got some young 2012 modules
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Apr 10, 2014.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    just got back with the modules from fedex. i ran my meter over them, all voltages are at 7.72v, the ten i got the other day from the other seller are at 7.58v let me know what you think.
    now, inside the box was a label from when it got shipped back to the seller from someone else, and their phone number. so i called them. i spoke to his wife and she said he had to send it back because some thing was wrong. something about a tester and he had a prius book. im hoping he will call me and explain what he did to test it. and ill let you guys know. i sure hope i didnt get scammed here.
    all serial numbers indicate 2012 and seem to be in numerical order. so i dont think it was rebuilt previously. im hoping he just didnt test it right or whatnot.
    scott
  2. bwilson4web
    16,531
    Certainly do your research. The real answer is when you charge them all to the same voltage and then do the parallel load test.
    If I remember correctly you know how to parallel wire and charge them up to 8.0 to 8.1 volts. As a sanity check, take them off the charger and see what sort of 'self-discharge' you see.
    Self discharge should not be much but it is an unknown load. The discharge resistors will be the true test.
  3. bwilson4web
    16,531
    Hi Jeff,
    In a perfect world, we would test each module, mark its capacity, and then order the pairs. But I got the impression FAST was important to the OP:
  4. scotman27
    735
    82
    PA
    2001 Prius
    I just ordered 50 68 ohm 1w resistors. The seller: measured them for me and hand picked them so they would be as close to 68 ohms as possible.
    Lowest he said was 67.8 highest was 68.
    bwilson4web likes this.
  5. scotman27
    735
    82
    PA
    2001 Prius
    well I would like it to be done right but with working with something on eBay I know you have 30 days to file a claim to get eBay Buyer protection. if it was not for that I would do exactly that take each module and cycle each one to get capacity. But I got less than 30 days and I want to see if there are any problems before going forward in the given time.
  6. bwilson4web
    16,531
    So let's go over the electrical stuff:
    • 8V / 68 ohms -> 0.118A
    • 8V * 0.118A -> 0.94W
    • 7.5V / 68 ohms -> 0.110A
    • 7.5V * 0.110A -> 0.83W
    Working close to the designed power rating of these resistors, make sure there is 'free air' around them. They will get HOT and you want to have some gloves or oven mittens handy. When they first heat up, you'll probably smell a 'hot electrical' smell but as long as they don't discolor or char up, don't worry about it. This is what it is all about.
    Now the discharge curve of NiMH batteries is fairly flat. For a first approximation:
    • ~0.114A/hour
    • ~8.8 hours, 8 hrs 46 minutes is 1 Ahr
    Just spot check them to make sure they are all staying above 7.5 V. If one reaches 7.5V, it is OK to let it go down to 6.5V but never let it fall below 6.0V. If these were brand new modules with a full 6.5Ahr capacity, discharging 1Ahr should bring them down to:
    • ~7.75V ## Great!!
    I'll work up the spreadsheet tonight and post it to the thread. But understand these are 'back of the envelope' numbers. I would recommend spot checking against your RC charger, three weakest and three strongest. This just gives confidence that the '3d world' engineering approach has given usable metrics.
    Later,
  7. scotman27
    735
    82
    PA
    2001 Prius
    What do you mean by spot checking against my charger?
  8. scotman27
    735
    82
    PA
    2001 Prius
    also do you mean to charge the pack in parallel to 8.1v then take it out of parallel and let it sit for ten hours or so to see what discharge i get?
  9. bwilson4web
    16,531
    Yes. You have the modules and know how to parallel charge them. Git'er done while waiting for the resistors.
    The parallel charge and using matched resistors for controlled discharge with a clock, these are basic, applied physics. But you also have a smart RC charger and it makes sense to compare what basic physics reports versus the RC charger.
  10. scotman27
    735
    82
    PA
    2001 Prius
    ok, i will try to work on that either tonight or tomorrow night after work.
    The seller sent the pack of 28 with what looks like a white plastic module block on each end with the rods on top and bottom. so ill have to buy threaded rod to extend it out to make it a gen 1 pack so I can compress it together.
    i may still not understand what you mean with the charger. this is what im getting
    please use my paragraph to add or change anything that may be incorrect or may be of help.
