Greasing locks?
Discussion in 'Generation 1 Prius Discussion' started by primuspaul, Dec 6, 2015.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    What is a good chemical to use to preventatively grease the door/trunk locks of a Prius? What about the ignition cylinder in those cars that still use a mechanical key to turn the cylinder? Is engine oil an acceptable chemical for both.
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Graphite (powder) - check out the local locksmith or hardware store.
  3. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Just wondering is this the same stuff as what's inside of a pencil? Can I just grind down a pencil (the core of it) and use that?
  4. WilDavis
    2,493
    2,155
    49
    I'd use white grease on the striking plates of the lock, but for the cylinder barrel and tumblers of the lock, I'd use Graphite Lubricant (Hillman)
    check at most good hardware stores. You could grind up your own graphite pencil leads (I've done just that, but that was long ago before amazon) but then why keep a dog and bark yourself?
  5. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    The striking plates need lubrication?
  6. WilDavis
    2,493
    2,155
    49
    Anywhere metal meets metal - for want of a better term, I call them striking-plates since that what they're called in the building trade, but perhaps they're called the "striker" - I've noticed the dealer used white-grease on the door hinges and strikers on my old Corolla Wagon when they did the complete (everything) bumper-bumper service). Oil is all very well for lube, but does tend to run where you don't want it, and it attracts dirt. Use graphite powder on locks or any small catches (I use it on the caps of various LED flashlamps I have where electrical continuity is needed from the cap to the body (graphite is conductive))
  7. Mendel Leisk
    42,381
    I use a light shot of silicon from an aerosol can. Maybe every second year.
