Grille shutter Inoperative
Discussion in 'Gen 4 Prius Main Forum' started by Dragon Rider, Sep 9, 2016.
  1. krmcg
    2,592
    2,393
    Whittier, CA
    Only if the cause of the light is repaired.
    RCO and kithmo like this.
  2. fuzzy1
    10,687
    Which is was, the text warning was already gone by Post #7 of this thread.,
    Dragon Rider likes this.
  3. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    ;) I hear ya! <double wink>
  4. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    I think what the dealer did was just open the fuel l tank and closed again. The service advisor told me this is way too early. I was there at 6:30 am they fixed in 10 minute.
  5. krmcg
    2,592
    2,393
    Whittier, CA
    But was the gas cap seated?
  6. Dragon Rider
    344
    212
    Miami
    The dealer did the reset . They blame the gas cap. I don't think it was that. If that thing hit my windshield. It would have been a hell of ride. I am always looking for thing flying off . This one hit me out of no where. Scary this is why I was looking at the Rav4 . I have a jeep Wranglers too.
    I closed the cap my self last Saturday. I still have halft tank I do 90 miles a day. I think the hit happen at 6:30 am found the comment in the dash around 10 pm it took 12 hours for the comment to pop up plus the check Engine light on. Once I took the piece out . The grille comments got deleted by it self. The check Engine Light dealer reset this morning.
    #26 Dragon Rider, Sep 10, 2016
  7. sillymike
    sillymike Junior Member
    59
    GA
    Exact same thing just happened to me just got off the road after eight hundred mile trip went back out to the car get this exact same message after shutting it down and restarting I'm driving approximately a mile the message went away check engine light is still on and will not go out yet coincidently I'm heading to the dealer for the 5000 mile service tomorrow I just traded in my 2010 Prius 2 for 2017 four touring
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    Did you find anything stuck in the shutters?
    The person that had the block heater cord blocking the shutters later had a car fire that points toward the block heater cord. If you have the cord blocking, get it replaced even if it looks OK. There could be inside damage.
    RCO likes this.
  9. Mendel Leisk
    42,271
    Or just inspect it and check it's resistance, should be around 36 ohms between the two flat prongs.
    RCO likes this.
  10. sillymike
    59
    GA
    Will do found nothing blocking it. I don't recall anything flying in at the grill. Good thing I live close to the dealer. They will handle in am.
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    I suspect some strands of the cable got damaged and it heated up due to the current draw of the heater. A low current ohmmeter will not find that issue.
    RCO and Mendel Leisk like this.
  12. sillymike
    59
    GA
    Upon further inspection I found a little teeny piece of plastic lodged in the shutters that must have been road to breathe because nothing looked like it was broken looks like it return to normal operation but the check engine light is on good thing I'm heading to the dealer tomorrow for my first service thanks
    RCO and Prodigyplace like this.
  13. sillymike
    59
    GA
    Just an update left the dealership they reset the code everything was fine.
  14. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    I got the grill shutter failure message. Took to to the dealer. Not covered under warranty because there was debris in the tray behind and below the shutter. Not that it wasn't stuck in the shutter itself but they still said it wasn't covered because the debris most likely cause the failure.
    So this is a warning to anyone who their Prius under warranty. If you shutter fails, you need to remove the tray below the radiator and clean out any debris that might have flown in there or your warranty won't cover it.
    Bottom line is the dealer gets less if they repair it under warranty. A LOT less so it's in their interest to try and deny coverage so they can get more from you. I declined and will fix it myself. They want $800 to fix it parts and labor. They said the shutter itself needs to be replaced but it doesn't. It's fine. It's just the actuator which will cost me $250 new.
