Green oily gunk covering part of radiator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dan_, Sep 26, 2014.
  1. Dan_
    Dan_ New Member
    CA
    I
    Sorry for the lack of a picture but I noticed a 1'x2' square in the bottom passenger side corner of the radiator covered in green oily gunk. Ive had the 2008 for about 1000 miles (has 58k) so Im assuming its been there for a while. Seems like its impeding airflow. Suggestions on cleaning? Idea of the source? Its very green
  2. JC91006
    16,475
    8,393
    AC oil leak? Sounds expensive.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Most likely a tiny coolant leak I think.
    That tends to be green and crusty as it dries.
    I would suggest that you NOT try to clean it off yourself because doing so might make the leak MUCH bigger.
  4. Mendel Leisk
    38,647
    What color's the coolant in the reservoirs?
  5. bisco
    49,377
    i would try warm soapy water and a shopvac.
  6. wa-chiss
    wa-chiss Member
    124
    36
    Brownwood, Texas
    Toyotas coolant is pink. If someone put dye in the a/c, it should be green.
