Greetings from another happy Prius driver
Discussion in 'Newbie Forum' started by danl, Jan 27, 2009.
  1. runnerwithaprius
    runnerwithaprius New Member
    17
    Pennsylvania
    Ok so I know I just posted that yesterday but when I filled up today, the mileage reset on the touch screen...so I guess I'm back to what I originally thought would happen after filling up.
  2. danl
    danl New Member
    231
    Boston, MA
    Yup resets every time I fill up too. Nice feature, but too bad it doesn't have another counter to track the lifetime mpg as well as the tank mpg.
  3. danl
    danl New Member
    231
    Boston, MA
    Sorry if I sound like a broken record, just want to clarify about regen braking. So if I were rolling towards a red light at say 30mph, is it better to
    1/ brake really early, and lightly ride the brakes to the light
    2/ roll all the way to the light then brake when I get there
    I mean, if I'm braking lightly from far away, are the friction brakes applied?
  4. danl
    danl New Member
    231
    Boston, MA
    Yikes, what happened to my mpg reading at between 20-25 mins? Anyone seen that before? No, my car wasn't idling. That span should have read 100mpg because I was on a highway going 55 but rolling steadily downhill. I managed to keep my momentum when I got off the highway into the side streets. And it wasn't like my battery SoC was low too. It was around 50-60%, and rolling downhill probably charged it up a notch as well. Bug?
  5. ruby
    ruby Member
    130
    78
    danl,
    This usually happens when I'm crawling in traffic and/or haven't gone very far in a five minute period. Or, say, have the car in ready mode waiting for someone (the engine doesn't idle because no heat is on, etc.) So, during that part of the trip, maybe you only crawled through some traffic lights? If you went a few miles (rolling down hill etc), it would probably show something in the bar.
  6. danl
    danl New Member
    231
    Boston, MA
    Just weird. Nope it was at night around 7:30, and the streets were fairly clear of other vehicles. I was definitely on the highway for a good portion of those 5 mins traveling downhill around 55mpg; my foot was off the pedal. I must have traveled at least 3-4 miles in that span. Typically on that part of my commute home, I'd get a score of 100 (see past screenshots 1, 2 and 3). And last night I was thinking that I did better than average because it was later at night and I managed to initiate a couple of short glides and timed a couple lights perfectly to avoid stopping at all.
    Edit: Oh and even though I drive day in and day out in the bitter cold NE weather, I almost never turn the heat on. Hardly the radio. Gotta save those pennies, errr I mean trees. Lol.
  7. donalmilligan089
    239
    22
    virginia usa
    Hey it's not broke in yet . Bearing parts are tight and it will loose up thus better milage. Air pressue in tires give a little more vibration but I enjoy the increased milage. Also synthetic oil helps. I get 45-47 cold weather and 52-55 60 degree weather. Learning p&g will aid to better fe
  8. Bull Winkus
    Bull Winkus New Member
    Detroit Down River
    I've had that happen to me, but only when going through a drive through that lasted longer than 5 minutes. I guess there's just not enough miles (yards?) to register in my case.
    Looks like you had near perfect milage between 5 and 15 minutes ago, as well as good (above 50 mpg) milage for the previous 5 minutes. Are you sure you have your timeline straight?
  9. danl
    danl New Member
    231
    Boston, MA
    Hmmm, it happened again. Link
    Same stretch of the road. The whole time, I was in motion, on a highway with hardly any other cars on the road. I wasn't practicing P&G, but I was actively keeping the car running on solely on battery power. Max speed was probably 60 and slowest speed was probably 15. Never stopped once. Could it be that its like that because I burned 0 gallons of gas, so its a Divide By 0 error? Quite an obvious bug that toyota QA didn't catch if it is. :-\
    Anyway, onto another question. For my other cars, I've found the haynes manual to be an invaluable resource over the years. Just wondering if I should pick this book up for the Prius. It covers Prius from 2001 - 2008, but I figure there's not much of a difference between 2008 and 2009. Anyone have this book or can recommend any others?
  10. jtlytle
    jtlytle Caution: Prius owner
    89
    Welcome Danl. I'm new here since Dec 2008.
  11. danl
    danl New Member
    231
    Boston, MA
    Hi thanks. Great place to be.
    So adding to my list of questions, hopefully someone has the answers:
    1/ For those living in cold climates, do you warm up the car and usually for how long?
    2/ Anyone know if the haynes manual is a good resource for DIY maintenance and repairs?
