Got Prius 2010, worth Upgrade to PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by inferno, Jun 24, 2013.
  1. inferno
    inferno Senior Member
    1,072
    405
    Your thoughts? I love the 2010, get like 40-45mpg in the winter, and usually 48-54mpg in the summer. The Prius Plugin is 4k more than my car (after rebate before tax incentives - how long are they going to last?) and has less cargo space since those batteries in the back.
    I can only charge at home.
    Is it worth upgrading considering it's the same car otherwise? Do you get better mpg because of the better bigger battery pack? I'm curious because right now on several rides my regen breaks actually fills the batteries and I'm wondering if I can do that with the PiP, but have it last longer on electric?
    Another thing...a guy at the dealership told me the electric won't turn on unless it's fully charged? What kind of BS is that if that's any? I was disappointed.
    But it seems like these car salesmen are really becoming dated, they don't know diddly squat about features, hybrids and especially plugins. I'm getting conflicting information on a lot of the hybrids (they don't even know the mpg off hand). Are people just not economical these days so the salesmen don't care?
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    Clueless sales rep. You can charge as little or as much as works in your situation.
  3. Gruvin2
    Gruvin2 Junior Member
    45
    16
    Baltimore, MD
    I went from a 2010 Prius to the PiP and couldn't be happier. You get heated seats/Nav/backup cam standard and better mpg even after the battery is depleted. I get on average 4-8 better mpg AFTER the battery is used up. The PiP acts just like a standard Pruis when the EV range is done but with better regen while driving. I only charge at home myself. My commute is 9.1-18.3mi 1 way depending on the day. Your battery does not need to be fully charged to use.
    Beshara1111 and JMD like this.
  4. inferno
    1,072
    405
    Is it possible to fill your ev battery by regen breaking instead of plugin? I saw this weird video that showed the EV distance, then the battery went down to none and it went full again and basically showed the regular Hybrid Battery Screen?
    These cars are getting complex lol.
    I guess I'm trying to see the economical benefits, I don't want to lose anything that I have in my current Prius.
    But 4k rebate, my Prius is worth 15-16k (was assessed) 0% interest now for the PiP and a tax credit as well...I'm kind of tempted ;) Very Kind of. Two things holding me back - no jack/tire, less space in the back because you can't lift up the secret compartment, AND the Prius V for my family - I don't want to go Sienna, engines tried and true but I can't go less than half in fuel economy after I went hybrid!
  5. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I traded in my 2012 Prius Five for the PIP Base when Toyota came out with the $5k finance credit last year. I also got the $2500 fed refund and my local electric utility gave me a $500 rebate check for the PIP.
    I get free charging at work 5 days a week- so that helps too.
    Stats FWIW- (I drive about 1400 to 1500 mi/month average):
    -2012 Prius Five avg mpg per month (over the six months I owned it): 50.3mpg
    -2012 PIP mpg: April 2013- 95mpg, May 2013- 96mpg, June 2013 (as of 6/24) 99mpg.
    -Home electric utility bill increased about $18/month since I got the PIP (22 cents/KwH here)
    -2012 Prius Five- had to gas up once every 1.5 weeks
    -2012 PIP- gas up every three weeks
    -2012 Prius Five- saw as low as 29mpg on short weekend trips due to ICE warm-up cycle
    -2012 PIP- can go most weekends without ever starting up the ICE
    Average daily commute to work then back home- 56mi total x 5 days a week. Average about 30+ miles of weekend driving consisting of mostly short 5-10 mi trips.
    Beshara1111 likes this.
  6. inferno
    1,072
    405
    I didn't know electric companies had rebates as well? The $18/month increase is interesting as it leads me to some math here:
    My Prius 2010 has about the same stats as your 2012 Five, so let's say gas is on average $3.50 - and you fill 10 gallons (I'm constantly able to get to that), that's $35, filled twice a month that's $70
    Your PiP seems to be double efficient, so that's $35+$18 = $53 - so you save yourself about $17 a month (1 gas fill in two months about)
    Now...this is you charging at work also? I guess the ultimate would be using those public free stations and have some sort of solar at home.
    Anyone know how these LithIon batteries are in cars? They are tried and true and laptops so are the Nickle Cadmium ones, and I still see 2001 1st gen prii driving around lol
  7. ny_rob
    1,968
    814
    L.I.- NY
    Yeah, that's how it works-
    Even though they're not- think of them as two separate batteries in the PIP- one for the EV (up to 64mph use) and one for HV use (up to 42mph). When you plug in for recharge it charges both (even though it's just really one large 4.4kw LIon battery) batts- once you deplete the EV portion of the batt, the display switches to a graph of the HV portion of the battery which is still full once the EV portion is exhausted. Now the PIP acts more like the regular Prius- you have to keep under 42mph to prevent the ICE from starting- and even if the HV portion of the batt is full- excessive pressure on the accelerator will call for more power than the HV batt can supply and the ICE will start up.
