got some young 2012 modules
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Apr 10, 2014.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    The computer looks for voltage and not capacity. That's why it so critical to hook up all modules in parallel for about 4-8 hour prior to assy (I would recommend 8). And... the computer is looking for a voltage difference of greater than .3v before it throws a code. I doubt you will see a variance greater than .15 with those matched capacities.
  2. bwilson4web
    16,533
    Since the Prius sees only module pairs, it won't even see individual modules. Also, we do peak charge and very low discharge to measure capacity which is not normal Prius charge and discharge levels.
    As others have pointed out, the 40-80% range is key to long life.
  3. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    Ok so that little but of mah difference won't hurt it.
    now what about pairing these.
    Question 1: Should I do what usnavy suggests and add up capacities then divide by 38 and pair them closest to that number or should I just pair highest capacity and lowest capacity together.
    Question 2: will it matter which modules are in the Middle or on the outside?
    Samsung galaxy precedent
  4. bwilson4web
    16,533
    Highest and lowest together so they 'average out' for the 19 sense lines of the traction battery controller.
    Put the strongest pairs in the middle of the pack and weakest pairs on the end. We have seen a pattern of module failures in the middle where the heat accumulates. Putting the strongest there means their extra capacity delays the eventual pack failure(*). The weakest on the ends ensures they get the most benign environment.
    * - I know that "heat is the enemy." It is possible to conservatively drive our 2001-03 Prius, the NHW11 model, in such as way that the traction battery temperatures and internal module pressures never stress the terminal seals, the weakest part of the traction battery. But this requires keeping ordinary speeds at 65 mph and below and climbing tall hills at a speed so the traction battery is NOT providing additional energy. These are achievable objectives BUT like Casandra, I know it will be ignored.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Hey Bob,
    I'm having a hard time understanding something here. If you pair the strongest modules with the weakest modules, how will it be possible to put the strongest in the middle and the weakest at the ends? Do you see what I'm saying?
  6. bwilson4web
    16,533
    You can either sum the two and use that number to rank the pair. Alternatively, you can average the pair and use that number (turns out both operations will give the same ranking of pair strength.) Let me give an example:
    • 6,500 mAhr
    • 6,400 mAhr
    • 6,300 mAhr
    • 6,100 mAhr
    So pairing strong and weak:
    • 6,500 + 6,100 -> 12,600 / 2 -> 6,300 mAhr :: goes on either end
    • 6,400 + 6,300 -> 12,700 / 2 -> 6,350 mAhr :: goes in middle
    The divide by "2" does not change the ranking of the pair as strong or weak.
    The pairing rule, strongest with weakest, means the voltage swing as the pack charges or discharges for that pair will appear to the traction battery controller to have a similar swing as a less-strong, and less-weak pair (I know the English reads confusing but it is how my mind works.)
    Once the pairs are made, we treat them as a module assembly and rank them so the strongest ones are in the middle where the heat stress is the largest. The weaker ones are on the end where they have more cooling because they are not sandwiched between a bunch of module pairs.
    usnavystgc likes this.
  7. scotman27
    735
    82
    PA
    2001 Prius
    Ok so right now Im waiting on module one to finish charging and that will be complete. and the pack will be done. Here are my final numbers if you both agree the pack is ready for me to install tomorrow. I will await your answer and if you both agree for me to install, i will put the pack in parallel and let it sit for a couple hours. hopefully ill hear from you before tomorrow afternoon. if its afternoon i wont have time as ill need the car in the evening.
    Here are the possible final numbers, once module 1 gets done ill post that. its charging now
    Module 1: D2:5990
    Module 2: D2:6093
    Module 3: D2:6070
    Module 4: D2:6076
    Module 5: D2:6124
    Module 6: D2:6227
    Module 7: D2:6135
    Module 8: D2:6092
    Module 9: D2:6344
    Module 10: D2:6414
    Module 11: D2:6094
    Module 12: D2:6373
    Module 13: D2:6358
    Module 14: D2:6027
    Module 15: D2:6122
    Module 16: D2:6299
    Module 17: D2:6079
    Module 18: D2:6044
    Module 19: D2:6238
    Module 20: D2:6483
    Module 21: D2:6407
    Module 22: D2:6479
    Module 23: D2:6405
    Module 24: D2:6131
    Module 25: D2:6282
    Module 26: D2:6153
    Module 27: D2:6100
    Module 28: D2:6160
    Module 29: D2:6274
    Module 30: D2:6203
    Module 31: D2:6152
    Module 32: D2:6359
    Module 33: D2:6326
    Module 34: D2:6408
    Module 35: D2:6346
    Module 36: D2:6207
    Module 37: D2:6248
    Module 38: D2:6336
    Let me know if i should assemble or cycle the ones that are not above 6100 mah.
