Got the fogs installed but where does that silly red wire connect to?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ES44AC, May 21, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    One set of directions said " goes in the same direction as the white wire" ( not an exact quote)
    If you look at the attached photo there is no male plug to accept the female end on the dreaded red wire!
    Is this the power / hot wire that feeds the relay when the low beams are ON?
    If so please advise where you hooked it up, as you can see there is nowhere on my 2011 fuse panel to do that :/
    Thanks!
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Either one of the ones circled. PC store needs to change the instructions for 2011 and up.
