GPS - current coordinates location
Discussion in 'Prius v Main Forum' started by syscon, Oct 16, 2012.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does Prius GPS have current coordinates location/position?
    I could not find it.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,057
    6,928
    Texas Hill Country
    Map settings menu page has single item at top. From there scroll down all the way. Lat/Long/Altitude only displays when stopped.
  3. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Yes, I see it. When I go to Map --> Option and scroll down I see "Location & GPS Information" button but it only show address very close to my location the Latitude / Longitude and Satellites entries are empty when the car is parked inside garage.
    When I move the car out it shows GPS coordinates.
  4. Adam H
    Adam H Junior Member
    62
    To save it as a waypoint, what I've been doing is first magnify the scale by pressing + a couple of times, then I press over the current location with a stylus, and it allows me to rename the destination and store it.
    Marla.D likes this.
  5. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Here is what you can get on the spit screen of the HDD Prium Nav.
  6. Adam H
    62
    So what do you do with those coordinates?
  7. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I used the coordinates to call an air strike on a tailgater using the SOS button. The voice refused to redirect the drones to my location. I guess they were to busy patrolling.
  8. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Those GPS coordinates are very handy.
    Typical examples, you are lost somewhere/car broke down etc. and want someone else to find you all you do is provide these coordinates to someone who has a GPS and they will locate you.
    You went to a friend house and his house is not located on the map yet and want GPS to memorize/mark this location, just click save button.
