Grabbing Brakes in Reverse
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LINKSTER, Jul 26, 2009.
  1. LINKSTER
    LINKSTER LINKSTER
    los Angeles
    Whenever I park (1 hr+) my 2010 class 1V on a small incline and then go to back up, the brakes violently grab the disks like they are seizing up. After driving a mile I can back up totally normal. It only happens on an incline and never on an even surface. Has anyone experienced this or have any idea what might be causing it?
    Linkster
  2. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    This seems to be a known event. There's a thread that talks about this problem: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65875-braking-in-reverse.html
    Here's how to avoid it from the link:
  3. rsgillmd
    rsgillmd Junior Member
    38
    Memphis, TN
    I haven't specifically noticed the problem but when I am parked on an incline I have my parking brake applied anyway. I put my foot on the brake pedal and turn on the car. Keeping my foot on the brake pedal, I release the parking brake and put the car in reverse. Then I ease off the brake pedal.
    I'm not sure how you do it. That is why I spelled out what I do. Hope it helps.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Make sure you're not invoking the hill-hold feature and then
    getting weird behavior when it releases.
    _H*
  5. rahamanmd
    rahamanmd Prius for Change
    Orlando, Florida
    This happened to me once while reversing out of my garage (level surface).
  6. TheHorsts
    TheHorsts Junior Member
    53
    Oakland, CA
    Had this happen to me, today. Level office parking garage.
    The lightest touch in reverse caused the brakes to seize up quickly. Seemed to do it 2 or 3 times before it settled down. The gas engine seemed to have come on, too. It was almost as if the brakes settled down once the engine kicked in.
    Brand new Model IV Prius -- 2 days old.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Grabbing Brakes in Reverse would be bad for your hands. Brakes Grabbing in Reverse is another issue. :D
    Tom
  8. hotgrass
    hotgrass New Member
    tn
    it happened to me this morning, since i needed to move forward in order to not hit the car behind me, the brakes where pretty violent in the incline moving forward but not going on reverse. weird.
  9. CaptBud330
    CaptBud330 New Member
    Knoxville, TN
    It has happened to me at least a dozen times on level surfaces forward and reverse. There is definitely a problem with this otherwise wonderful automobile.
    I questioned the local Toyota service manager and they were unaware of any problem. I contacted Toyota technical services and they had not heard of any problem either.
    They said they would make a note in regard to the VIN of the automobile. I honestly believe the NHSB should be involved in forcing Toyota to resolve this problem.
  10. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    I've had the problem too, forward and reverse...but after pumping the brakes for a bit it goes away quickly....sure GRABS fast and furious until then...even the slightest pressure on the brake pedal and it really seizes up....noticed mine in forward motion first, not reverse...though I've had it happen both directions...and only when the car is first starting up.
  11. CaptBud330
    Knoxville, TN
    Found a solution. Put the Prius in park. Apply the brakes and shift out of park to D or R. Grabbing brakes solved. I now know when I get in the car if the brake pedal feel hard , I just pump it a few times. You can feel the brake pedal go further down and you won't have grabbing brakes at all. I sure hope Toyota fixes this. I have 4100 miles on my 2010 level IV and the problem still exists.
    2 people like this.
  12. web1b
    web1b Active Member
    817
    52
    The brake pedal gets very stiff and then goes back to normal after pumping several times.
    See video:
    [ame=http://www.vimeo.com/9170569]Strange Brake Issue on 2010 Prius on Vimeo[/ame]
    I noticed the problem most often after sitting with the ignition on (listening to the radio at lunch) and then backing out of a parking space, but I cannot reliably reproduce it 100% of the time.
  13. Sieglinde
    Sieglinde New Member
    Ridgecrest, CA
    I have had it happen only on level surfaces since I have not had the opportunity to park the car on an incline since I bought it. I found it disturbing but didn't feel that it was dangerous. The brake would grab, I would do the normal thing and release the brake and then it may grab again but usually it quit grabbing after one or two uses.
  14. LINKSTER
    LINKSTER LINKSTER
    los Angeles
    After a meeting with the dealership manager today the (6th) and their QC man, they agreed to take the car for as long as they need it to experience what I have been telling them about. So guess what? It happened again at three stops on the way home. I don't know if this is important, but each time the pedal was lower than normal?? I'll let everyone know the results in a week. Other members talk about "getting around it". I am not interested in getting around it, I want a normal bake system. I have not experienced any other brake problems that I have read about on other threads. The car is still under warranty.
    Linkster
  15. IMUSA76
    IMUSA76 IMUSA76
    Rhode Island
    I have had the grabbing brakes only on inclines when I'm backing up, its acting like the hill assist is on, but with out the indicator being on.
  16. LINKSTER
    LINKSTER LINKSTER
    los Angeles
  17. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    If they are saying they do not know about this, they are lying once again. It is a well-reported problem. Until Toyota stops lying and fixes this, the fix I have found is to shift into park and then back into gear.
    This company needs to stop lying to its customers. What will it take?
