Grid Charge HV Battery to Balance?
Discussion in 'Gen 2 Prius Technical Discussion' started by vskid3, Feb 7, 2014.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    Make sure you cool things as you charge/discharge the pack, and keep things under compression.
    Doing some preventive/maintenance charging would certainly keep things in check and is a good idea.
    Glad to hear you are thinking ahead.
  2. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Thanks for the encouraging words. We hope so too!
    Our fan motor control board is almost done. Functions perfectly on both 1st & 2nd gen HV battery fans. Just a few more tweaks and tests (and a green light from the patent attorney) and these will be ready for market :).
  3. jeff652
    607
    624
    Idaho
    Like Eric said, the voltage levels should work, but the 'car harness' would be completely custom. Also and very critical, you would need a way to cool the cells while balancing. For a one off, might be worth getting some sort of 120vac fan and fabricate a removable ducting setup.
    We get calls all the time from lower volume hybrids such as this. We want to get car harnesses designed for all of them, but oh so little free time hahah
  4. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Would I still need to be concerned about forced cooling even in the middle of winter in eastern canada?
    I will be experimenting with spare modules to get the hang of what I am doing before working on the full battery.
  5. MTL_hihy
    536
    261
    Maritimes, Canada
    Totally understand serving the larger markets first. My biggest concern would be the charging system as I can definitely design a forced cooling setup (either using the stock system or retrofitting something onto the vehicle).
    Thanks again for everyonés insight on this.
  6. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    If you monitor the first module on a regular basis you will know how much heat is likely to be given off. Charging more than one module within thin pack at the same time may require some cooling. The lower the charging current the less the heating will be, but the charge times will be longer to compensate.
    John (Britprius)
  7. MTL_hihy
    536
    261
    Maritimes, Canada
    Makes perfect sense. I am looking to use 2 x 200 watt (self powered) Hitec X4 chargers so hopefully that would be the maximum heat dissipation assuming the modules were all at full capacity. I will just need to see how hot the setup gets on a steady state basis under those conditions.
  8. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    For some of the people charging at high amp ratings for longer periods of time, I would suggest backing off a bit as you reach higher State of Charge. Don't want to make the cells overcharge and start venting!
  9. MTL_hihy
    536
    261
    Maritimes, Canada
    When you say back off do you mean to lower the current down to 1-2A or to lower the mAh being delivered to the battery overall? Not sure my charger has that capability to alter current throughout the cycle if thats what was meant.
    Testing a module today I did overcharge it and it started to vent as I could hear the cells bubbling at only 5A of current with 7500mAh being delivered overall. The cells started to bulge out slightly but it all seemed to go back to normal again when discharged. If this venting/cell deformation is bad, how do you prevent this from happening in the future.
  10. vskid3
    vskid3 Active Member
    773
    228
    Insight batteries are generally balanced by the overcharge method with only 350mA. 5A is waaaaaay too much to balance at unless you have massive cells.
  11. MTL_hihy
    536
    261
    Maritimes, Canada
    Are you talking grid charging the whole pack or cycling individual modules?
    Have you balanced Prius cells too? If so what values were you using?
  12. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    My understanding is this thread was about charging the whole pack at a very low current to improve balance without having to take the pack apart.
    MTL_hihy: It sounds like you really need to stop and do some more research on safely cycling your individual cells (different than what this thread was about). It doesn't sound undoable, but if you do it wrong you can easily destroy your battery. If you are seeing evidence of bulging/bubbling you are likely doing permanent damage to your cells. You may not have the correct profile loaded into your charger, as it should be slowing down the charge toward the top and I would think it should have stopped before that started to happen. You may also need to come up with a rig to keep the module compressed while cycling. I'm no expert, but I would proceed very cautiously and do a lot more reading until you know what you need to do to protect your cells.
    Rob
  13. MTL_hihy
    536
    261
    Maritimes, Canada
    I have done extensive research on the subject and discussed with many experts and it didnt seem like the settings I was using were at all going to be doing any damage to the modules. The bulging may be just a lack of clamping on my test modules (havent touched the ones in the car at all) which I will fix with a test jig. Yes the cycling of individual cells is a bit different from grid charging but you can apply the techniques to both situations.
  14. vskid3
    773
    228
    The 350mAh is for the whole pack, but that doesn't make too much of a difference. Charging at 5A is probably ok (the car itself usually charges at many times that amount of current), but you need to have a smart charger that will lower the current and stop when the battery is full. Charging the whole pack is more of a quick and dirty method compared to doing each cell.
    I haven't grid charged anything yet, I'm just going off what I've read from many others who have.
    j12piprius likes this.
  15. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    The car is charging at a much higher rate, but it never is taking the cells to 100%!
  16. MTL_hihy
    536
    261
    Maritimes, Canada
    Great discussion and certainly look forward to setting up a grid charger for highlanders too.
    If you are looking for a beta tester I would certainly be interested.
  17. MTL_hihy
    536
    261
    Maritimes, Canada
    Just a follow up on this......the test module above was damaged because:
    1) I overcharged it (started cycle charging instead of D>C, capacity was also set a bit high)
    2) I didn't clamp the module as well as I should have (best to attempt charging in the Toyota packs, not on the bench)
    Had much better luck on the actual battery pack with lowering charge rates and capacity settings.
  18. jeff652
    607
    624
    Idaho
    Yes lower current=better when grid charging cells above 100%. We are on our third & final rev of the fan motor control and almost done with the patent application. Will be doing final thermal testing next week and hopefully getting the patent application filed next week also. It's taken longer than I thought but we have a charger with fan control that is robust enough to be run in a hot Arizona summer, which was our goal from the beginning.
  19. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    Charging rate (current) is the same whether it is one cell or the entire pack. They are in series, after all. The current flow is identical through all cells by definition, and voltage can vary. Were they in parallel, then the voltage would be consistent in all cells but the current could vary. 0.35 amps is WAY lower than 5 amps.
  20. pbui
    pbui Member
    190
    Los Gatos, northern CA
    So what is the GenII top off charge voltage ? with 350mA current limited
