Got a new ODB2 scanner and found these CEL codes but NO CEL on dash.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Nov 3, 2022.
  1. rogerthat
    rogerthat Active Member
    387
    124
    Georgia
    Are those JDM imports reliable? I haven't seen any for close to $150. Do you have a link?
  2. Tombukt2
    Tombukt2 Senior Member
    12,987
    2,328
    Durham NC
    For the Gen 2 you will have to ask the sales guy to get you one from auris I think the JDM car is called . He will know by the first 8 of vin.. few weeks it comes . The gen3 my importer has right now each piece is 150 I think . What do I think these pieces come out of vehicles that have under generally 70K miles . Usually our troubles are starting close to 200K so I see probably a 100 plusK for 150 bux pretty decent ROI to me . Yes it could bite you in the nice person but so far it hasn't me it's yielded very decent results so I'll stick with it until it bites me enough that it makes me spend $1,000 per part and at my age that's not likely to happen I'll die before then
    51,937
    If it gets worse, eventually, you’ll need to replace it
  4. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    I was able to clear the CEL abs codes and drove 500 miles and hasn't return. So I guess those trigger after an abs event and apparently hasn't return since clearing the codes. I hope the ABS module stays healthy since the replacement video look like a nightmare for repairs.
    SM-A526U ?
    #24 Kaptainkid1, Nov 16, 2022
