Greek taxi and traction battery
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Oct 6, 2013.
  1. bwilson4web
    16,547
    We had a user, scratesthecabdriver, report traction battery problems in the 2010 Prius in Greek taxi service. I've proposed we start a new thread in the Gen III forum. However, I would not limit it to just our Greek Prius taxi owners but anyone else who might have had a traction battery problem:
    This is the NHW11 (2001-03) model forum but I notice yours is the ZVW30 (2010-current) model. We also have a 2010 Prius but a pattern like this is curious:
    • Are you typically leaving the car in READY or when waiting for a fare, do you still shutdown the car?
    • What sort of terrain (or perhaps a city)?
    • What sort of temperatures?
    • Any problems with the 12V battery?
    • Has anyone tried using a Prius-aware scanner to see what is going on with the traction battery?
    • Would anyone have a GPS with data recording (i.e., Garmin nuvi) for route analysis?
    I would like to collaborate with you on this problem as we have a 2010 Prius:
    • 70,000 km
    • typical commuting route
      • ~50 km/day
      • +/- 10m/day
      • ~60 km/hr
    • Huntsville, AL
      • river valley with 160m hills
    • temperature ranges
      • 15.7C average, 31.7C max, -1.5C min
    If you don't mind, perhaps we could restart this thread in the "Gen III" technical forum?
    Thanks,
    cwerdna likes this.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I already started one about this a few hours ago. What sort of info are you looking for Bob? My Prius hasn't broken yet, but is weakened by its taxi use and is starting to hesitate when transitioning to the engine now. The HV battery quickly charges upto full very easily now when going down hills and also once the HV is down to 2 bars, it takes an age for it to charge back up.
    I replaced my inverter at 70,000 miles and I do wonder if that was because the car has been left in Ready for 10+ hours a day. I never turned it off so as to keep the a/c running and allow the 12v to be topped up as I had a 2 way radio, dispatch computer and taxi meter running all the time. Maybe the inverter got hot leading to failure. Saying that, the new one looks much more substantial, though I appreciate that's just my view. I don't know the temperature of my HV battery internally but I do know it was always warm to touch the boot floor just above it after the car had been worked.
    hybridbear likes this.
  3. bwilson4web
    16,547
    Sorry, I didn't look before posting but you are bringing something up, the unique characteristics of a Prius in taxi service. I had not thought about the need to keep the car in READY for the heavy, 12V load. Let me suggest we merge our threads, using "report" to make it easier to follow.
    I sure wish we could get someone using a ZVW30 (2010 model) Prius in taxi service with a miniVCI to capture some metrics. Hummm, I have a 2010 Prius, a miniVCI, and an AC power inverter on the 12V buss that could drive a resistance load. But I always raise the rear floorboard to run the AC inverter to vent the heat.
    Now one of the changes with the 2010 Prius is there is no separate radiator for the inverter. My understanding is the radiator has three cores:
    • engine coolant
    • A/C condensor
    • inverter coolant
    If the car is sitting there, the only airflow would be from the radiator fans and they are traditionally driven by the engine coolant temperature. Now I'm wondering if the inverter coolant temperature should also be used to force the fans to operate perhaps with a more aggressive cycle.
    We really need metrics and if you are no long in taxi service, perhaps one of our Greek friends might show up. We can then work with them to make a plan to see what is going on.
    I've made the assumption taxi service does NOT use the OBD connector so we can still use it to get metrics.
    Right off the bat, I'm also wondering if a Prius taxi might also need more 'exhaust ventilation.' If so:
    • remove the plastic tray under the rear floor board to help get the heat away from the traction battery
    • some sort of 'spring' or shim to give a 1/2 inch (1 cm) gap at the rear floorboard to help vent the traction battery heat
    • alternative, remove the rear carpet and make 'vent holes' to help release the heat into the cabin, away from the traction battery
    GrumpyCabbie likes this.
  4. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    If the HV Battery is getting hot, it is possible to turn on the battery fan with an Xgauge. I have done this and this does improve HV battery performance when it is hot.
    Thanks,
    Dan Lander
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    As the traction battery in the gen3 air cooling scheme includes the spare tire area,(and it's a wealth of noise in the drivers seat), I'm wondering about the positive aspects of opening the ventilation of the traction battery to the cabin occupied by humans, the gasses being evacuated by the closed system are now being diverted to the cabin. I'm thinking about a scoop on the outside of the vehicle near the inlet for the traction battery that will "force" air through the system without contaminating the cabin, it can have a large noiseless fan to dissipate heat when standing still, like in taxi mode, fan is by the 12v battery
    Notice the gen2 has an evacuation system for the traction battery that doesn't include the spare tire area, and it seems to be more efficient.
    And quiet, have both.
  6. Emcguy
    Emcguy Member
    177
    29
    Australia
    Does Prius v (Li-Ion) have or need one of these fans? If so where is it?