  8. bwilson4web
    16,533
    Suggested ordering:
    Column 1
    0 [tr][th]new pair[th]mod A[th]mod B[th]pair capacity
    1 [tr][td2]1[td2]26[td2]29[td2]6213.5
    2 [tr][td2]2[td2]31[td2]25[td2]6217.0
    3 [tr][td2]3[td2]30[td2]19[td2]6220.5
    4 [tr][td2]4[td2]2[td2]32[td2]6226.0
    5 [tr][td2]5[td2]24[td2]33[td2]6228.5
    6 [tr][td2]6[td2]5[td2]38[td2]6230.0
    7 [tr][td2]7[td2]15[td2]9[td2]6233.0
    8 [tr][td2]8[td2]3[td2]34[td2]6239.0
    9 [tr][td2]9[td2]17[td2]23[td2]6242.0
    10 [tr][td2]10[td2]14[td2]22[td2]6253.0
    11 [tr][td2]11[td2]4[td2]21[td2]6241.5
    12 [tr][td2]12[td2]1[td2]20[td2]6236.5
    13 [tr][td2]13[td2]8[td2]12[td2]6232.5
    14 [tr][td2]14[td2]18[td2]10[td2]6229.0
    15 [tr][td2]15[td2]11[td2]13[td2]6226.0
    16 [tr][td2]16[td2]27[td2]35[td2]6223.0
    17 [tr][td2]17[td2]36[td2]6[td2]6217.0
    18 [tr][td2]18[td2]7[td2]16[td2]6217.0
    19 [tr][td2]19[td2]28[td2]37[td2]6204.0
    This ordering achieves:
    • within a pair, strongest and weakest - to make balanced pairs
    • ordered pairs, strongest in middle and weakest on each end - weakest on coolest ends
    Before rebuilding the pack, benchmark the car with the existing pack:
    run 10 miles, two-passes, at a cruise control set speed between 35-40 mph​
    record outside air temperature, midnight to 4AM is an excellent test time​
    Don't forget to parallel balance all modules to a common 8V limit.
    After installing the rebuilt pack, benchmark the car with the new pack:
    run 10 miles, two-passes, at a cruise control set speed same as the first set​
    try to run when the outside air temperature is within +/- 5 degrees of first test​
    This will provide an objective view of the new pack effect on MPG versus the original pack. At a constant speed between 35-42 mph, the car will cycle between "engine-OFF, battery discharge mode," and "engine-ON, battery charge mode." There are more stressful, traction battery benchmarks but such tests would push both packs to the margins and one might fail . . . boring.
  9. scotman27
    735
    82
    PA
    2001 Prius
    Wow, thank you for doing that, that saves me some time. its much appreciated. ok so you are saying this pack is ready to be installed, correct?
    and that the 300 or so mah difference wont be noticed by the car.
    ok so when that gets done out there charging, i guess ill pair them together, put them back in parallel, charge to 8.1 or so and rest, remove and get the old pack out of the car and disassembled.
    is this correct?
    usnavystgc and bwilson4web like this.
  10. scotman27
    735
    82
    PA
    2001 Prius
    Module 1 now done here are the numbers
    Module 1: D2:6376
    Module 2: D2:6093
    Module 3: D2:6070
    Module 4: D2:6076
    Module 5: D2:6124
    Module 6: D2:6227
    Module 7: D2:6135
    Module 8: D2:6092
    Module 9: D2:6344
    Module 10: D2:6414
    Module 11: D2:6094
    Module 12: D2:6373
    Module 13: D2:6358
    Module 14: D2:6027
    Module 15: D2:6122
    Module 16: D2:6299
    Module 17: D2:6079
    Module 18: D2:6044
    Module 19: D2:6238
    Module 20: D2:6483
    Module 21: D2:6407
    Module 22: D2:6479
    Module 23: D2:6405
    Module 24: D2:6131
    Module 25: D2:6282
    Module 26: D2:6153
    Module 27: D2:6100
    Module 28: D2:6160
    Module 29: D2:6274
    Module 30: D2:6203
    Module 31: D2:6152
    Module 32: D2:6359
    Module 33: D2:6326
    Module 34: D2:6408
    Module 35: D2:6346
    Module 36: D2:6207
    Module 37: D2:6248
    Module 38: D2:6336
    let me know the order, i dont know how much this will change things
  11. bwilson4web
    16,533
    Ok, here you go:
    Column 1
    GOOD LUCK!
