Got a new to me 2015 Prius Two with a Fuel Leak Question
Discussion in 'Gen 3 Prius Technical Discussion' started by MPDano, Sep 2, 2018.
  1. MPDano
    MPDano Junior Member
    San Diego, California
    Hello all,
    Got a cracked flexible hose that enters the fuel tank from the gas filler. Anyone have a fix for this as by looking at diagrams, there is no replacement part for the just that piece of plastic hose. It looks like it is part of the fuel tank per diagram. I will post pics of the affected area.
    Much Thanks,
    Leo
  2. MPDano
  3. MPDano
    As you can see by the pics, the part does look serviceable due to the clips. Anyone know the part number for this short piece of flexible hose?
  4. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Sorry, can't help with the part number. Two thoughts. 1 -- Is it a single wall pipe to the fuel tank? If so, you must be getting a CEL as the tank is not venting correctly ..... would this not be covered under the 10/150k emissions warranty? 2 -- If the pipe does disconnect -- a salvage yard is the place to go. I would get some sort of epoxy .. or sealing tape to close it up before fixed properly (if not covered by warranty)
  5. MPDano
    Interesting as I thought the Prius was out of any warranty. Do you have a link where it shows such coverage? It's got 72k on the odometer. Yes, single walled. Also, yes got a couple codes relating to evap. I sealed it temporarily to try and rid the codes so I can get it smogged.
  6. Tande
    Tande Active Member
    525
    310
    Mich.
    Any chance this 77201-47220 is it?? ........
  7. MPDano
    Nope, that is actually the filler side. I need the small host that connects your part to the tank
  8. MPDano
    I have a feeling it's only going to be sold with the tank.
    Part Number: 7700147110
  9. Tande
    Tande Active Member
    525
    310
    Mich.
    Well, darn/it! .......
  10. Mendel Leisk
    40,586
    Check with a service department. Yeah I know, the expense. But maybe they can get it up on the hoist, assess it, talk with parts, for under $100. There has to be a sub-assembly, just that hose: it is completely onerous to replace the entire gas tank.
    Tande likes this.
  11. Mendel Leisk
    40,586
    On page "3052" of this Repair Manual excerpt (attached), there's instruction on removing the hose clamps, and on page "3057" the install. Some screen grabs:
    Note in the illustrations there appears to be an insulated covering; ours looks like that too.
    If it turns out be impossible to get that hose, maybe you can even find an aftermarket replacement hose, approved for use as fuel line? It seems absurd, for a hose that is clamped on, to considered part of the gas tank assembly.
    #11 Mendel Leisk, Sep 5, 2018
  12. MPDano
    Yeah, fully get it as far as buying a whole tank. The hose is easy to get to and I do know that part to the filler disconnects easily, it's the tank side that is questionable.
  13. DrElectron
    DrElectron Junior Member
    NC, USA
    I think I have the same leak in my 2012 Prius V. For my car the hose is 77213-47090.
