WTB Good Used rear wheel hubs
Discussion in 'Private Sales' started by Taxi/Limo, Nov 27, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Does anyone have a set of rear wheel hubs for a Generation 3 prius
    Will pay up to 100 dollars a piece
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    Be careful, there are many cheap rear hubs that may not last a year. Plus I would not buy used oem. Consider Timken or OEM.
    These parts were used on my v, a hatchback had different part numbers.
  3. Mendel Leisk
    42,343
    Is Timken Toyota’s supplier, or it’s not known for sure, but suspected?
  4. rjparker
    11,096
    6,962
    Texas Hill Country
    I can tell you the parts look identical even to the welds although they have different numbers stamped in the same font. Timkens are not cheap but better than the dealer with their markup. One rear wore out at 250k miles, changed both rear hubs and the rear pads for the first time. Had one front hub dealer changed around 50k miles with a speed sensor "foreign object" code, not worn bearing on that one.
  5. Taxi/Limo
    526
    107
    Hope someone has these even new if possible will pay more
  6. rjparker
    11,096
    6,962
    Texas Hill Country
    Do you want oem only?
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Have you tried Rock Auto yet?
    The NSKs are made by AISIN and are $95 each.
    Taxi/Limo likes this.
  8. ChapmanF
    19,019
    Hub bearing assemblies are not very good candidate parts to buy used, because that would require removing them from the vehicle where they were, and there are no easy provisions for removing them without damage to the bearings.
    Such removal would require applying force only to the stationary flange, and not applying any force through the bearing. But if you look up a sample of threads here on PriusChat by people removing these hubs, you see most often methods being used that will end or shorten the life of the bearing.
    Maybe if someone had a pair removed from an extremely clean Gen 3 used in an area that never sees road salt or damp weather.
  9. Christopher Rosanio
    Christopher Rosanio Junior Member
    17
    southwest
    I have 2 that I used for like a week, they’re TRQ brand but I’m in Tucson AZ
  10. seane7808
    seane7808 New Member
    US
    2012 Prius+ MPV
    Three Touring
    If you have one in good shape please send me a pm with pics
    TECNO BD4h ?
