Grouped lots of Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by clintonsimmons, Nov 9, 2024.
  1. Mendel Leisk
    42,354
    That just might work, lol.
    douglasjre likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    ?????????:confused::confused::eek::eek:o_Oo_O(n)(n)
    Brian1954 likes this.
  3. clintonsimmons
    clintonsimmons New Member
    Dallas
    Ok so first. Yall are hilarious.
    Inwent to a shop to see about the head gasket.
    Compression was 170psi in each.
    Leakdown test passed
    Engine block smoke test passed.
    So $250 for peace of mind!
    now… i’ll shoot some video to see if i can capture the death rattle. If the hg is ok. Whats the other cause? Sounds like no one is sure?
    ill review your posts and make a plan. Thanks everyone.
    52,863
    congrats!(y)
  5. ASRDogman
    8,067
    4,089
    Bore scope w/pressure test...
  6. clintonsimmons
    Dallas
    Hello again! here is the update... and the orange triangle of death!
    1. EGR cooler was disgusting and blocked. 110k miles. took 6 days in oxyclean THEN power washer blast
    2. Valve, pipes, elbow cleaned with new gaskets.
    3. Intake manifold was disgusting. pooled oil.
    4. throttle body was nice!
    5- I ADDED IN A CATCH CAN.
    6. reinstalled everything and now the hybrid systems check cuts out the READY light.
    I understand this happens if the HV battery discharges while it was off for 3 weeks. What's the fix here?
    I have a Dr. Prius app and code reader coming today. I'll add in codes.
    But did I kill my prius? Is this the first and second battery sections discharging? How do I fix this new hell!?!?!?
    Thanks everyone!
  7. Mendel Leisk
    42,354
    When taking pictures of the cooler interior, you really need to override auto-exposure, or get some kind of penlight source aimed into the interior.
    Car won't start and you've got CHECK HYBRID SYSTEM alert? Can you see hybrid battery charge status, and if so, what's it showing?
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    Most likely you have something disconnected or your new catch can system/hoses are leaking.
    Second possibility is you may have pulled the orange hv disconnect and failed to push in the interlock after you snapped the handle in.
    Independently, your hg problem probably is still there regardless of the egr state. You really need the dual view borescope test which was promised early but apparently not done as part of the conventional $250 tests. Those tests are not conclusive on a gen3.
    Car Care Nut HG Borescope at 7:40
  9. clintonsimmons
    Dallas
    thanks. I wasn't in the trunk near the high voltage orange interlock. so maybe something in the intake/inverter area. I can check the large orange cables under the hood for looseness. yes, the pictures are bad. Should i open it all back up to take more? lol.
    Yes, it starts on READY, the ICE engine runs for about 20-30 seconds. Then the CHECK HYBRID SYSTEM
    Then the ICE stops, then the READY light goes out. Then it sits ON but not running or ready.
    I'll look for state of charge and codes soon.
  10. rjparker
    11,117
    6,975
    Texas Hill Country
    98% the engine is not actually starting but it sounds that way as MG1 spins it at high rpm. The pcv is one of many things disconnected that will cause this.
  11. clintonsimmons
    Dallas
    so the hybrid system does have charge on it.
    I believe the gas engine is running and shaking. I can feel it
    Are you saying that’s the traction motor just spinning the crank?
    I put a video down there to show you the ready light on and off
  12. ASRDogman
    8,067
    4,089
    First, stay calm.
    If you had used oven cleaner, you could have saved yourself 5.5 days....
    Did you clean the egr holes in the manifold?
    It's extremely likely you just forgot to install something.
    Double check EVERYTHING. Each connector, and hose filling.
    This happens to a lot of people and 99% of the time they forgot to connect something.
    GO SLOW, check everything, every connector and hose.
    Did you remove the orange safety plug for the hybrid battery? There was no reason too.
    But some people do, they even disconnect the 12v battery.
    There is nothing related to the hybrid battery for the egr system.
    Check that everything on the intake manifold is connected. It's sneaky and tricky.
    I don't understand this: "Is this the first and second battery sections discharging?"
  13. ASRDogman
    8,067
    4,089
    Since you installed a CC, it's likely you left something loose. See post 30.
    That's a big vacuum leak.
    PLUS!!! Do NOT just keep trying to start it. The hybrid battery is low.
    By letting it keep turning the engine over again and again, you're draining it.
    If it gets too low, you will have another nightmare on your hands...
    Find the vacuum leak first.
    IF you MUST try starting it, be ready to turn off the car if the engine doesn't
    start right up. You'll know it, because it sounds different then just turning over,
    which is what it is likely doing.
  14. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Yes, the HV battery turns the crank until the engine "catches" and if it never does it can last around 10-20 seconds before it dies. Each try will take up a healthy portion of the battery, so be very mindful from here on out. If it does get too low you need to charge it, which is not difficult, but does require a charger (which will be expensive). I would be double and triple checking everything visually before even attempting another start.
    I don't think those tests are always particularly effective on these cars unfortunately. Visual check with a boroscope in the cylinders is generally the preferred method for 100% confirmation. People say you need to pressurize the system, but (if the car runs) you can let it pressurize itself and then just wait a while until you check the cylinders.
