Ground Clearance?
Discussion in 'Gen 3 Prius Main Forum' started by kgall, Jun 9, 2009.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    What's the ground clearence on the Gen 3 Prius?
    I ask because I live on a dirt road, not too bad, but not perfectly smooth. My antique (1999) Corolla does OK here. But I saw some complaints about low clearance on the Gen 2 Prius.
    Does the clearance differ with trim level? I'm not planning on getting the 17 inch wheels.
    Sanjeet likes this.
  2. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    The specs provided by Toyota say that the minimum ground clearance is 5.5 inches.
  3. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Minimum clearance is listed as 5.5 inchs.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It is more than the 2004-2009 Prius and I very rarely have problems doing down dirt roads, even ones with large pot holes. I regularly take mine offroad on our nature preserves and it does quite well as long as you don't try to go up too steep of an incline where traction control might kick in. In my case, the incline doesn't have to be very steep. :(
  5. Boo
    5,051
    485
    97
    Flushing, NY
    Because it says "minimum" I presume they're talking about the 17" tires which has a diameter that's 0.4 inches less than the 15" tires.
    Therefore I'm guessing that the ground clearance with the 15" tires is 5.9 inches.
  6. RodJo
    RodJo Member
    423
    56
    Boston
    I didn't check your math (although that seems like a big delta), but wouldn't it be the radius difference that you're looking for here? Making it 5.7 inches?
    2 people like this.
