GPS Upgrades
Discussion in 'Prius v Accessories and Modifications' started by dick killian, Nov 12, 2016.
  1. dick killian
    dick killian New Member
    San Antonio, TX
    2014 Prius v wagon
    I have a 2014 Prius V with Nav Disk version 3.2.0 Is there an upgrade available, and if so where?
    52,872
    welcome! only at the dealer, and they can tell you what version is available.
  3. mikefocke
    4,083
    1,864
    Sanford, NC
    Map updates for the base GPS Entune system generally come out in late November or December and require a paid part that is a key card the dealer uses through his computer to upload the map to your GPS. That means an expensive part and expensive labor. Not a trivial or cheap process even compared to any recent GPS you may have seen advertised. I've found the costs can be negotiated somewhat. But they are so objectionable I only do the update every few years.
    I've found the actual firmware update (think of it as the program that manipulated and displays the map data) can be a dealer free update if you complain enough about the slowness of the warnings as being dangerous.
    The map updates are at least a year out of date when Toyota finally issues them compared to other GPS manufacturers which use the same source of map data that Toyota uses.
  4. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    I was one of the few Prius v owners who made the mistake of paying to upgrade the GPS maps. It cost around $225 and was a waste of money. The new maps were obsolete the day they were installed. The traffic updates through the Entune system are useless.
    The 6 inch display in my Prius is nearly the same size as my 5.5" phone. No advantage there.
    I recently made a road trip from Philadelphia to Tampa and back using Android Auto. It is far superior to the built-in Toyota nav system. Android Auto allows you to download map areas. If you lose your data connection it functions without any hiccups. Also, Android Auto now runs on your cell phone even if you don't have the app built into you vehicle entertainment system.
    I dislike having the clutter of using a cell phone mounted right above the unused built-in system but there is no denying the Toyota system is inferior.
    chipr and bisco like this.
  5. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    was not aware android auto worked on Prius. does apple car play work as well?
  6. Prodigyplace
    12,718
    11,850
    Central Virginia
    It appears they ran the Android Auto app on their phone only, without using the Prius.
    ems2158 likes this.
  7. S.Bell
    S.Bell Junior Member
    70
    Bay Area, CA
    2013 Prius v wagon
    Thanks. Do you have a link for it?
    I also found the maps in my GPS to be outdated.
    I'm interested in hearing more about it for iPhone, too, since I am considering upgrading my cell next to iPhone.
    SM-N910V ?
