Grinding noise when turning right at moderate speed (10-40 MPH) - 2005
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Onomatoprius, Jan 23, 2024.
  1. Onomatoprius
    Onomatoprius New Member
    Hey y'all. Have an '05 with 212k miles on it.
    Had a noise start about a month ago (or that's when I noticed it, at least). It sounded like mechanical mayhem on the front left wheel when I turned right.
    It sounded familiar, so I went ahead and replaced the wheel bearing with OEM.
    A lot of the noise went away. It's totally quiet when driving straight now, but a certain noise persists when I turn right.
    It's not the mechanical mayhem sort of noise from before, but a very consistent grinding hum. Like someone is dragging a rock across concrete. I can feel the sound as well, in the steering wheel and center console. Nothing major, but I can feel it.
    I looked over the suspension and all the joints/bushings/boots/etc. look fine. The inner fender isn't sagging at all and there's no parts interfering with each other that I can see.
    Anyone have any ideas? Is it at all likely that it's actually a steering issue?
    Thank you for any and all responses!
