grill blocking
Discussion in 'Gen 2 Prius Accessories & Modifications' started by donalmilligan089, Oct 23, 2008.
  1. donalmilligan089
    239
    22
    virginia usa
    What kind of material seems best to block the slots in upper and lower grill?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    foam pipe insulation
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
  4. Gutsy
    Gutsy Junior Member
    30
    Yardville, New Jersey
    I used black duct tape on mine on 2 of the 4 lower grill slots for now. It looks much neater and it blends in nicely with the black grill.
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Let's see some pics, what about removal wont it leave behind the sticky residue.
  6. Gutsy
    Gutsy Junior Member
    30
    If it does, I'm sure it will be easy enough to remove with bug/tar remover. I'll remove what I have in a few weeks and see how hard it is to remove and if there's any issues with the plastic. I'll post pics tonight or tomorrow. I picked up the black duct tape at my local auto "Auto Zone" store a while ago.
  7. Gutsy
    Gutsy Junior Member
    30
    Here are two photos of my lower grill blocked with black duct tape.
  8. morpheusx
    1,555
    81
    Akron, OH
    It looks great.
  9. hideki
    hideki Tako Time
    Detroit area
    Vinyl cove base molding - the kind used for the tile / wall interface for any tiled room. Black, tie -strapped to the grille. Easy to cut, easy to punch holes in for tie-straps using a leather punch.
  10. NC_Prius
    NC_Prius Member
    186
    I wonder how it would look if someone manufactured a vinyl aftermarket bottom grill cover, same material as the bra, with reinforced edges. Not sure if it could be tied down tightly enough to prevent all airflow from getting through though.
  11. hideki
    hideki Tako Time
    Detroit area
    For me, that is the next step. I plan on having just such a thing constructed by a local automotive upholstery shop. It must use a quick release system so that both slots (upper and lower) can be blocked, either upper or lower or none.
  12. NC_Prius
    NC_Prius Member
    186
    If the quality is good, you might ask if they would be willing to do a group buy on them. I could be in for something like that.
  13. eagsc7
    eagsc7 Geocacher
    50
    Prescott, AZ
    I'm working on a Carbon Fiber blocker... Same release method as above, but will be on a Chloroplast backing. Will have pics once I get it all painted up before I get around to fibering it all.
  14. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I have had my entire grille fully blocked with 1" foam cutouts. I left a small 2x2 in hole on the bottom left for the inverter. I have kept it blocked since winter. I have a SG to monitor temps and my engine coolant temp hardly ever goes over 205F. Usually stays around 180-195F whether its 32F or 80F out. Is it staying in that temp range bc the fan is coming on to cool it? I have never heard the fan run (not sure how loud it is) but I find it hard to believe that the engine coolant temp would remain the same even when the ambient temperature changes 50F. Any help would be appreciated!
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    already done except its plastic and color coded to match and is attached but had removable plugs; circles approximately 2-3" in diameter.
    still can be removed but probably not what you want to do. still no semi permanent solution for the top yet
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i block 100 % in winter but remove when temps hit the 60's. if the fans come on and you are not moving you will definitely hear them. on my 2004 (last time i heard the fans run was like 2005??) they came on and you can definitely hear them while in cabin.
    as FYI fans came on during trip to Montana 75 mph with OAT hitting 102º. they came on when i stopped for a pee. they ran 3 mins, turned off. then ran a few minutes more.
    as i was pulling out of the rest stop still moving at 5 mph, i heard them come on again. unfortunately i did not have any thing to check temps so dont know what the water temps were (did not get CANVIEW) until that winter
  17. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    The only other noise I hear from my prius other than the ICE is the whirring sound of the coolant pump for 10 seconds after I power off. Sometimes I can hear this same sound for 2-3 seconds when getting into the driver seat and depressing the brake (even if the car has been powered off and sitting for a quite a while). Drove home today with ambient 85F on highway at 70 and don't think I heard it either.
  18. a_gray_prius
    2,927
    782
    IL
    C-ONE makes an upper grill block part that Singma sells. I'm looking into buying one, but it's hard to get competing quotes from other vendors.
