Got Triangle of Death Today.
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jun 7, 2024.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
    Today, I got the Triangle of Death on the HWY, while doing 75mph
    I got all kinds of warning lights including= BRAKE WARNING , ABS WARNING, VSC WARNING,
    CHECK ENGINE WARNING &= the A/C stopped working.
    --I was able to make it home 20 miles away
    BUT??==I still had all the BLUE BARS on the charging system, with the Triangle of Death on the dash?
    ***SEE THE 2 DASH PICTURES I POSTED
    Any suggestions?
    #1 ski.dive, Jun 7, 2024
  2. fragglestickcar
    69
    40
    New York
    For me these were the symptoms of P0A93, or failed inverter pump. You only get it when the car runs long enough for the inverter temperature to hit about 180 degrees F.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,517
    NJ-USA
    Get a capable scantool and check all systems for codes.
    It certainly could be a P0A93 inverter overheat, but that's a guess. I suppose you could check the inverter coolant reservoir for agitation and circulation.
    49,500
    bummer!
    how many miles on her? 2008 seems too early for failure
  5. ski.dive
    896
    231
    My code reader says= P0A93, a failed inverter pump
    ***Buying an OEM' inverter pump' at the dealer tomorrow.
    Going to attempt to change it out myself.
    fragglestickcar likes this.
  6. ski.dive
    896
    231
    ***I drove it for 20 miles with a BAD INVERTER PUMP=Hoping I did NOT cause any more damage!!!
  7. Mendel Leisk
    38,729
  8. ColoradoCrow
    ColoradoCrow Active Member
    973
    392
    Leawood, KS
    I
    When swapping it out remove the drivers headlight. The job is so much easier when you do. And you can reuse the mounting bracket and just pinch off the hoses and you wont have to drain or loose much coolant.
  9. mr_guy_mann
    3,470
    1,517
    NJ-USA
    When the inverter gets too hot, it's programmed to turn off functions (like A/C) to protect itself - it'll be fine.
  10. fragglestickcar
    69
    40
    New York
    Bro, I drove my white-hot inverter for about that distance. I believe the car dials back power under P0A93 so you can't do too much damage. Check out what my old pump looked like..
