Grill Blocking Caution
Discussion in 'Gen 2 Prius Accessories & Modifications' started by efusco, Dec 3, 2007.
  1. icarus
    icarus Senior Member
    4,884
    976
    earth
    Remember that the boiling point of liquid goes UP with pressure. That is why (one reason) modern cars have pressurized cooling systems. Your in no danger of boiling over at 212-220f assuming you have a proper coolant mix. Higher with pressure, lower with altitude.
    Having said that, my intuition is that running ~200F the engine really isn't more stressed than ~190F, but running consistently ~220F would get me worried. I suspect that there are some gearheads out there who would really know. My problem is more with -40F!
    Icarus
  2. dragonrand
    dragonrand Junior Member
    74
    22
    Springfield, MO
    Is my blocking method safe/effective?
    I blocked my grille a few weeks ago. I commute about 40 miles each way, hilly highway driving, running between 65-75mph. Outside temps have occasionally gotten above 50F during that time, and your post now makes me worry I may have been pushing the limits of the Prius' operating temps, with the hilly terrain of my commute. I currently have no way to measure temps. I'd hoped to get a CAN-view at some point, but now I wonder, if I'm going to use grille blocking, should I invest in a scanguage asap and get the CAN-view later? (I hate to spend the extra money -- I'd prefer to just use the CAN-view.)
    How I Blocked My Grille:
    For the upper grille, I blocked each slat individually with it's own, single piece of pipe insulation foam (meaning I didn't use the foam to span across any slats). Each grille slat is itself visible, but the spaces between are completely blocked from end to end.
    (I presed the foam tightly into place, and of course got a wavy effect from the vertical cross-supports attached to the grille's back side at regular spaces. To create a more even look, I pressed the foam very firmly into place, then pulled it out. There were clear indentations in the back side foam where they had been pressed against the vertical supports, so I made a simple slice partway into the foam at those points, then pressed the foam back into place. The supports slipped nicely into the newly cut notches in the foam, allowing for a nice, even look for the upper grille.)
    For the lower grille, I did span the foam pieces across slats. I used three pieces of foam altogether. The top piece tucked into the first and second spaces, covering one slat. The middle (slightly thicker) piece tucked into the second and fourth spaces, covering two slats. The third piece tucked into the fourth and fifth spaces, covering one slat. However, although the lower grille is blocked from top to bottom, it is not completely blocked from end-to-end. The lower grille has the same cross-support pieces spaced regularly across the backside of the grille, effectively dividing it into sections, and the sections on the very ends are not blocked. I haven't measured it, but I'd estimate that my blocking method leaves about four inches unblocked on each side of the lower grille.
    This makes me wonder whether 1) I've blocked enough of the grille to be effective, or 2) I've blocked TOO MUCH of the grille to be safe given the driving conditions of my daily commute to work (hilly highway driving). :(
    Also, I'll be driving home to the rocky mountain region for the holidays -- a two day drive one-way -- and I wonder if, with no way to monitor temps, my grille as currently blocked is safe for such a drive. It'll tend to be colder in the rockies, with temps rarely above freezing and probably never even into the 40s.
    Can anyone offer wisdom as to which areas of the grille cool which components? I'm also curious where the outside temp sensor is located and whether my grille blocking is giving me inaccurate (high) outside temp readings.
    Bryan
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Bryan,
    I suspect you're OK, though I'd remove at least one piece of foam when temps are over 50.
    I had intended to update this thread anyway after my recent trip to and from KC.
    What I found was that on the way up with temps consistantly in the 30s that with the grill fully blocked (individual foam piece in each slat) that all temps for the ICE and MG2 inverter were fine. It's around 150 mile trip.
    On the way home it was interesting. Temps were in the 20s in KC when I left so there were obviously no issues...esp. since the battery had had a 3 day 'cold soak' in the parking garage as it went unused during my conference.