    So when I get the resistors ill parallel charge to 8.1v (probably 8.16v and let it bleed off to hopefully 8.1v?) let the pack rest for 8 hrs, record voltages and do the discharge with the resistors and check it with a voltmeter once every 45mins or so up until about the 8 hr 45 minute mark. then record voltages and remove the resistors(or should i remove resistors then record voltages? also any rest time before recording voltages after removing resistors?).
    but once i get done the discharge test and record voltages and post the values here. ill put the 3 strongest that you say through a discharge/ charge, discharge charge cycle, record voltages and mah.
    then do the same with the 3 weakest correct.
    would that be considered the spot check with the r/c charger?
    thank you
  11. bwilson4web
    16,531
    Comments inserted
    * * * * * commented posting * * * * *
    So when I get the resistors ill parallel charge to 8.1v (probably 8.16v and let it bleed off to hopefully 8.1v?) let the pack rest for 8 hrs, (an hour or two would fine but use the rested voltage as the start) record voltages and do the discharge with the resistors and check it with a voltmeter once every 45mins or so up until about the 8 hr 45 minute mark (the longer the run, the more accurate the numbers but yes, closer to 9 hrs). then record voltages and remove the resistors(or should i remove resistors then record voltages? also any rest time before recording voltages after removing resistors?) (remove resistors and take the measurements there will a small rebound but go run some cold water over your blistered fingers and then measure the voltages . . . the resistors will be HOT).
    then do the same with the 3 weakest correct (this is only to get a second opinion, a scaling, between this manual process and the r/c charger, I would trust the discharge metrics but this is to give you and everyone confidence that the two match).
    would that be considered the spot check with the r/c charger? (correct, an optional step.)
    I've attached the promised spreadsheet inside a zip file. All of the columns in italics are inputs and will calculate the expected Ahr capacity of the modules. Now the longer the discharge, the more accurate the estimated Ahr capacity. Just monitor the voltages over time to see if any of the modules show discharge voltages falling below 7.5V. You really want 6.0V to be the absolute lowest ever seen and even then, it is not good.
  12. scotman27
    735
    82
    PA
    2001 Prius
    so after removing the resistors. what should I give the battery about 10 minutes before I take voltages or 5 minute maybe less? I plan on using gloves for this.
  13. bwilson4web
    16,531
    Gloves are good! These resistors are going to be just under their 1W power rating so they are going to be HOT!
    As for the rest period, I don't know a hard value to use. You might find something on the internet but certainly give the a pause. My thinking is don't be in a rush. Put the resistors away, drink a cuppa coffee, look at the spreadsheet and 'go to town.'
  14. scotman27
    735
    82
    PA
    2001 Prius
    ill say about 5 to ten mins
  15. scotman27
    735
    82
    PA
    2001 Prius
    Ok i got the pack ready to be set into parallel. however home depot is closed and ill have to wait till tomorrow morning to go get some threaded rod and some nuts. hopefully tomorrow morning ill get it set into parallel. While im in this little wait period I figured I would take a look at the voltages all on the pack of 28 are at 7.72 solid.
    so i looked at the serial numbers: here is what i got: Im not going to list all 28 as some go up in order
    All start with 052N:
    052N5M14044V
    052N5M14045V
    052N5M14046V
    052N5M14047V
    052NJM05791V
    052NJM05804V
    052NLM05807V
    052NLM05808V
    Here are the ones that go in order: im not going to list all of them just the first and last ones:
    052NLM05815V stops at 052NLM05830V
    052NLM05851V
    052NLM05852V
    052NLMO5853V
    052NLM05854V
    thats all 28. all are sitting at 7.72v
    Now my question is by looking at this, does it seem that the pack was a rebuilt unit? or is everything ok.
  16. Patrick Wong
    18,210
    6,517
    My guess is the 28 modules came from at least three donor battery assemblies. That doesn't mean that they are not OK.
  17. scotman27
    735
    82
    PA
    2001 Prius
    is it a good thing tho that since ive had this battery that the voltages are steady, not dropping, and not all over the place?
  18. Patrick Wong
    18,210
    6,517
    Yes, that is a good sign but until the modules are put under load, who knows whether they are matched.
  19. scotman27
    735
    82
    PA
    2001 Prius
    ah, very true.
  20. Patrick Wong
    18,210
    6,517
    Can I assume that you've compared the battery modules from the Prius v to the modules from the Prius c, and have found them to be identical with regards to physical form factor:
    1. height/width/depth of the modules?
    2. Do the terminals come out of the battery case at exactly the same height?
    3. Have you tried to fit the new modules into the Classic Prius battery case to see if any modification of the sheet metal will be required for the modules to fit?
