GPS won't let me input an address
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Db17, Apr 1, 2017.
  1. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Got in the car today and went to enter an address in the navigation system (Advanced 11.2). The only options it gave me were recent addresses and address book. It did not allow me to enter an new address (that button was greyed out). Rebooting the screen didn't fix it although when I got back I the car an hour later, the system worked normally.
    Anyone else ever experience this?
  2. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    Car must have not wanted to go wherever you were about to take it.
    'LectroFuel likes this.
  3. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    Were you in motion the first time you tried to enter the address?
    priuscatprimeguy likes this.
  4. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Thank you. That's the answer
  5. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    There will be multiple options not available if you drive....GPS..and others system and car setting....safety precautions from Toyota
    Stop and check again
  6. CharlesH
    2,798
    1,166
    Roseville, CA
    Toyota apparently never considered that there might be a passenger who wants to change settings. This has long been a source of gripes. It is clearly done at the behest of their legal department as a defense against lawsuits that Toyota facilitated an owner's stupidity. :rolleyes:
  7. rcc
    rcc Junior Member
    Germany
    The question is why this is the case with the Prius models, not however with our Yaris model? I conclude this not to be a general Toyota policy, but a model specific feature?
    regards
    rcc
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    I do not know about the Prime but on many GPS systems the restrictions are enabled by default for liability reasons but there is an option to disable the restrictions.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    do tell ( where is this option?):D
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    I know my Garmin GPS has it. I do not know, otherwise.
  11. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Yep, but it seems like the other ones usually notify you the option is not available while moving. So this time I just thought it was broken.
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    It was the same on my first generation 2002 Prius. It was so defensive that you had to explicitly dismiss the warning about not blindly following navigation guidance every time you started the car. It did not time out like in subsequent models.
    As for Toyota model differences, I guess it is sort of like why does one get individual tire pressure readings on the Highlander (like my son's 2008 Highlander Hybrid), but not the Prius?
  13. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    If the car is moving then you can't input any address from scratch, similar to phone log that once you are in motion, you can't browse the whole calling history.
