Gross HV fan and Waterlogged 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hyp3rmil3r, Mar 27, 2020.
  1. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    Cleaned out my disgusting gen 2 some more today after the persistent musty smell kept returning. Must be a leak somewhere...note that odd metallic looking square on the metal behind the hv fan. Is that a patch? It was pretty damp (along with a lot of the insulation).
    Enjoy the pics! Sucked all the water out and let things air dry a bit. Lazily cleaned the hv fan.
    Not sure how to test the hv fan but I imagine thats a good idea.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Be sure to check both pieces of the fan connector for corrosion (y)
    edthefox5, hyp3rmil3r and Raytheeagle like this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Take the spare tire out check under there for water. Reports of water getting under the rear seat carpet area too so might want to smell around the carpet areas.
    And if the ac drip tube gets clogged from lack of maintenance the ac condensate will over flow into the front passenger floor.
    Montgomery likes this.
  4. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    Yeah I took the spare out and removed the floor plugs so that area could drain. There was a good bit of water in there. I’ll take note of the wet carpet from the A/C.
    iPhone ?
  5. Mendel Leisk
    38,739
    Now the "fun" part: figuring out where the water's getting in.
    hyp3rmil3r likes this.
  6. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Raytheeagle likes this.
  7. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    Terrible cracks! Slapped caulk all over it lol.
    iPhone ?
