***Grinding noise when in reverse...***
Discussion in 'Gen 3 Prius Main Forum' started by Greenteapri, Jun 4, 2019.
  1. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    Everytime I move in reverse I hear a loud grinding noise coming from my tranny. I found this:
    I'm pretty sure it's this but it sure scared the bajezus out of me.
    Thank you AISINs.
  2. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    I knew the Prius had low ground clearance, but that's crazy.
    Greenteapri likes this.
  3. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Missing push pins?
    Montgomery and Greenteapri like this.
  4. Greenteapri
    330
    388
    Cypress
    Yes, most likely. I really hate those with a passion. They are hard to get off without breaking; especially when they are old and brittle.
  5. Mendel Leisk
    42,359
    Comes from flexing back that "oil flap" for oil changes. It's a poor design; better to take the whole underpanel off. If that hinge is near-completely cracked you can maybe cobble something, drill holes and install zip ties.
    If you're missing fasteners, the attachment has the part numbers. It's good to wash the fasteners out in soapy water, before reinstall: it's grit that jams them, makes the hard to remove, prone to break.
  6. Greenteapri
    330
    388
    Cypress
    Thanks.
    I purchased a 100 count of those fasteners already. So when I need to service the vehicle, I can rip those old ones out without hesitation. :D
    jb in NE likes this.
  7. Mendel Leisk
    42,359
    There's three part numbers. The vast majority are #3 (not shown, but basically all the fasteners down the sides and at the front), there's a couple of #5 (they have grey centre caps, are slightly larger), and a couple of #4 (at the plastic-to-plastic splice). If you take the whole panel off you never deal with the latter.
  8. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    There was more damage to the push pins after the first 2 "Free" oil changes than the 14 oil changes since.
  9. Greenteapri
    330
    388
    Cypress
    No thanks. I'd rather keep that 'skid plate' in place. I never know when the next off-road opportunity will present itself. ;););). Plus I'm sure removing it will increase drag on an efficient vehicle.
  10. Greenteapri
    330
    388
    Cypress
    They have to make their money somehow lol. OEM Toyota clips are expensive.
  11. Mendel Leisk
    42,359
    I bent the flap back for the first oil change (DIY from the outset), and the way the whole panel was flexing, I vowed nevah again.
  12. Greenteapri
    330
    388
    Cypress
    You're such a rebel, eh. :rolleyes:
    I feel the same way with ICE vehicles. Nevah again! I'm going American, I'm going Tesla.
  13. Greenteapri
    330
    388
    Cypress
  14. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    No noticeable increased drag on my 15 (1 year ave 52 mpg), but I do agree on the protection factor, especially from road debris. I decided to risk it anyway since I have never had road damage underneath on any car I ever had and none of those had a plastic shield.
  15. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Good plan. These are essentially wear items. I have bags of them at home. If the old ones don't look new, I replace them. Cheap enough.
  16. ChapmanF
    19,041
    My oil pan flap and "engine cover no. 2" were torn off today by some unexpectedly high water during an extreme weather incident. Then I reversed and the oil flap got bent under and creased.
    My heat gun on about 5 was able to relax the crease and get the flap nice and straight again.
    The plastic around the clip holes in engine cover no. 2 broke in neat lines and just bent around the clips (which stayed attached to the car).
    I found my same heat gun turned up to about 7 was able to melt the polypropylene and sort of stick it back together, only the airflow from the heat gun tends to blow the softened plastic away from the break instead of back toward it. I'll probably just buy another engine cover no. 2, as it's only $27 (unlike the oil flap, which only comes as part of "cover assembly" at over $200, hence my straightening it out).
    Crazy.
    Bay Stater and jb in NE like this.
  17. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Making the flap easily removable is a better solution than taking off the whole panel every time, methinks. Besides reducing the number of push-pins to contend with, that eliminates the need to lift the car up high enough for the silly flap to clear the ground.
    Bay Stater likes this.
  18. Mendel Leisk
    42,359
    Yeah 4 gen is better in that regard: it has 3~4 screws holding a small panel on: take out the screw and the panel just drops off. Still, it's good to take the whole schmo off once in while, check for leaks, look at the CV boots.
  19. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    I have it down to 3 push-pins and 2 screws to take out each time.
  20. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    I bought extra push pins. For some reason My car had 2 different sized push pins. I ended up with the larger size. I think I had to enlarge 1 hole as I recall. Like I said, since I have been doing the work they don't seem to get damaged even though I know they are a wear item.
