Grill blocking on the C
Discussion in 'Prius c Accessories and Modifications' started by Revan86, Sep 18, 2012.
  1. FireFire
    FireFire Member
    101
    Ontario, Canada
    Did 75% for now. GTA is cold... BC are much better I guess.
  2. Mendel Leisk
    42,248
    Has anyone done a guideline for the c, how much to block, and what temps?
    Myself with regular Prius I never block the upper, and it's either one tube (50%) or two (100%) on the lower. My rule of thumb is if it's going below 0C, i go to two tube. The first tube I put in, once ambient temps are around 10C or lower.
    The upper you can block, but 50% at most, since the inverter radiator is directly behind it, there's no point to blocking that, and a complete block might even cause problems. My blocking is relatively conservative, I'd rather play it safe.
    One thing, even in winter, if going up a ski hill, I'll take all the blocking out.
    There's a thread here on 3rd gen blocking:
    2010 Prius Grill Blocking strategy | PriusChat
    Again, not sure how applicable that is to the c.