    3/ Is it more beneficial for regen braking to really early, and lightly ride the brakes to the light, or roll as close to the light as possibly then lightly brake when I get there?
    4/ What's the optimal cruise control speed? 55?
  12. danl
    danl New Member
    231
    Boston, MA
    Hullo, anyone have insights into my questions above? No biggie, just general wonderments. Oh I got one more (maybe a stupid question):
    5/ Does regen braking apply to all 4 wheels or just the front two? Since there's no AWD, I gotta assume that regen braking only applies to the front two wheels.
    That being the case:
    a) does that mean than when I'm lightly braking, brake force is applied only to the front wheels
    b) if brake force is applied to all 4 wheels, does that mean that the rear drum suffers a normal car's wear-n-tear.
    c) if brake force is applied to only the front two wheels, does that mean the front wheels suffer uneven wear-n-tear, at least more than normal
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    1) I don't warm up because the thermo bottle instantly brings the coolant temp to around room temp (70 deg F).
    2) I heard that the Bentley version is better. Although it is more expensive, people here said it is more detail and well worth it.http://www.amazon.com/dp/product/0837615534?tag=priuschatcom-20 It is really a balance. The battery pack can absorb about 30 hp of regen braking. To get an idea of how that feels like, put the car in EV mode and accelerate until the gas engine kicks in. I think it is better to brake early if you don't think letting off the accelerator (rolling) is enough. I don't think the electric motor can generate 30hp at low speed. Below 7 mph, regen stops and the brake pad kicks in.
    4) I like 55 mph because it is the best trade off between speed and aero drag. It is the reason why they set the speed limit at 55 MPH.
  14. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    5) Prius is front wheel drive so the regen braking is only front wheels. Iin theory, front tires should wear faster. 60% of the weight is also on the front wheels.
  15. danl
    danl New Member
    231
    Boston, MA
    I actually didn't know about the thermo bottle, so I looked it up and your video popped up ha!
    I'm considering the bentley book, good reviews on amazon. I don't expect to do alot of maintenance aside from oil and air filter changes, but I feel naked without a manual for those just-in-case scenarios.
    Thanks for your input, usbseawolf2000.
  16. Bill1
    Bill1 New Member
    Atlantic Beach, FL
    Hi danl. You replied to one of my threads and said that you also had driven about 1300 miles with your new Prius. I wanted to revisit one of your previous posts on this thread regarding tire pressure. There is lots of archive info on it if you do a search, and I read that you should keep a 2 psi difference between the front and back so you may want to add 1 psi to the fronts or take 1 psi off of the rears.
    I pumped mine up to 40f/38r on the last time I filled up with gas. You definitely feel the bumps in the road more, but I really like the way it drives now. It seems like it handles better in turns now. My mileage seems to be up as well - 1st tank was about 52mpg, 2nd was around 54mpg and the 3rd (with the higher pressures) I am now at 56+mpg shown on the MFD after about 350 miles. Of course this could be due to the car getting broken in or just me learning how to drive it.
  17. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    That one was fun to make. I threw in 30 MPG going uphill on the bridge. I got sick of seeing car ads on TV of getting 30 highway MPG as if it is suppose to be amazing. Ha!
  18. danl
    danl New Member
    231
    Boston, MA
    Hey Bill, yeah, thanks for pointing that out. Coincidentally I was planning to check the tire pressure this weekend, since its starting to warm up, but I'll be sure to keep a 2 psi diff between the front and rear.
    Those are some fantastic tank mpgs you got. My first tank was a dismal 36 mpg, which was a major bummer. But similarly, I noticed a drastic improvement as a direct result of me spending all day on PriusChat. :) I suppose the passing the break in period also has something to do with it. The following tanks were: 50, 53, and then 49 today. Still beyond my expectations and its still in the dead of winter here.
  19. danl
    danl New Member
    231
    Boston, MA
    Good thing I checked my tire pressure this weekend. Temperatures rose from mid 30s when I pumped them to 65F this weekend and my tired were over inflated; at 41 some psi.
  20. danl
    danl New Member
    231
    Boston, MA
    Howdy, quick questions: Over the weekend I was discussing the prius with a fellow coworker who is also considering buying a new 2009 or even a 2010. I was just giving him the facts, but a very simple question stumped me and I really should know. He asked if the ICE ever directly powers the wheels. What would be the correct answer?
    Oh here's another one. Is the prius on a timing belt or chain or none at all?