    As I continued South the OAT rose to the thirties. And still temps were fine though the ICE was pushing 190 and MG2 Inverter was in the 80s and occ. low 90s.
    The final third of the trip saw OAT climb into the mid-40s. And again I started seeing high 190s and occ. 200F for the ICE. But I finally got bright and decided see what the other key electronic stuff was doing. I started looking at MG1 motor & inverter as well as MG2 motor and inverter. MG1 motor was pretty consistantly the highest temp at 130F..and it seemed to stay there. MG1 inverter was usually next highest and stayed b/w 105-120F. MG2 motor didn't get hot very often and MG2 inverter showed a continuous climb in temp up to around 110F range with occasional peaks after heavy used (long slow regen stops or starting off the line) as high as 130F.
    If anyone's interested...the battery temp started at 35F and never got over about 58F even when I got home.
    So yea, once you start getting into the 40s AND you're going to be doing prolonged driving (more than 40-50 miles?) I'd feel a lot better if I had some sort of monitoring equipment to keep an eye on things. I'm not sure that Scan Gauge is adequate since the only temp you can monitor is the ICE.
    Also, I've never seen issues with shorter trips, ie my normal commute, with fill blocking even when temps were as high as 50F. I think it takes time for the temp to build.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    that would be an extremely tough call because i dont think water temps are the issue here. any radiator has built in safeguards so i wouldnt concern myself with that.
    what is of more concern is the temps inside the MG's. if you are going to be in the mountains doing a lot of elevation changes, remove one of the lower blocks. that should cover you against overheating there.
  5. icarus
    4,884
    976
    earth
    Wouldn't it be cool if one of those genius' out there would build an after market shutter kit like I had on my transport trucks. It would open the slats when all the temps got above the optimum and closed them when it was below. Pretty simple to do in this day and age.
    I run with all the grill blocked except the bottom until the temp is ~50F or above. I have ordered a scan gauge, once I get it going I will consider blocking the final slat.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Bryan, I keep the upper grill blocked all year and it improves the FE. I have yet to have the fan turn on even in warmer temps with both grills blocked. The usual route is around 35 miles highway driving zoned 40-55mph.
    Sign me up for thermostat controlled slats.
  7. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Great Thread
    Evan,
    Thanks for the write-up. I was sure before now that 90C to 95C (203F) was all good, but I'll start getting a little more worried above 85C. In Texas we routinely get 30F swings in temperature. This week alone we've seen the temps swing from 82F to 45F.
    When I first started blocking my grill I though that I would surely get my summer MPG, but running blocked with Winter Gas (bad RFG in Houston) I'm consistently 5-10 MPG down from my summer averages.
    May need to get that SG II+XGauge if there is any way to peel MG2 temps (searching PC in a separate tab already)
    11011011
  8. efusco
    19,891
    1,196
    Nixa, MO
    Can't get that info w/ SGII-X. The only new data is SOC and HV Batt. voltage.
  9. Bob64
    1,540
    93
    Virginia
    Heres a question: Instead of removing an entire lower bar, why not remove a bar's worth of blocking on the right side of the car (in front of inverter).
    That way the inverter gets air, and if needed, it can also provide some cooling to the radiator. Then the people with a SG can monitor the ICE WT directly to check if it is overheating.
  10. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Evan, do you still have the fiberglass insulation in your engine compartment?
    If yes, do you think that could be effecting inverter, MG1 and MG2 temps?
  11. efusco
    19,891
    1,196
    Nixa, MO
    Good question...No, I don't have that packed in there any more so that isn't a factor.
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    longer warmup times is only part of the drop in winter gas... changes in the formulation will take 1-4 mpg depending on your location. summer gas freezes at a very high temperature, so winter gas has additives that lower it to prevent gas line freezeups and such. the additives take up space but dont burn, so your winter gallon of gas is actually not a whole gallon. there is only three small areas in the country that dont change their formulation for winter...mostly southern florida and whatnot.
    also, colder air is more dense, so air friction is higher as well.
    tire pressures drop in colder weather, so real important to adjust. definitely check your tires in the morning to insure that your pressures are still where you want them to be.
