Got New Prius today.. what should i add?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by alfa737, Sep 9, 2011.
  1. alfa737
    alfa737 Member
    126
    27
  2. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    I would recommend a scanguage. You can customize it to fit your own needs. It is very useful and I think it helps me get better mpg.
    orenji likes this.
  3. alfa737
    alfa737 Member
    126
    27
    whats a scanguage and more important, what dose it do?:confused:
  4. Silver bullit
    608
    211
    Here is a video giving some info about it. [ame="http://www.youtube.com/watch?v=l-5cr-WlOPs"]Scangauge Installation and use video - YouTube[/ame]
    You can also search priuschat for "scanguage" as there are many people here who are much more knowledgable than me. It is available at the priuschat store, amazon, and the scanguage website. I have mine setup to show rpm, coolant temp, battery voltage, and mpg. Good luck!
  5. Eodguy
    Eodguy Junior Member
    Seattle
    First thing is to make sure it is all up to date on Maintenance.
    1. Change the oil
    2. Change engine coolant
    3. Change inverter coolant
    4. Change spark plugs
    5. Change air filter
    6. Change cabin filter
    7. Change CVT oil
    8. Clean out the EGR pipe
    9. Clean the hybrid battery fan.
    There are Youtube videos that show you how to do all of this and not one thing I listed is complicated. The only tools you need are a screwdriver, 10mm, 12mm 14mm socket. Special oil filter tool and 10mm hex wrench.
    When you finish with that list.
    1. sound insulate your doors, hatch area, floors and headliner.
    orenji, wastoooo and CoastRider like this.
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I have to believe the OP's Prius has 60-70,000 more miles on the odometer since starting this thread.
    Mendel Leisk, wastoooo and CoastRider like this.
  7. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Weird how u guys says the car doesn't accelerate quicker.. When it comes to Norwgian priuses that's not the case, it's a BIG difference between power and Eco.... Put the pedal down in Eco or in normal won't be the same effect as in power...
    Maybe what u should do first is put in a K&N filter and take of the resonator, makes a difference in throttle response. If u wanna make a "engine mod" first tho.
    I've been screwing around in the interior, adding front camera, do small things in the interior as changing the blue gearstick to the black one from the auris hybrid, change to LED lights in the interior.
    Buy a smarttap relay so u can change warning light patters, tap to blink, arrival and departure lights.
  8. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    The main mods u need with out going over board is:
    Tint
    Hids
    Lowering springs
    Max Taiwan and Burna J like this.
  9. Grandma Prius
    Grandma Prius Junior Member
    Cincinnati
    I purchased a scangauge ll to keep a eye on water temp, rpm, since the Prius has no tachometer, or temp gauge. Replaced all interior lights with led bulbs. I drive mine in eco mode on the hiway seems to cruise better for me. Use power mode if needed on highway ramps, but typically leave it in eco mode.
    James Powers likes this.
  10. MagnusAG99
    673
    521
    Norway
    Ive actually heard having it in ECO mode makes it use more fuel then in Normal mode lol. Even tho it only changes throttle response and nothing more.
  11. Mendel Leisk
    42,326
    The "today" in the title was about seven years ago lol.
