Grinding sound after bearing replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by zhawk316, Jun 7, 2020.
  1. zhawk316
    zhawk316 Junior Member
    I recently replaced my front passenger wheel bearing. After getting everything put back together, my Prius started making a hard grinding sound while in gear. I took the caliper off, the hub assembly, and the rotor, one by one and still have the grinding noise. My cv axle has no play in it. Any thoughts? I’m stumped.
  2. MoffettMotors
    MoffettMotors New Member
    New Jersey
    Something isn't right, is the axle completely seated?
  3. RideTheUS
    RideTheUS New Member
    CT USA
    Having the same issue. Was there a cause identified? Thanks
