GreenTecAuto = SCAM
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BCS-TX-Prius07, Jun 14, 2015.
  1. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    But you have enough time to waste by not posting the photos that others are asking for to get to the answer.
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    #82 alftoy, Aug 16, 2022
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Ummmm......It's a Gen 1. The serial numbers are viewable through the case. There's an opening about 3 inches x 6 inches on the top of the case. (left side of battery in the previous photos) You can see the module tops in the photos, which is how I was able to say those are not Gen 1 or Gen 4 modules.
    alftoy likes this.
  4. alftoy
    1,132
    519
    #84 alftoy, Aug 16, 2022
  5. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Nope, not a typo. The first instance is referring to the car generation and the second instance is referring to the battery module generation.
  6. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    When you told the other guy to get a clue (original post 82) because the OP would need to have the tech come back and disassemble the battery to get a photo of the modules, I just responded that it wasn't needed because it was a Gen 1, which has an opening in the top. I can't help it if you then edit and delete your post. My fault for not quoting to provide context? No harm no foul, we all make mistakes about the different gens sometimes. I've made plenty of responses to Gen 3 questions, thinking it was Gen 2. Nothing new there.
    alftoy likes this.
  7. Traveler21
    Traveler21 New Member
    Nevada
    2002 Prius
    I posted 2 pics… now the battery has been installed and covered in the car and I have no idea how to open it… I have the number on the battery that’s ended with R151 but it doesn’t seem to be the serial number another friend here was talking about… As long as the “cell” is really a new one I’d like to give it a try and I’ll travel again soon anyway… They fixed the “check” light for me today…
  8. Traveler21
    Nevada
    2002 Prius
    Actually they made that “check” light disappear with a cellphone…without doing a diagnostic…
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Then we shall never know if they are new or not. Maybe next time, lol. If you ever have a chance to pop the carpet off the battery, get the numbers and let us know.
    Was this someone coming to you, connecting a Bluetooth device to the OBD port and then reading/resetting fault codes using a phone app? Did they tell you what the code was?
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Actually, if at the end of a sentence you say "period", the translation puts it in. At least that's how mine works.
  11. Traveler21
    Nevada
    2002 Prius
    I took a pic of the trunk to show u what I meant about the covered battery . They did pretty much what you said about the “check” light…
  12. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Been a little while since I messed with a Gen 1, but I think that carpet piece right in the middle just pops out and exposes the battery case.
  13. Traveler21
    Nevada
    2002 Prius
    I’ll try after I find some tools just give me some time… Thank you very much.