  12. scotman27
    735
    82
    PA
    2001 Prius
    if you dont mind helping me out with the pairing again that would be great then I could possibly get this done tomorrow. module 1 went from 5990 to 6376, so im sure thats going to mess up the order you had them paired.
  13. scotman27
    735
    82
    PA
    2001 Prius
    disregard that last post of mine above.
  14. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    I think Bob read your mind. :)
  15. scotman27
    735
    82
    PA
    2001 Prius
    wow, . it seemed as though the capacities are kind of all over, i only had a 49mah difference before module 1 capacity came up . now i got a 370 mah difference. how did that happen
  16. scotman27
    735
    82
    PA
    2001 Prius
    yep, i think that would be very true lol.
  17. bwilson4web
    16,533
    Had a problem with the last table, here you go:
    Column 1
    1 [tr][td2]1[td2]26[td2]16[td2]6226.0
    2 [tr][td2]2[td2]27[td2]32[td2]6229.5
    3 [tr][td2]3[td2]11[td2]12[td2]6233.5
    4 [tr][td2]4[td2]5[td2]35[td2]6235.0
    5 [tr][td2]5[td2]24[td2]9[td2]6237.5
    6 [tr][td2]6[td2]31[td2]33[td2]6239.0
    7 [tr][td2]7[td2]4[td2]34[td2]6242.0
    8 [tr][td2]8[td2]17[td2]21[td2]6243.0
    9 [tr][td2]9[td2]14[td2]20[td2]6255.0
    10 [tr][td2]10[td2]18[td2]22[td2]6261.5
    11 [tr][td2]11[td2]8[td2]23[td2]6248.5
    12 [tr][td2]12[td2]3[td2]10[td2]6242.0
    13 [tr][td2]13[td2]15[td2]13[td2]6240.0
    14 [tr][td2]14[td2]30[td2]29[td2]6238.5
    15 [tr][td2]15[td2]7[td2]38[td2]6235.5
    16 [tr][td2]16[td2]2[td2]1[td2]6234.5
    17 [tr][td2]17[td2]6[td2]19[td2]6232.5
    18 [tr][td2]18[td2]36[td2]37[td2]6227.5
    19 [tr][td2]19[td2]25[td2]28[td2]6221.0
    The spreadsheet is a little tricky but here you go.
    So looking at your future pack, it is in effect not just new but improved over the original due to the lower internal module resistance of the new style. Awesome!
  18. scotman27
    735
    82
    PA
    2001 Prius
    So what do you recommend I do with my old pack? it works just fine and the voltage spread in reverse, pedal to the floor up a little incline shows 0.2 to 0.4 volt difference, i dont really want to scrap my old pack as I know it works and someone out there is in a bind and could use a pack, whether they need one to sell their car ( and should be honest with the buyer) or are in a financial bind and need to get by until they can afford a newer reinvolt pack or something.
  19. bwilson4web
    16,533
    I can't answer that except to suggest survey the modules and then post the 38 modules as a set with the numbers. Tell the buyer you'll equalize the charge before shipping and then it is their problem.
    You might also wrap up your charger and resistor set and offer them as a bundle with the 38 modules and not bother with the survey. In effect, selling a 'do-it-yourself' kit.
    If I remember correctly, I sold you a couple of replacement modules? I would be interested in what the after-service capacity looks like compared to the tags I had on them when I shipped them to you. Not quite 'apples-and-oranges' as we use different smart chargers. Still, another data point.
    You have a unique window to document the effect of the old and new pack on your mileage. The key is as carefully controlling the test environment with the old pack so you can replicate it with the new pack:
    • speed - the same speed in all cases but it needs to be just under 42 mph to get charge/discharge loads or over 65 mph to get high-speed metrics
    • temperature - anything within +/- 10 degrees around 70F would be great. Closer is better.
    • route - same route with or without hills but mostly without traffic and traffic lights
    • distance - 10 miles on a reset trip meter, two passes, one in each direction
    GOOD LUCK!
  20. scotman27
    735
    82
    PA
    2001 Prius
    here is my charge spreadsheet of my modules, can you confirm that I have my capacities correct for my pack.
