got some young 2012 modules
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Apr 10, 2014.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    The others got done this morning numbers are just shy of 6000mah
    so i bumped the mah up to 7250mah and started the next set. ill come back to these at the end of the rebalancing.
    Module 9: D1:2353 C1:6800 D2:5842 C2:6800
    Module 10: D1:2380 C1:6800 D2:5973 C2:6800
    Module 12: D1:2830 C1:6800 D2:5915 C2:6800
    Module 13: D1:2621 C1:6800 D2:5907 C2:6800
    If the next set doesnt seem to balance out, ill have to bump it up to 7500mah, but i think things will be ok at 7250.
  2. bwilson4web
    16,533
    Works for me.
    I only had abused modules from failed or well worn packs. You've got much better inventory than I ever had.
    GOOD LUCK!
    scotman27 likes this.
  3. scotman27
    735
    82
    PA
    2001 Prius
    Thank you, ill have some numbers up here shortly. Just got home from work.
    Samsung galaxy precedent
  4. scotman27
    735
    82
    PA
    2001 Prius
    i still think with only 7 to 9000 miles on them, they should be at or above 6500 mah.
  5. scotman27
    735
    82
    PA
    2001 Prius
    ok here are some numbers, module 16 done previously
    Module 14: D1:2648 C1:7250 D2:6027 C2:7250
    Module 15: D1:2549 C1:7250 D2:6122 C2:7250
    Module 17: D1:2577 C1:7250 D2:6079 C2:7250
    Module 18: D1:2554 C1:7250 D2:6044 C2:7250
    so far so good, i think ill hold my charge mah at 7250.
    bwilson4web likes this.
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    From the looks of it, you're gonna have a damn good pack when all of this is said and done!!!! :)
  7. scotman27
    735
    82
    PA
    2001 Prius
    thats what im hoping for.
    the only thing that concerns me is that they are below the 6.5ahr rating.
    ive read that modules should be cycled at least 3 times. ive been doing these only twice, at the end of this, should i go back and do a cycle of 2 again or match them up and get them ready to be placed into the car?
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    Your doing fine. I would keep on keeping on. Then take the data and match them up the best I can. All the modules are virtually the same. As for the 6.5 ah rating, modules begin to lose capacity right away so yours look really good.
  9. scotman27
    735
    82
    PA
    2001 Prius
    Ok great, i just want to make sure im doing this right the first time. the ones im going back and doing again is module 38 because that has 5155 ahr and the four i ran at 6800 mah charge.
  10. scotman27
    735
    82
    PA
    2001 Prius
    Next set done, gonna have to go back later and run another 2 cycles i want to see at least 6ahr ill be happy happy happy.
    not like im happy with what im seeing and hearing already.
    Module 20: D1:2564 C1:7250 D2:5906 C2:7250
    Module 21: D1:2601 C1:7250 D2:5936 C2:7250
    Module 22: D1:2608 C1:7250 D2:5893 C2:7250
    Module 23: D1:2519 C1:7250 D2:5949 C2:7250
  11. scotman27
    735
    82
    PA
    2001 Prius
    ok i got one here that got done way before the others
    module 25 D1: 2591 C1:4662 D2:4367 C2:4388
    what do I make of this. seems to me it hit delta peak.
    module 38 did the same thing
    how come I only got two out the whole pack to hit delta peak and the rest took the whole 7250 mah?
    Is this a good thing?
    to me it seems as though it wont take the 6.5ahr charge its supposed to take, if anything it looks like it took less mah the second time around, however, it almost takes the same mah out on discharge. is this module and module 38 bad?
    module 38 read:
    Module 38: D1:3803 C1:4272 D2:4122 C2:3880 D3:3830 C3:4206
  12. bwilson4web
    16,533
    My speculation is the lower capacity of these weaker modules puts them in the set charger amp range so the dV/dt is detected. But the other modules are so strong the amps are too low to trigger a strong dV/dt.
  13. scotman27
    735
    82
    PA
    2001 Prius
    so what would you suggest I do with the modules that do that? replace them, recycle them again through 2 more cycles at a lower charging amps?
    I figure that's the reason I'm getting such low discharge mah is because the charger is detecting a peak and not putting in the full 7250 mah that I have it set to cut off at. now I could on my charger turn off the Delta peak cut off and have the charger shut off charging the module solely at 7250 mah
  14. scotman27
    735
    82
    PA
    2001 Prius
    just got home from work here are some numbers, again module 25, should i : replace it, cycle it again in a couple days, or turn off delta peak and just charge it till it hits the 7250mah cutoff then discharge and see what I get.
    Module 24: D1:2527 C1:7250 D2:6131 C2:7250
    Module 25: D1:2591 C1:4662 D2:4367 C2:4388
    Module 26: D1:2584 C1:7250 D2:6153 C2:7250
    Module 27: D1:2547 C1:7250 D2:6100 C2:7250
  15. scotman27
    735
    82
    PA
    2001 Prius
    just checked on my modules already module 29 has peaked out. at 4000 something mah. its on discharge now, ill see what materializes out of it. i dont think theses ones that are peaking out are weak, i dont know what to make of it.
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Hmmm, I would try to turn off the Dv/Dt on one of them for one charge/discharge cycle. I would monitor it closely and I would stop at the top and observe the module for self discharge.
  17. scotman27
    735
    82
    PA
    2001 Prius
    i agree with that. ill let it finish up then ill record numbers. as the others are discharging or what not. ill charge it and then run i 1 discharge charge cycle and see what it does. barring that the other modules are not close to ending all their cycling, if they are, ill wait and go back when all testing is done.
  18. scotman27
    735
    82
    PA
    2001 Prius
    the only thing thats been bothering me is ive been doing alot of reading and it seems as if almost everybody has done or is doing at least 3 cycles on their modules where i have only done 2 cycles on them. should I go back and run 2 more cycles on this whole pack?
  19. scotman27
    735
    82
    PA
    2001 Prius
    right now ill be going back when this is done and running 2 cycles on modules 1,9,10,12,13,20,21,22,23,38, and now 29
  20. scotman27
    735
    82
    PA
    2001 Prius
    i just checked my charger, i had the charge rate bumped up to 2amps charge, could that higher charge rate be causing certain modules to peak?
