Got a C1310 DTC code
Discussion in 'Gen 2 Prius Main Forum' started by dandlwelder, Dec 15, 2015.
  1. dandlwelder
    dandlwelder Junior Member
    Maryland
    OK, I finally resolved the bad skid control ECU, so I have no more codes relating to ABS sensors or pump actuator. Still get a C1310 when travelling at speeds over 60 for 10 minutes or so. After the car sits for a while, the idiot lights, triangle, ABS and brake lights disappear and the car runs fine. Except it has been whining at acceleration and deceleration a bit more than I remember. When I hooked up Tech stream, I got a P0A2B which is - Drive motor "A" temperature sensor circuit range/performance. Please tell me it isn't transaxle. Why does it only happen at high speeds? I can drive for 20-30 minutes around town without it triggering the dreaded red triangle.
  2. ChapmanF
    18,996
    If you have a code whose description is shown as a temperature sensor range or performance, that suggests that the computer is getting a temperature reading that doesn't seem reasonable. The computer by itself can't figure out whether that's because the actual temperature isn't reasonable, or something is wrong with the sensor, or with the wiring to the sensor. Its owner has to participate in checking and eliminating those possibilities. That would be you. The troubleshooting pages in the manual for that code will help.
    The time-delay effect does have me leaning slightly toward an actual overtemperature, taking a while to get that warm. Even that has various possibilities, from some inherent expensive fault deep in the tranny, to some easily remedied reduction in the cooling performance. It doesn't help much to guess, you just have to do the legwork and find out.
    -Chap
  3. dandlwelder
    Maryland
    They did replace the water pump for the hybrid drive back in June for the second time... Could an improperly bled coolant system to the hybrid drive be a cause? I paid for three day access to the manual a month ago, but when I tried to get back in on day two, it said the site was not available. Not exactly cost effective. I did print out a lot of pages for the skid control and pump actuator, but nothing for the transaxle or cooling for hybrid drive.
  4. Patrick Wong
    18,210
    6,517
    DTC C1310 is logged by the skid control ECU and means the hybrid drivetrain has a problem.
    DTC P0A2B is logged by the hybrid vehicle ECU and means one of the transaxle temperature sensors has failed. The solution is to replace the transaxle as the sensor is not field replaceable.
    Why does it take 20 minutes - maybe the sensor is providing an abnormal reading only after the transaxle heats up. Maybe the transaxle is actually overheating. If the transaxle is actually making excess noise, the latter might be the issue. Who knows.
  5. dandlwelder
    Maryland
    Well, I have been driving it on and off for a few weeks, and it would show the VSC ABS and red triangle after 20 minutes at high speed, then after stopping and a few minutes the VSC and ABS would go away and leave the red triangle. After two or three restarts the triangle would go away. Then around town it was fine, and back to the highway, the symbols would show again. Then today the same thing happened, high speed, the symbols showed up, after two starts all went away, then aftr a 2 mile drive, I pulled into the driveway and the symbols showed up, and now the car wont move. No Ready light. No codes on OBD. Have not connected the VCI/Tech Stream yet, as it is dark and cold with snow on the way. Just glad it didn't happen away from home. Oh yeah, brake lights do come on.
    SFO likes this.
  6. Megazilch0
    Megazilch0 New Member
    Bakersfield
    Hello everyone sorry to try and revive an old thread but can't seem to create a new one myself. I have a 2008 prius that I replaced thr brake actuator on and had Toyota do the brake flush on. Unfortunately, a c1310 code is on. What's strange is, after disconnecting the battery for a while, the car will run fine provided I'm not stopped for very long. Once I stop for a little bit, the red triangle shows back up. The dealer recommended replacing the ecu in order to start with the diagnosis.... Anywho, the dealer mentioned me getting p3000 and 90A1F. Thank you so much for all of your time.
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    How did you determine that there is a C1310 error?
    What device was used for diagnostics?
    If data on other errors?
    90A1F - such a code is not used. Either incorrectly written or incorrectly diagnosed.
    P3000 this error has different subcodes to determine probable problem areas and different ways to eliminate them.
  8. Megazilch0
    Bakersfield
    Thanks for replying!
    The c1310 code shows up with an innova obd reader on the abs side. The p3000 and 90A1F is what the dealership told me comes up. They may have just like wanted me to throw money at it and replace the ecu. I'm going to run techstream and see if anything more specific shows up.
  9. Megazilch0
    Bakersfield
    Oh and thanks for your help! Reassuring to know because I can't find any info on 90A1F anywhere
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Hello, and welcome to Priuschat!
    You have several codes that point to other thing(s) going on. C1310 is set in the ABS ecu when it sees that the Hybrid Control ecu has a fault. P3000 is (usually) set in the HC ecu when it sees a fault in the High Voltage battery ecu.
    P0A1F sets in the HV battery ecu when it "detects an internal fault". The only diagnostic procedure per service information is to replace the ecu. Personally, I would inspect all the connectors, terminals, and power-ground circuits before tossing an ecu at it.
    In general, a compatible used ecu (boneyard or ebay) should work fine.
    Brian1954 likes this.
  11. Megazilch0
    Bakersfield
    Super helpful! So the ecu that could potentially need replacing is the one yhat is inside the high voltage battery, right? I've seen another ecu that sits inside the of the dash and am really hoping I don't have to go messing with that.
    #11 Megazilch0, Mar 28, 2025
  12. mr_guy_mann
    4,111
    2,011
    NJ-USA
    Yes, the HV battery ecu is inside the battery case behind the rear seat.
    Here it is with some of the covers removed. It's toward the left (driver's) side of the assembly. Screenshot_20240608-125512.jpeg
