Grid charging between first and last cell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mark1234, Aug 20, 2019.
  1. Mark1234
    Mark1234 New Member
    CA
    Hello, I have my battery out on the bench right now and was grid charging it with the HA charger. I then last night started the discharge process but was going to sleep so I turned it off the bulb discharger with using the orange service plug. This morning I went to go put the service plug back in an continue discharging but the orange connector that's connected to the computer must have shorted out and small little fire. I'd like to keep the process charging and discharging the cells so I was wondering is it possible to just go from #1 cell to #28 cell with + and - and keep it charging? I know the service plug needs to be in for that to work so I don't know if that's a bad idea with already the problems I've had with the shorted wire.
    Thanks for the help.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Id be concerned about proceeding without further investigation into the “small fire” that occurred ;).
    Sort that out first and keep us posted (y).
    alanclarkeau likes this.
  3. Mark1234
    Mark1234 New Member
    CA
    Well I was trying to bypass all the electronics if that's possible. I read one post about people saying cell reversal can cause that. Haven't looked into what causes that but after the fire I went and checked everything and sure enough there were three cells that were reversed.
