Grille woes.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jul 23, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    I accidentally broke off a couple of the plastic clips on the front bumper that hold the grille on. Do they make an aftermarket grille that screws in?
  2. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,514
    Durham NC
    No girlie slides in on the lip created by the bumper cover just put some goop in the grille slot that accepts bumper cover insert pull it forward let dry 30 min .
  3. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    Drill holes and use zip ties? I would be worried though that the zip ties might eventually cut through the relatively soft bumper cover material.
    Not sure what the "clips" look like that you are referring to, but it is possible to repair some parts of bumper covers, for instance:
  4. highmilesgarage
    highmilesgarage Active Member
    494
    184
    Kansas City
    plenty of them in amazon, you can buy one with inserts for fogs if you don't have one and wire the fogs manually.
  5. Tombukt2
    13,836
    2,514
    Durham NC
    This is bumper cover grille is black part wer fogs go .
