Grill blocking (New to a Prius)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Patrick_Roderick, Nov 12, 2014.
  1. DenToyPri05
    DenToyPri05 Junior Member
    118
    24
    Denver, Co
    If I'm taking a road trip from Colorado to California, and the lowest and highest temps are respectively 30s and 70s, how much of my grill should I keep blocked, if at all, for best mileage?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The heat-retention benefit comes from temperatures below freezing. I'm about to remove my blocking now that things are melting here.
  3. Patrick_Roderick
    Patrick_Roderick Junior Member
    Waconia, MN
    i have removed 50% of the lower grill block on my prius. temps still get to the 20s in mn at night but it is getting up to 50 during the day. will be removing all of it in the next few weeks.
    T-Mobile Samsung Galaxy Note 10.1 2014
  4. Mendel Leisk
    42,352
    With temps in the 70's, and maybe some hill climbing? Safest would be no blocking. Doubly so if you might use AC.
    DenToyPri05 likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'm fully blocked almost all the time. I'll pull the uppers when I start seeing high temps. That may happen in the 90's or on cross country trips. I've pulled pieces at rest stops so the heat doesn't continue to build. If you are looking for a range of numbers I agree with Patrick Roderick. Engine coolant 195-200F, inverter coolant 160F.
  6. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Removed the grill blocks today. Temps in the upper 60's
  7. Mendel Leisk
    42,352
    Are you using air conditioning? I can't see grill blocking with AC on.
  8. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    I removed my grill blocks yesterday, temps now in the 60's some days. I don't believe in taking any unnecessary chances.
    I've been monitoring temps with scan guage. It is obvious thermo opens at 191 and cools quickly. Could probably keep them in to much higher temps, but no real need.IMHO.YMMV.ect!
  9. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Just removed upper blocking today. I think partial blocking has benefits up until A/C is needed ... (the morning temps are below 50 for a while).
    I have scangauge so I am monitoring cooling temp, I would not recommend blocking under heavy load and over 60F temp
  10. Mendel Leisk
    42,352
  11. JimN
    7,028
    1,117
    South Jersey
    In the summer CC is set around 78. In the winter set around 72.
    Last night's trip to Plymouth-Whitemarsh HS through Philly inverter coolant temp was in the low 90s. OAT was in the 50s & below. ICE coolant was low 180s.
    Route is US1/I-76/I-476 going through residential Palmyra & Tacony section of Philly and Chemical Road exit in Plymouth just before toll booth for the NE Extension.
    Anyone who believes 90F is too hot for the inverter shouldn't be driving in the South or the summer.