    If your EV batt is depleted and you're heading to a long downhill road- regen braking will first recharge the HV batt portion all the way- then it will recharge the EV portion as well. But due to the larger capacity of EV batt- it's very rare to get a decent charge to the EV from regen braking.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I upgraded from a 2010 solar to a 2012 plug-in.
    On days when I only recharge at home, the MPG average for my round-trip commute (34 miles) in non-winter temps is in the 80's. When I also recharge at work, it's well over 100. There's a clear efficiency improvement for commutes.
    Running errands around town, the improvement is profound. Suburb driving is all eletric. It's great! No more short-trip penalty.
  9. ny_rob
    1,968
    814
    L.I.- NY
    I didn't know our Electric Co had that rebate either- till I read a forum post here. That post got me an extra $500!
    The PIP gas tank is a bit smaller than the regular Prius tank- My last fillup was 8.6 gal, $32 at $3.71/gal. The gas gauge was on the last pip- but it wasn't blinking yet. 8.5-9 gallons is average fillup for PIP drivers.
    Yes- there's a free ChargePoint station across the parking lot from my job. That was a major consideration in purchasing the PIP.
    Well in most states- the PIP battery comes with a 100'000 mi warranty. If you live in a CARB state (like NY) you get a 150'000 mi warranty on the battery!
  10. ny_rob
    1,968
    814
    L.I.- NY
    I used to dread the weekend hit to my monthly mpg in the Prius- with the PIP I now look forward to an all-electric weekend that boosts my monthly MPG stats. I went into this weekend with a 97mpg monthly stat- this morning I'm at 99mpg for the month thanks to may Sat and Sunday errands.
    Love the all-electric weekends in the PIP!
  11. CharlesH
    2,798
    1,166
    Roseville, CA
    You don't see NiCd batteries much any more; maybe in cordless shavers and electric toothbrushes, but that is about it. Things are at least NiMH, if not LiIon.
    BTW, the Gen 1 Prius was NiMH, like the current standard Prius. Just sold my 2002 this year.
  12. bisco
    52,911
    how far is your commute? you won't get much regen unless you're going down some serious hills.
    Frank Perkins likes this.
  13. inferno
    1,072
    405
    My commute is 90 miles on one day and perhaps 20 on others (have to go to the main office). I can do this at 53 mpg in my regular Prius. The 20 on the other days get knocked down to like 46 or so. I go through mountains and large hills, so I actually end up with a full battery bar a couple times on the trips.
    Another question, anyone have flat tire anxiety with your PiP? Any horror stories? My trip involves a few cell deadspots...
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    I use a dount spare that I got from the local junk yard for $35 and a plug kit just when I leave on trips out of town.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Most of my driving is in town short trips, 8-15 miles round trip, works really well for me. I do go out of town 4-5 times a year for a 500 mile round trip. My mileage is really nice due to all the in town short trips. Your trips are just the opposite. You still should get good MPG as john 1701a has shown. Also check out his web site, great stuff to see and read. John's Stuff - Toyota Prius and more :)
  16. bisco
    52,911
    you're describing a commute that could be very advantageous with a pip. i have no experience with large hills, my biggest gives me .3 miles in regen. i also have a used donut i throw in when going far enough from home that i on't want to call toyotacare and get towed. the goop kit is a nightmare if you watch the video. btw, a new donut with tire is almost $500.
  17. markabele
    5,084
    1,782
    Nebraska
    What is the split of 90 miles commutes compared to 20? If 90 are the majority then the pip won't save you much on those. And how often do you do errands within 5-10 miles of your home?
    I forget, did you say you can charge at work?
  18. inferno
    1,072
    405
    Thanks guys, I appreciate it.
    It's actually 180 miles one day (round trip) and the 2010 Prius does well. Every day it's like 20 miles TOTAL for that day. So are you saying it wouldn't be to my advantage on that long trip?
    I can't charge at work either :( So...lol...
    Anyone use plugshare for those long trips? I might wait, keep my 2010 and see what the 4th gen bring, it's just a year or two away right?
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Sure you will see an advantage just not as much. I would think maybe 57-60 MPG depends about type of drive and speed. My 500 mile round trip to my brothers house mostly interstate rolling hills was 60MPG next round trip was 69.3MPG mostly 64-69 MPH. I did leave with a full charge and charged at my brothers house. Temps. 70-85 drgrees f.
    You will do really well on your short trips! :)
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    We are all hopeing for some nice changes in 2015 model. Only Toyota really knows what the changes will really be!
    Maybe more electric, better mileage, ect. We will see. :)
