Grounding kit for the Prius - would it make sense?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by rookie, Apr 17, 2005.
  1. sleonardelli
    sleonardelli Junior Member
    141
    Ruskin Fl
    Thanks so much!! After all the reading I've done on this social network I kinda believed it to be "bunk". I'll save my money and keep reading all the value and sage advise from this forum!!!!!;)
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Want to "improve" the grounding on your Prius?
    Remove rear hatch floor.
    Remove right side cover over battery.
    Check battery -ve post clamp for tightness.
    Check bolt on -ve battery cable that goes back to the chassis/body for tightness.
    DO NOT overtighten either bolt.
    Cost - 10 min of your time.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
  4. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    [SIZE=-1]Quoted from: http://www.sigmaauto.com/EGS/egs.php:
    [SIZE=-1][​IMG] Exhaust Grounding System[/SIZE]
    "Sun Auto now offers specialized earthing straps to properly ground your exhaust system to the chasis. Based on research & development of the HGS, the new Exhaust Earth is designed to maximize exhaust efficiency by minimizing static electricity that obstructs exhaust flow inside the muffler. Benefits include: Increased torque response / reduced static electricity in exhaust / reduce vibration noise from exhaust / improve corrosion resistant of muffler. Use w/ HGS for cumulative performance enhancement!
    [SIZE=-2]Installation: Each kit comes with 2 ground straps; one is connected from the exhaust where the muffler bolts on the midpipe to the chassis, and the other is connected from the exhaust where the midpipe bolts on the cat. converter to the chassis. If possible, best results will be had if any paint/debris is scraped where the terminals connect for a solid metal-to-metal contact."
    [/SIZE]
    [/SIZE]
    So let me get this straight, there is some kind of static cling inside my muffler that won't let the gas out?!? Would some of those drier sheets help? If only the factory could do something to provide a solid connection between the ICE and the exhaust, or if some kind of conductive material ran between the exhaust and the body. Someday maybe...
  5. patsparks
    10,664
    569
    Adelaide South Australia
    You can get it by the bag cheaper,
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    unfortunately, the guy behind sigmaauto should know better, and
    he's on the forums occasionally. But I guess his job is to
    sell stuff.
    _H*
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    This is called conventional current flow. All electrical engineers draw current flowing from positive to negative, unless we are talking about semiconductors with major and minor carriers or some form of bizarre gas discharge.
    Tom
  8. problemchild
    problemchild New Member
    429
    37
    You guys dont have a clue.....
    I installed the big ground kit and I got my wife back, my dog back, my job back and I caught my limit of fish this weekend. So there!
  9. racerbob
    racerbob Member
    138
    S Florida
    If your main power connections are corroded slightly or just loose, it is easy to do a voltage drop test with a multimeter to determine where the extra resistance is located. Just cleaning and tightening the connections will usually
    restore good current flow. Don't waste your money on fancy wire. The oem cables do their job quite well unless there is a fault at the connections.
  10. TVT_Design
    TVT_Design Junior Member
    16
    2002 Prius
    Sorry to resurrect a dead thread, but it beats starting a new one. I actually joined this site to see member's takes on products such as these.
    Sun Automobile U.S.A.,Inc
    I run a small performance shop that focuses on Mercedes cars and we needed to purchase some items from this company for a battery relocation kit. I also have an 02 Prius. I was gonna purchase some of their gas saving products to try them out and see if it really does make a difference. The site and information looks really wild, but in theory some of the things may work.
    Anyway, I was seeing if there would be interest and knowing the results. If they are good I can get more at wholesale for whoever wants them.
    I'll post back when the parts are in.
    Anthony
  11. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    :welcome: Welcome to PriusChat, Anthony!
    I think most of us are interested in validated benefits, but there is so much snake oil sloshing around I wouldn't buy most stuff until it was proven. If all the crap out there was as good as it claims, wouldn't the auto makers be using it to try to get an edge by building it in?
    Let us know what works for you!
  12. GatorJZ
    GatorJZ Member
    285
    17
    Please follow through on this. I installed a grounding kit on my 300ZX. It did smooth out the stumbly idle that a lot of these cars experience. Curious to see what, if anythng, the dyno indicates this did for your Prius.
  13. TVT_Design
    16
    2002 Prius
    I didn't plan on dynoing the car as I don't think any of us care how much power we're adding. I was going to do a comparison of average gas mileage for each mod. Each reading will be taken at the 500 mile mark and then one mod added at a time.
    I would like to do a larger amount of driving for each test, but the test would go on for months if I waited for that.
  14. chinalfr2
    chinalfr2 Member
    234
    New England
    You can DIY your own grounding kit. The cost will be less than buying a kit. I did my own DIY grounding kit for my Evo 8. The grounding kit did improve the car idling and responses.
    The other day, I was checking the engine bay and I look at some ground cable on the Prius. I think I will try to DIY my own grounding kit and see if there is any improvement. To DIY your own kit, just need to purchase some 0/4 gauge power cable and terminal. Measure the length, cut the cable and crimp the terminal.
  15. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Where would the extra ground wires even go or connect to since the battery is in the trunk?