    Module 1: D1:1718 C1:7500 D2:5990 C2:7500 D3:5110 C3:7250 D4:6376 C4:7250
    Module 2: D1:1960 C1:7500 D2:6093 C2:7500 D3: C3: D4: C4:
    Module 3: D1:1947 C1:7500 D2:6070 C2:7500 D3: C3: D4: C4:
    Module 4: D1:1967 C1:7500 D2:6076 C2:7500 D3: C3: D4: C4:
    Module 5: D1:2420 C1:7500 D2:6124 C2:7500 D3: C3: D4: C4:
    Module 6: D1:2447 C1:7500 D2:6227 C2:7500 D3: C3: D4: C4:
    Module 7: D1:2432 C1:7500 D2:6135 C2:7500 D3: C3: D4: C4:
    Module 8: D1:2479 C1:7500 D2:6092 C2:7500 D3: C3: D4: C4:
    Module 9: D1:2353 C1:6800 D2:5842 C2:6800 D3:5395 C3:7250 D4:6344 C4:7250
    Module 10: D1:2380 C1:6800 D2:5973 C2:6800 D3:5473 C3:7250 D4:6414 C4:7250
    Module 11: D1:2507 C1:7000 D2:6094 C2:7000 D3:1388 C3:0285 D4:5155 C4:7000
    Module 12: D1:2830 C1:6800 D2:5915 C2:6800 D3:5324 C3:7250 D4:6373 C4:7250
    Module 13: D1:2621 C1:6800 D2:5907 C2:6800 D3:5237 C3:7250 D4:6358 C4:7250
    Module 14: D1:2648 C1:7250 D2:6027 C2:7250 D3: C3: D4: C4:
    Module 15: D1:2549 C1:7250 D2:6122 C2:7250 D3: C3: D4: C4:
    Module 16: D1:2079 C1:7000 D2:6101 C2:7000 D3:6299 C3:7000 D4: C4:
    Module 17: D1:2577 C1:7250 D2:6079 C2:7250 D3: C3: D4: C4:
    Module 18: D1:2554 C1:7250 D2:6044 C2:7250 D3: C3: D4: C4:
    Module 19: D1:3308 C1:7000 D2:6068 C2:7000 D3:6238 C3:7000 D4: C4:
    Module 20: D1:2564 C1:7250 D2:5906 C2:7250 D3:5720 C3:7250 D4:6483 C4:7250
    Module 21: D1:2601 C1:7250 D2:5936 C2:7250 D3:5639 C3:7250 D4:6407 C4:7250
    Module 22: D1:2608 C1:7250 D2:5893 C2:7250 D3:5687 C3:7250 D4:6479 C4:7250
    Module 23: D1:2519 C1:7250 D2:5949 C2:7250 D3:5687 C3:7250 D4:6405 C4:7250
    Module 24: D1:2527 C1:7250 D2:6131 C2:7250 D3: C3: D4: C4:
    Module 25: D1:2591 C1:4662 D2:4367 C2:4388 D3:3673 C3:7250 D4:6282 C4:7250
    Module 26: D1:2584 C1:7250 D2:6153 C2:7250 D3: C3: D4: C4:
    Module 27: D1:2547 C1:7250 D2:6100 C2:7250 D3: C3: D4: C4:
    Module 28: D1:2521 C1:7250 D2:6160 C2:7250 D3: C3: D4: C4:
    Module 29: D1:2589 C1:4325 D2:4110 C2:7250 D3:3614 C3:7250 D4:6274 C4:7250
    Module 30: D1:2593 C1:7250 D2:6203 C2:7250 D3: C3: D4: C4:
    Module 31: D1:2619 C1:7250 D2:6152 C2:7250 D3: C3: D4: C4:
    Module 32: D1:4008 C1:7250 D2:6359 C2:7250 D3: C3: D4: C4:
    Module 33: D1:965 C1:4238 D2:4133 C2:4770 D3:4128 C3:7250 D4:6326 C4:7250
    Module 34: D1:4049 C1:7250 D2:6408 C2:7250 D3: C3: D4: C4:
    Module 35: D1:4079 C1:7250 D2:6346 C2:7250 D3: C3: D4: C4:
    Module 36: D1:2756 C1:7250 D2:6207 C2:7250 D3: C3: D4: C4:
    Module 37: D1:2833 C1:7250 D2:6248 C2:7250 D3: C3: D4: C4:
    Module 38: D1:3803 C1:4272 D2:4122 C2:3880 D3:3689 C3:7250 D4:6336 C4:7250
    modules 32 thru 35 had a power outage
    module 11 i accidently disconnected the wires and lost the data on the 3rd cycle
  21. usnavystgc
    3,159
    990
    Tucson, AZ
    Ready to assemble and install imo. Good luck and good job!!!!
