Grid Charger options
Discussion in 'Gen 2 Prius Main Forum' started by drogmar, Mar 20, 2026.
  1. drogmar
    drogmar Junior Member
    Patterson, CA
    I was looking at the $100 DIY thread that is now closed. They show a KUAIQU SPPS-D3001-232 (0~300v, 0~1A) for charging the battery and 90980-12474 4P wire connector harness plug too to hook up with a 12v charger for the fan.
    When I look up the power supply, it looks like it works off 220v. Does anyone know if there is a 110v input version that works the same or if the power supply will take 110V and still supply 300v out?
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Main thing you'll run into is the type of plug it comes with... And in general most electronic devices run on both 110V in US and 220V in Europe and the plugs are different but the electronic devices are usually designed to handle both sources of power. If you're buying the US you can be sure it will ship with the correct plug for a 110v outlet.
  3. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    My Venice hybrid charger is 120V @2.4 MA @300V setting it has two other settings for Honda etc
  4. PriusCamper
    13,476
    5,441
    How much did you pay for yours?
    This one is $650: https://www.ebay.com/itm/257047387383
  5. Tombukt2
    13,879
    2,521
    Durham NC
    Taj built mine for me a lil different better plugs etc . 8 think I paid him about 450 with discharger at time 5 yrs ago . He real nice guy . And if anything goes wrong or goes funny I can send it to him and he'll fix it without any issues it's been back Once I cracked the white case . Changed to heavier case
  6. pasadena_commut
    pasadena_commut Senior Member
    3,072
    956
    Southern California
    2.4 MA? Surely that is 2.4 A. I guess it could also be 2.4 mA, but charging times would be really long.
    Amusing to think what that system would be like if it really was in mega Amperes. The output wires would have a cross section of around 2 square meters. The service it ran off of would need a rating of at least (300/120)*2.4MA = 6 MA (assuming 100% efficiency). I don't think Home Depot stocks any quite that big, but they might carry a 400A box. One would only need to wire 15000 of those boxes together to pull in enough current. Cooling might be an issue though. P=IV. If V is 300 and I is 2400000 it would be best to stand back, as 720 MW might get a bit toasty. I suspect that 720 MW dissipated in a pack would very rapidly convert it to a puff of smoke, and if in the car itself, a puddle of molten metal.
  7. Tombukt2
    13,879
    2,521
    Durham NC
    My mistake 2400ma or 2.4 a. It's on the site he builds Bunches of them or he may not now he kinda older.