  13. hill
    9,038
    Regarding the 190 temps, I remember some cars (at least in the 1970's) had factory thermostats in the 220's for emissions purposes. Seems as though if engines are meant to run that high (just for minimum operation), then it wouldn't really be an issue, would it? I really don't know, but mabe some motorhead might bring up what temp is safe, on the high end.
  14. efusco
    19,891
    1,196
    Nixa, MO
    I can't give you a definative answer on that, I suspect the ICE in the Prius could run safely and efficiently at 220. My primary concerns, again, were that the Inverter temp was higher than I'd ever previously seen it run for any sustained time and that it was continuing to climb. I'm confident that a long drive (several hours) without stopping would have resulted in dangerously high temps. Further, the ICE temp was continuing to climb and I suspect it too would have climbed higher.
    Again, although the temps I observed I do not consider dangerous my concern is that the ability for the Prius to compensate was gone, the temps were continuing to climb, and that someone without the ability to monitor the temps closely could easily get into a temp range that could put the car in danger of damage.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    still no info on the max safe temps for the MG's? that would help a lot.
  16. drees
    drees Senior Member
    1,782
    247
    Would be intersting to see what temps hit without any grill blocking and ambient temps of 100*F+. Throw in some mountain passes, too. That ought to tell you what reasonable max temps are that you should be sure to keep temps under. :)
  17. efusco
    19,891
    1,196
    Nixa, MO
    I've seen some 120s in the inverters in summer 100+ temps, not sure what the peaks are with reversing and heavy stealth use.
    It's been reported that 220-230 is what the inverters have been tested at so I think there's some margin of safety...but I'm not interested finding out what the practical limit is!:eek:
  18. icarus
    4,884
    976
    earth
    Pardon my confusion here,,,
    I just installed a scan gauge today. I have been running with all but the bottom slit covered for several months. Temps in the 30's-50's F. I have always suspected that the car was running cold even with that much of the grill blocked and the heat on. My first test drive confirmed that. Freeway driving @ 70mph and the temp struggled to stay near 175f (O.A.T. ~45f)
    I blocked the final bottom slit. The car warmed up quicker, and got to about 190f with no heat on. After I turned the heat on, it stayed ~180f. 50mph up a 2 mile hill brought the coolant temp to 200-205f. It is nice to be able to see quickly what is happening.
    My question is this: We are going on a trip next week through the intermountain west, E. OR, Central NV, AZ, NM, UT. If I were to unblock some section of the grill to cool the inverter? Drivers side top top, slit, top bottom slit, bottom top slit, or bottom bottom slit?
    I don't have a great concern that it is going to over heat, but since we will be in the mountains alot, with no way of knowing I think perhaps I should unblock part of one.
    Any ideas would be appreciated. Thanks in advance
    Icarus
  19. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I'll restate my thoughts.
    First, I don't think we are in any danger of overheating the engine/coolant. The reason is the fans aren't even running. Once you get the thermostat fully open you are just -starting- to get the rad in use. Worry when both fans are running at full speed.
    I worry only about the inverter temp. Saying this, however, I DO NOT worry if the inverter temp is below 150F. Ambient can (and does) get over 110F in the southwest US (and probably parts of Australia as well - the north east from what I've been told). If the ambient temp can get that high, and we don't have refrigeration to cool the inverter, then the inverter is designed to be safe at those temps and a fair bit above.
    I think many of you are overreacting. But keep watching, because sooner or later, somebody WILL overheat the car.
    More information is always a good thing, as long as we all remember to "DON'T PANIC!!" ;)
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    with temps in mid 30's to high 40's, i block EVERYTHING and have done so for past 3 winters...
