Got a screw on tire, will Toyo cover it?
Discussion in 'Prime Main Forum (2017-2022)' started by Roy2001, May 5, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    The car is less than 3 month old, will Toyo or Toyota dealer repair it for free?
    UPDATE:
    It was 5:45pm, all the tire store closed at 5pm. I was very close to America's Tire but they only open on Monday. Called Walmart and they are not going to fix it until tomorrow.
    Decided to go home slowly, but downhill the speed went up to 50mph and the screw flew away. I had to stop at the roadside on the freeway.
    Fortunately, that was 3 miles away from home. Called wife to ask her to bring the spare tire to me. Went home with the spare tire I bought when I got the Prime 3 months ago. I paid $40 from a junkyard. It is from a 2010 Prius.
    I guess the repair kit should be able to fix it, but if it is a sidewall scratch then a sparetire is a must.
    #1 Roy2001, May 5, 2018
    49,511
    :mad:nope.:unsure:
    jrodz09 likes this.
  3. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Nope never, Unless you have a really nice dealer;)
    fuzzy1 and jrodz09 like this.
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    Looks like you’re “screwed.”
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    jerrymildred, qettyz, scona and 5 others like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I bet he’s here all week :rolleyes:.
    jerrymildred, scona, huskers and 2 others like this.
  7. Bluebells2
    Bluebells2 Junior Member
    46
    Silver Spring, MD
    Not unless you have the add on tire maintenance. My tire blew when I bought the car with a license tag screw from the dealer in less than 6 hours....nope they will not!
  8. Mendel Leisk
    38,741
    Nope. Maybe I'm living dangerously, but I would just take that wheel off, and plug-repair, through the outside, and air them up with a bicycle pump.
    I've got one OEM tire that had a finishing nail in the tread, and one snow tire that had a bolt similar to your picture. I plug repaired them both 4~5 years back, no further problems.
    Getting professional repair is not that expensive, maybe $20~30 BUT, if it's within an inch of the tread edge they may refuse. The pros now tend to use an inside plug, that is more secure, but can't be used close to the edge of tread. That was the scenario that tipped me to procure an old-school plug repair kit.
    I went with BlackJack kit; there's lots of good names though.
    #8 Mendel Leisk, May 5, 2018
    fuzzy1, Kurt Weiske and jerrymildred like this.
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    And don't forget to tip your waitress.
    PGHtoolman and Raytheeagle like this.
  10. Washingtonian
    Washingtonian Senior Member
    716
    617
    I had a small nail in mine. Took it off, took it to Costco and they repaired it for $11. with a plug. Seems to be fine now.
  11. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I'll see you taking tire off and taking it to Costco offer to Calling AAA and having tow truck put my car on the tow truck bed then driving to the nearest Belle Tire and Belle Tire charging me a grand total of $10.00:D
    benagi likes this.
  12. Mendel Leisk
    38,741
    Yeah but you miss out on all the DIY fun? :confused:
    priuscatprimeguy likes this.
  13. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    When you replace that set of tyres, buy them from a shop that will repair free, rotate free, etc. Like here in western Canada, Kal TIre. Or is that Kal Tyre? ;)
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Like the "donut" spares, the "repair kit" is intended ONLY as a temporary, emergency measure.
    It is NOT intended as a permanent fix.
    P.S. Using it to get home probably would have been a LOT easier and quicker than changing the tire.
  15. bwilson4web
    15,527
    You might pay a little more for a Firestone repair but I know they take the tire off and put a patch on the inside.
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    If wishes were horses, beggars would ride.......
  17. AnneLW
    AnneLW Member
    118
    95
    California desert
    I got "screwed" yesterday, too!
    I a remote part of Arizona, 200 miles from home. I was able to pump it up at a gas station jst enough to limp to a Big O Tires j1/2 hour before they closed, and had to pay $22 for a repair.
    I thought I had an air pump in the car, but I just had the dealer kti which I hope to never use; I'm told that stuff will also mess up the tire pressure sensor.
    NOW, I have an air pump in the car.
  18. Oniki
    Oniki Active Member
    652
    499
    Colorado
    Bad choice. Expect to be told that your tyre is trashed.
    Next time stop as soon as it is safe and use the repair kit
  19. Oniki
    Oniki Active Member
    652
    499
    Colorado
    I've read that internet crap too, but it most certainly does not apply to the goo our kit contains. A much more certain risk is damaging your tyre from driving on it with inadequate inflation.
  20. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    It seems we are beta A testing these prii with no spares.
    Until the tires that are flawless are introduced.
