Got my first prius 2001
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Aug 7, 2012.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Be very careful. I assume you've read my previous posts about how hard it is to take off without damaging it. You will almost certainly damage it no matter how careful you are. As I said, I was extremely careful and I used trim removal tools. I still broke 3 tabs. I was able to glue them back on however and they did hold (and are still holding).
  3. scotman27
    735
    82
    PA
    2001 Prius
    Ok, i will be care full, i think it already has a hairline crack in it from the seller or the previous owner. so careful is shall be.
  4. bwilson4web
    16,535
    Let me suggest it may not be a question of "if" it cracks but rather "when" it cracks and be prepared for the repair.
    If I decide to go in the dash again, I'll have some stiff, music wire and hand tools to form a wire version of the plastic 'pins' that hold the facia. The tech who installed the FM encoder used a cheap soldering iron as a plastic welder and it worked. However, I'm not fond of breathing plastic fumes since some can be toxic and pose other health risks.
  5. scotman27
    735
    82
    PA
    2001 Prius
    I agree, which I did break a couple of the plastic clips. I used some epoxy on the back of the fascia to reinforce where the crack is. Now I just need a littl time to epoxy the clips back together and the one screw holder for the radio. Right now i just have the radio unit bolted to the car and the fascia is being held by the screws on the bottom where the cd player would be and the clips
  6. scotman27
    735
    82
    PA
    2001 Prius
    I think i am going to go with blue leds. I think that will look ok on a silver car. has anyone ever changed the color of the dash where the mph is displayed?
  7. scotman27
    735
    82
    PA
    2001 Prius
    Bought some devcon plastic welder epoxy for the fascia, this stuff I used in the truck shop where i worked, excellent stuff. I rebuilt screw holes in the dashes of the sterling trucks because the guys would put their feet against the dash and break the fuse cluster holes on the passenger side, so I used this and as of today I believe it still is holding and thats over 2 yrs! I think a prius fascia will not be a problem lol.
    bwilson4web likes this.
  8. scotman27
    735
    82
    PA
    2001 Prius
    Here is the link to the stuff I bought, found it on Ebay: THis is the clear stuff, i got the cream color since that is what I used.
    ANYONE WHO HAS BROKEN THEIR 01-03 PRIUS FASCIA DASH, USE THIS TO REPAIR THE BROKEN FASCIA.
    ITW Consumer/ Devcon S-220 Plastic Welder | eBay
  9. scotman27
    735
    82
    PA
    2001 Prius
    Someone mentioned on another site about putting a switch in to cut power to the fuel injectors so the ICE would just spin without fuel so mg1 would not over rev. is this something I could do. I figure I would get an engine code but I would be running on electric and if I came upon any hills I would flip the switch and ICE would run normally. or if the battery would become discharged. this would only be for flat surfaces or cruising under 45 mph since most of my drive is 35-45 mph. highways, hills, pulling out on hills would be an ICE job.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    Here's an excellent example of what I mentioned in a previous post. When you try to mess with the Prius, you end up causing more problems that have to be addressed. If you cut out the injectors, you will get a Christmas tree of lights but beyond that, it is not as easy as flipping a switch and the engine starts up and you roll on. In order for the engine to start up, you will need to turn the car completely off and then back on. Your codes will remain on for 4-5 cycles of the key (assuming you don't turn off the injectors again). Additionally, you will only be able to go about .75 - 1.5 miles (depending on speed) before the battery is completely discharged. Then once you do turn on the ICE, it will race to charge the depleted battery thereby negating all mpg gains achieved by turning it off. Your next thought will be to add more battery power, then you have to modify the battery ECU, then you'll need to mod something else.
    The Prius is an extremely well engineered car (even a Gen I is amazing). Tinkering with one part of it will cause a problem with another part which will in turn cause a problem with another part. About the only mod I've ever seen that was straightforward is ccdisce's ECT spoofer (which fools the computer into thinking the ICE is warmed up sooner than it really is). It will net you nearly the same mpg's in the winter as in the summer (assuming no AC or heater usage). Most of us want to mod our Prius when we first get it to squeeze out even more mpgs but the reality is, the engineers that designed it squeezed out all they could. The fact of the matter there is no simple/cheap way to do this.
    My humble advice to anyone thinking about doing things like this is "most likely its already been tried, it will cause other problems that you will chase like a rabbit, it will be a money pit and, you'll probably end up going back to a stock setup after all is said and done". Their will, of course, be exceptions.
  11. scotman27
    735
    82
    PA
    2001 Prius
    That is exactly why I joined this forum. I need all the help I can get. I would have most likely tried this and would of been disappointed or broke something. So what are these guy s in Japan doing to get these things to 100mpg, cant be easy and has to be expensive
  12. scotman27
    735
    82
    PA
    2001 Prius
    I need to replace my muffler on my prius, no big deal but, im pretty good at fabricating. is there anyone here that has put a muffler on that helped mpgs or am I better to just stick with a stock muffler. either way its got to be replaced. thank you
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    The 100mpg claims are exaggerated or there is a very narrow driving style that will allow for it. To achieve 100mpgs on any Prius you will need to plug it in (minimum $3500 investment for any worthwhile gain). On top of that, you'll need an ECT spoofer, a Scangage and probably an EV switch (another $260). Then you'll have to learn how to drive it to achieve that mileage (plug it in at work, take back roads, monitor displays etc (doesn't sound hard but gets old). Additionally, the 100+mpg does not account for electricity use or eMPG. If accounted for, virtually no one is achieving over 100mpg's.
    Judging from my experience and what I've read, extremely high mpgs are achieved on desolate roads with slow speed limits (who wants to go slow on a desolate road).
    I know of no muffler that will improve mpgs on any car. You can go with stock or aftermarket. It doesn't matter.
  14. scotman27
    735
    82
    PA
    2001 Prius
    I didn't know if mufflers affected these cars our not. Never did on my other cars, but hey I never had a hybrid so I figured I would ask. I also was not sure of the 100mpg claims either, I figured expense, and/or Alot of modding was necessary to achieve it. Thank you for you're feed back guys
