New buss bars?
    Cleaned buss bars?
    Correctly torqued?
    Tighten until it "feels good enough"
    Check ECU?
    Check module before replacing?
    Check all other modules in the pack?
    Replace wire frame?
    Inspect wire frame?
    Etc, etc, etc
    Raytheeagle and jerrymildred like this.
  13. bisco
    49,816
    balancing?
  14. JC91006
    16,500
    8,412
    Yes there is a "gold" standard to a battery rebuild, that should be the only standard. But should that "gold" standard cost an arm and a leg? You see $1500 - $2000+ for a rebuilt battery regularly and even for a "gold" standard rebuild, that is a very steep price for the services.
    A 10+ year old Prius does not fetch much money on the marketplace. Maybe less than $4000. That's the time when the batteries tend to fail. With a failed battery, that car goes to less than $2000.
    $1500 at a regular mechanic shop that pays rent, insurance, employees, tools, blah blah blah.....pays for lots of labor. At a regular shop rate of $75, that rebuild would equal 20 hours of labor.....
    A fair rate would charge 10 hours of shop labor to do this stuff (and nobody spends 10 hours on a rebuild). The customer would be willing to pay it and the shop still makes good money on the repair.
    m.wynn and sewella like this.
  15. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
    Sounds fair.
    If you don't mind sharing, do you get the new OEM hv batteries at Olathe Toyota in Kansas ?
    If so/not, maybe you would like to update the list below so others can know the current price and or OTC availability.
    New Traction Battery Cost: Start Shopping Here | PriusChat
  16. HughJazscheens
    HughJazscheens Junior Member
    Wow! My understanding is very different.
    Traction battery packs out of smashed cars used to be $300 on eBay, because the dealer would give you $300 to recycle it, so no one in their right mind would pay over $300. I'd call junkyards and area dealers to find a used one. They're heavy and hazardous, so having everything done in one spot is best. If they took it out, they should know how to put it back in.
    Even more important, it's my understanding that if you have a "bad battery pack" what you actually have is a single faulty cell (~$40 on eBay) in the pack. You have the faulty cell replaced, not the entire pack.
    And I would definitely go first with the advice above to reset the error code and see what happens.
    sewella likes this.
  17. HughJazscheens
    Last time I checked, traction battery packs out of smashed cars were $300 on eBay, because the dealer will give you $300 to recycle it, so no one in their right mind would pay over $300. Shipping is another matter, but it sounds like you live in SoCal.
    Next, it's my understanding that if you have a "bad battery pack" what you actually have is a single faulty cell (~$30) in the 200-cell pack. You have the faulty cell replaced, not the entire pack.
  18. HughJazscheens
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    Well that is a short term and short sighted "fix".
    All the rest of the "modules" are the same age and have seen the same service.
    When one goes bad, others are likely to follow soon.
    srellim234 likes this.
  20. tvpierce
    tvpierce Senior Member
    950
    879
    Maine
    2013 Prius v wagon
    Based on KBB, what's a fair price for the car if it was running properly right now?
    For the sake of discussion, let's say it's worth $4000 (which is probably pretty close) -- again if running properly.
    Tell you're friend's you'll sell it to them for $3000 and they replace the battery -- they'll want the warrantee in their name.
    I'd recommend to them that they go for the new battery for $2500, but it's their call. That's how I'd do it.
    sewella likes this.