  7. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Off-topic, but only PHV and +/Alpha(JDM) has Li-Ion. Your Prius v has NimH.
  8. bwilson4web
    16,547
    Perhaps before we 'engineer' an improved traction battery cooling system, we need to get some metrics:
    • traction battery temperatures - we need samples during the workday to see if the traction battery temperatures are climbing or riding high
    • inverter temperatures - again, we need samples during the workday to see if they are climbing or riding high
    We will also need some 'stock' or 'normal' temperatures. For want of better configurations:
    • temperatures during a one hour, highway drive
    • temperatures from 'cold-start' to 'daily commute'
    But all of this depends upon getting cooperation or partnership with a 2010 Prius taxi owner. If no one shows up, the rest does not matter. I'm here to help but I'm not here to become a Prius taxi owner.
    I'm going to suggest looking at the pressure relief 'valves' located between the body and rear bumper cover. These rubber valves open so when a door is closed it doesn't pop everyone's ears. Duct work could route the hot-air exhaust to one of these valves and force it out.
    The NHW11 had a traction battery, hot air exhaust on the side of the body and a traction battery fan to force the hot air out. However, this was also an area where aggressive, car wash and small critters could enter the traction battery area. I've long suspect this was the likely cause of a couple of NHW11 traction battery fires.
    But I'm not interested in working on this UNTIL we have some basic engineering metrics about the traction battery temperature profile . . . especially for taxi service.
  9. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Isn't the Australian model a +/Alpha?
    Edit
    Disregard the question above. I see that it's still called the Prius v but the 7 seat version has a LI-Ion battery.
    Carry on.
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The European v which is called the + here has Li-ion as does the Yaris hybrid. The li-ion battery in the Prius+ is situated between the front seats in what is the void below the shifter on the gen3. This allows space in the rear for the 7 seat option.
    New Toyota Prius Plus (12 on) Car Review - Gallery | Parkers
  11. telmo744
    2,181
    769
    Portugal
    Yaris hybrid shares platform with Prius c, both NimH.
  12. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    As far as traction battery temps, won't the car manage this automatically? Our 2013 FFH has Li-ion batteries, so it isn't the same battery chemistry as the NiMH of the Prius, and the fans turn on when the battery reaches about 75-80 F depending on outside air temp and cabin air temp. The fans will increase in RPM if the battery temp gets much above 80. The highest I've observed for the HVB is 95 F. This was on a 100+ day outside and was after the car was sitting in the sun for hours. Once I started driving with the AC on the HVB temp dropped down to the low 90s.
    Is your hypothesis that the Prius HVB fans are not sufficient for the taxi application with the car on all day?
  13. bwilson4web
    16,547
    The usual killer of a Prius traction battery is heat and charging is exothermic. So we know from the earlier Prius:
    • some driving profiles can 'heat pump' the traction battery - a lot of hills at speeds over 70 mph in the NHW11
    • ZVW30 does not have an external vent for traction battery heat - the NHW11 does
    Now there may be another failure mechanism involved with the taxi service, traction battery failures. But we need at least some temperature measurements to rule out the known killer, heat.
  14. bubbatech
    bubbatech Member
    153
    60
    Alabama
    I agree that the only way to begin to answer the question definitively is to collect battery and inverter temperature data under a variety of conditions, especially under heavy service conditions. We could compare a couple of groups - people like me who drive typically under mild conditions (I live about 90 miles south of Bob in a relatively hilly city), and heavy users like taxi drivers. If the temperatures were compared over time of day, we could build a temperature profile to see if the battery temperatures are different, perhaps calculating something like degree-hours. It seems to me that temperature is important, but also the amount of time at which temperatures are maintained could be a significant factor. If we find that time-temperature matters, we would at least establish an association, although establishment of causality would require something more active.
  15. Emcguy
    Emcguy Member
    177
    29
    Australia
    Correct, all of the v's here have 7 seats. You can either buy the base model, like mine, or the i-tech which has sat nav, moon roof, leather and 17" wheels. The base model still has better features than most cars here.
  16. bwilson4web
    16,547
    Are these Prius the taxi service vehicles?
  17. telmo744
    2,181
    769
    Portugal
    Athens is both hilly and warm. Lisbon also, although less warm.
    I have heard of a Lisbon 3Gen taxi HVB failure recently, around 100k miles. Of a few Prii taxi, it is a significant event!
    Agree that we are lacking data/measurements, but for sure HVB heat management may be to blame. Or a production flaw that gets worse when in severe duty...
    bwilson4web likes this.
  18. Emcguy
    Emcguy Member
    177
    29
    Australia
    Sorry, I was explaining options available to the public. There are base model Gen iii taxis but only in one of our northern states (Queensland) the rest of Australia run sedans from Toyota, Ford, Holden (gm). Ford and Holden both have LPG optioned engines.
  19. bwilson4web
    16,547
  20. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    So the ZVW30 (current gen Prius) doesn't have an external vent for battery heat? Just internally to the cabin?
