Grill block on/off experiment: 71 mpg v. 62 mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by mainerinexile, Apr 11, 2011.
  1. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    On the last day I had the grill blocked for the winter, I drove a 27 mile stretch of rural road, no stop lights or stop signs, light traffic, rolling gentle hills, no wind, ICE pre-warmed, ideal conditions for Prii gas mileage. I drove the identical route again this week, no grill blocking, similar conditions, almost a perfect experiment. Here are the results:
    Grill blocked: 35 degrees; 52 mph; 71 HSI mpg; 68 estimated actual mpg
    Grill not blocked: 40 degrees; 50 mph; 62 HSI mpg; 60 estimated actual mpg
    Temperature and speed slightly favored the unblocked gas mileage, but as you can see, the blocked mileage is much better. Although I am NOT a hyper-miler, I do practice 'Modified Pulse and Glide' (MPG) in which I slow down going uphill and speed up going downhill, when traffic allows. In this mode, I call the Prius an HGEV (Hybrid Gravity Electric Vehicle) since using the terrain allows me to improve gas mileage.
    I am impressed with the effectiveness of grill blocking. Toyota should add grill shutters for Prii like Chevy has just unveiled for aerodynamic reasons.
    Jeffrey Jessup, andyprius and olerox like this.
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Cool, mainer.
    You could probably keep some partial blocking on if you're comfortable, 40°F is still rather cool. It was 55°F here today, and with my top grill half blocked and bottom 3/5 blocked (Gen II Prius), coolant was still in typical ranges even with 2400-2500 RPM moments in the drive.
  3. San-Francisco
    San-Francisco Junior Member
    Almere
    71 mpg!
    That`s something I can only dream about!
    But with just 3000 miles my ICE is not broken in yet.
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    It's getting warm here in So Cal 60-90F. I got top 50%, bottom 100%. Since I'm using Enginer my coolant temp rarely hit 190F even at 85-90F. I'll remove a strip of insulation next month. There are too many stop and go traffic here so I never hit as high of mileage as you without plugin.
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Let's see, modifies the car for better gas mileage, does experiments to determine MPG, adjusts driving habits to get better gas mileage, gets mileage 40% better than EPA, I hate to tell you, but you are a hypermiler. It isn't an insult you know.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I see Ford is also installing shutters on their new models.
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I just unblocked half the lower grill on my car. We keep getting sporadic days of 70-80 degrees here, with 60s the norm. Granted, my typical drive is only 5 miles each way, but with the chance I might need to take a longer drive, I didn't want to risk any potential damage. I will probably keep the half lower blocked until we get to the upper 60s consistently here.
    Are there any recommendations on when to remove based upon temps? I know it can make a difference with trip length (shorter trips, probably not a big deal until it's really warm out). I think I'm at a good spot right now. I had it full blocked on saturday when I drove 100 miles r/t and got 56 mpg with temps around 55 degrees.
  8. mikewithaprius
    656
    103
    Rhode Island
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I remember Ken@Japan and his acquaintances where working on an automated louver system for the Prius. After having the bumper skin off myself, I wouldn't think this would be particularly difficult to do (at least for the lower grill). Just need a good metal or plastic fabricator...
  10. mainerinexile
    403
    73
    Maine
    Agreed, not an insult, but being an academic I am sensitive to being called a 'nerd'. On this drive, I just drove. Except for playing the terrain a bit as described in the OP, no attempt at hypermiling.
    Did you notice my average speed was 52 mph, not typical of a hypermiler!
  11. Corwyn
    2,171
    659
    23
    Maine
    I am confident you will be there soon.
  12. scottyfon
    scottyfon New Member
    White Haven PA
    I did a similar winter experiment, but instead of blocking the grille I wrapped the motor block with foil faced fiberglass insulation. Warmup occurred in a few minutes instead of twenty, and mileage improved dramatically, while the radiator was still able to cool the engine if needed. Of course the insulation all got wet and I took it off, but the point of it was very worthwhile. I might wrap the block again with waterproof insulation next winter. Maybe I'll try reflectix bubble wrap, which might melt, or high density fiberglass board cut to fit and wrapped with weldguard tie wired on. A good formed, water and fireproof block wrapper would be a great product for an aftermarket manufacturer to develop.
  13. mainerinexile
    403
    73
    Maine
    It seems that you've addressed one question I've wondered about: how much of the gas mileage improvement from grill blocking is due to heat retention and how much is due to improved aerodynamics? Perhaps it is mostly heat retention, although in that case. why did Chevy (or was it Ford?) bother to develop the grill shutters that they just announced?
    I still think that Toyota ought to add grill shutters to future Prii to gain some additional mpg benefit, for either reason above.
  14. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I thought the same thing when I saw the ads for the new Ford Focus with the grill shutters.
  15. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    71 MPG! You drive like a maineac. :eek:
  16. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    I'm running at 191f un blocked? Is this std for Gen3?
  17. Mark57
    2,945
    2,735
    OK
    Yes. Unblocked, mine runs around 194° - 195° depending on load, speed, outside temperature and how far I've been gliding with the engine off.:D
  18. comatoes
    comatoes #GreenLife
    288
    16
    I've recently blocked my engine, I see the temp getting up to 195 F, what's the "danger zone" for too much heat?
  19. walter Lee
    1,126
    376
    Maryland
    Excellent results. :cheer2:
    Did you block both the upper and lower air intake grills or just the top one? Do you have a way of monitoring the coolant temperatures? What kind of tires are you using and what tire pressure settings are you using? The Prius FE tends to be better when its travelling downhill so when FE is quoted for only one way (not a round trip) - gravity can be a factor so knowing the starting elevation and ending elevation helps one assess how much gravity affected your MPGs.
    Both Ford and Chevy have active air intake/grill shutter technology but they are only available on a few cars. The president of Toyota say that their R&D is looking to increase the thermal efficiency of their next generation ICE over 10% ( 35% -> 45%) so its likely that some type of dynamically control air intake cooling system is on the table for future Toyota designs.
    Fortunately, manually grill blocking is an inexpensive option for us today. :) Along with upping the tire pressure - grill blocking is one of those inexpensive mods that one can do which have a significant fuel efficiency payoff. :D Last winter, grill blocking helped me keep my 2010 Prius fuel efficiency over 50 mpg so this year I started grill blocking early in the fall in an attempt to increase my overall fuel efficiency.
    From your description, what you refer to as a *Modified Pulse and Glide* (MPG) is often referred to as *Driving with Load* (DWL) within hypermiling circles (see the FAQs on Cleanmpg.com).
    Walter Lee
    (aka "HyperDrive 1" on Cleanmpg.com mileage logs)
    2010 Toyota Prius type 3, blue ribbon/dk grey, oem floormats
    Yokohama Avid S33(D), (front 50psi rear 48 psi)
    ScangaugeII ( Fwt, GPH, SoC, RPM)
    Grill blocking (50% top 100% bottom)
    Odeometer +18000 miles, overall FE = 61 mpg
  20. walter Lee
    1,126
    376
    Maryland
    IIRC 170-189F fully warmed up, 190-204F is hot but not dangerous, >205F is dangerous ( the ICE thermostat is fully open at this point so additional cooling would be from the coolant pump working harder to do the heat exchange). I would take off the grill blocking if the coolant temperatures started climbing over 200F. However, more importantly, once the Prius engine coolant temperature rises over 168F there is no additional benefit to grill blocking except possibly a warmer defroster and passenger cabin in the winter time.:p
