Green light on Power Button not coming on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Experimental, May 19, 2005.
  1. Experimental
    Experimental New Member
    Atlanta, GA
    Maybe I'm imagining things, but I remember that a green light used to emit from the Power Button after the car had started in the past. I still get the amber color light on the Power Button when first pressed, but then it goes out and no other light comes on.
    Am I wrong, or is something out of the ordinary going on with my '05 Prius?
  2. kidtwist
    kidtwist New Member
    183
    This is normal I believe. I've never bothered to look at mine and see, but check out this thread: Green On Light
    Except that there it's stated that it changed in 2004, and you have a 2005 and you remember it coming on. Hmmmm.
    I'll check out mine next time I start it.
  3. kidtwist
    kidtwist New Member
    183
    Yep, mine also isn't lit when the car is on.
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Green: ACC
    Amber: Ig-On.
    Off: Off or READY.
    Blinking: system fault probably in power ECU.
